Connection of Emission hoses
_1ARC_
Posted 24 November 2009 - 06:20 PM
_The Baron_
Posted 24 November 2009 - 09:48 PM
The fuel line should come straight in the front on the LX but that picture has it coming in from the side.
(If that makes sense)
The LX is a little more complex. From memory (and I may need correcting), it is something like this.
It has a temp switch at the back of the DS head, it operates a solenoid/valve that prevents vacuum signal from operating the vacuum advance on the distributer.
There is also a coolant temperature sensing valve/tree at the front of the manifold that also stops the vacuum signal getting to the dist.
Also, the Manual LX 5 ltr has no EGR.
I don't have the diagrams at my finger tips but others may have?
Again it is just off the top of my head and may be a little wrong.
Good luck
Posted 02 December 2009 - 11:21 AM
Posted 02 December 2009 - 01:14 PM
. As Baron says, manual has no EGR.
Unless it has A/C???
I know of one with...
_1ARC_
Posted 02 December 2009 - 01:40 PM
Posted 02 December 2009 - 05:50 PM
Posted 03 December 2009 - 02:05 PM
I think Terra is confusing the vapour return line with the canister, as A/C cars have a return line from the fuel separator in the fuel line.
Is an EGR valve bolted to the inlet manifold near cylinder no.5???
Hopefully I will have to low down on the car after the STC get together next week as the owner is not a member here.
Edited by TerrA LX, 03 December 2009 - 02:06 PM.
_1ARC_
Posted 04 December 2009 - 11:24 AM
Posted 04 December 2009 - 11:41 AM
_The Baron_
Posted 05 December 2009 - 04:34 PM
Posted 05 December 2009 - 08:53 PM
_1ARC_
Posted 07 December 2009 - 10:50 AM
