LX406
1977 LX Hatch
Engine: 400 chev + .030 =406 c.i.
Cast std crank, x rods 5.7", cast flat top pistons. 10.8:1 compression
462 fuellie heads 1.6 2.02 valves, ported and port mached.
Crow cam solid, cat no: 1803 http://www.crowcams....ue-ChevSB.shtml
Texas Race Engines roller rockers 1.5:1 ratio
Victor Jnr manifold. 700 dp holley (unmodified)
ICE ingnition, compu curve box, and rev limiter
Power on engine dyno (flywheel) 449hp 5250rpm 497 ft lbs 4200 rpm
Fuel system: fuel cell in boot area. BG400 pump (since replaced it with a BG 220HR) 1/2 lines, BG regulator up front.
Transmission: TH400, 4000 dominator converter. Normal shift (not full manual)
Diff: 9" 3.7:1 full spool, 31 spline moser axels
Car: LX hatch, 6 point steel cage, minimal interior, fiberglass bumper bars, all the other panels standard, and glass windows.
Wheels/tyres: 15x3.5 weld draglites, front runner tyres. 15x8 with 26x10x15 Mickey Thompson Slicks.
Suspension: Front, std height 6 cyl spring, 90/10 shocks. Rear, very low springs, monroe gas shocks (found at the wreckers) boxed arms, nolathane bushes.
Performance: Best time 10.86 @125mph at calder on chilly friday night. Best 60 ft 1.48 sec. That felt really fast, front wheels off the ground by about 1 metre!!
Faults with the car: It launched very hard, but never straight. One time I had to back off as I was aiming for the xmas tree!!
The car is now gone, I sold it. I have the same combo in my HG Prem. It ran 11.51 @117
Now tell us your combo.
Edited by LX406, 06 April 2006 - 03:16 PM.
