COME Vs SCAT 355 stroker cranks
_rocket_
Posted 23 November 2009 - 07:51 AM
Posted 23 November 2009 - 08:30 AM
I am also interested with these SCAT cranks CMP in Perth is doing a SCAT stroker kit for under $1300 at the moment.
I have never heard anything good or bad about them.
_Ozzie Picker_
Posted 23 November 2009 - 07:59 PM
craig.
Posted 23 November 2009 - 08:33 PM
I've never heard bad things with SCAT gear, but i cant say the same for COME gear at times unfortunately!
Cant go too far wrong with SCAT!
Posted 02 December 2009 - 11:27 AM
_rocket_
Posted 02 December 2009 - 12:22 PM
I see SCAT 355 cranks on ebay for around the 750 and up , why would you go there when they are only 460 from Rocket new ?
_TJ253_
Posted 02 December 2009 - 12:28 PM
_rocket_
Posted 02 December 2009 - 12:35 PM
They say Eagle arnt as good as SCAT, but I have never bought any so dont know, but I think I will just spend the extra and buy a CSR.
Posted 02 December 2009 - 03:14 PM
I will never use them again.
_Drag lc_
Posted 02 December 2009 - 05:00 PM
i know its not a holden but dads supercharged flathead dragster runs a scat stroker crank and h beams it has run up to 18psi boost and countless blown headgaskets hehehe. it has now done a full season (race meetings twice a month) with out failure we will be freshing it up over xmas rings,bearings,valve springs.
Cheers Hayden
Posted 02 December 2009 - 08:54 PM
There was a 355 COME crank on ebay for 700, had no parts numbers on the box, just come cast on it, anyhow, I bid to 650, it went for 660, then next thing I get a second chance on it, the new owner didnt want it, said he it was a chev crank ? maybe it is was copy ?
The COME cranks can be ordered to suit Holden or SBC conrods. Chev journals are smaller dia. and wider than Holden.
_rocket_
Posted 03 December 2009 - 05:17 AM
On the link above Andrew, does it look like the packaging a COME would come in or ? The guy says it has no part numbers on the box,would this be correct ? Cheers mate.
_moot_
Posted 03 December 2009 - 11:06 AM
i'm also using scat I-beams in this motor.they are 5.7" long but with a holden journal
Posted 03 December 2009 - 12:21 PM
Posted 03 December 2009 - 06:22 PM
Yes.
