myss427 - beautiful work! I rate your car up there with Howard's SLR8000. Awesome stuff!!
I'll post up my combo when I get the time too....
Posted 14 April 2006 - 01:07 AM
Posted 14 April 2006 - 02:05 AM
Posted 14 April 2006 - 09:32 AM
Posted 14 April 2006 - 10:25 AM
Hi LXCHEV,bones - Wow, very impressive mate. So close to running a 10sec pass too! Couple of questions if you don't mind me asking (I'm real interested in your combo, as I'm also running a 383 Chev): what intake manifold are you using? dual or single plane? Cam - solid or hydraulic, big or small?? Also curious as to what kind of hi-stall you have? Oh, and lastly - extractors? Tri-Y's or 4-into-1's?? Is your engine a big revver or not? I find that 383's tend to fall over after 6000rpm. How driveable is yours? A flat 11 is FAST! Your combo sounds quite tame. My car is a couple hundred kilo's heavier than yours, but a lot of the other stuff is very similar.
Posted 14 April 2006 - 10:55 PM
Posted 14 April 2006 - 11:39 PM
Edited by LXCHEV, 14 April 2006 - 11:41 PM.
Posted 14 April 2006 - 11:45 PM
Posted 15 April 2006 - 07:59 AM
I have heard that 100kgs is around 0.25 of a second.
Can anyone tell me what is the general rule of thumb for rpm over the finish line? Are you meant to cross at peak power? Or higher? Thoughts?
Edited by Struggler, 15 April 2006 - 08:06 AM.
Posted 14 September 2006 - 09:22 PM
Posted 28 September 2006 - 07:26 PM
Posted 28 September 2006 - 07:32 PM
Posted 28 September 2006 - 07:51 PM
Posted 28 September 2006 - 10:39 PM
What are those important details to get right in your opinon?Like you said, its all in the combination. If you get all the details right the rest will take care of itself.
Posted 28 September 2006 - 11:00 PM
Posted 28 September 2006 - 11:56 PM
Posted 29 September 2006 - 05:10 PM
200rwkw isn't too bad, depending on the dyno, trans, converter etc that could be a real grunter.What are those important details to get right in your opinon?Like you said, its all in the combination. If you get all the details right the rest will take care of itself.
I was fairly disappointed when my 308/333 only made 200rwkw with what I thought was a reasonable combination. I'm nothing close to being made of money, but I might be able to make some modifications in key, big gain, areas.
Posted 29 September 2006 - 11:31 PM
Edited by ALX76, 29 September 2006 - 11:31 PM.
Posted 30 September 2006 - 05:47 PM
Like I said it was more than fine tuning.......^ you picked up 2 seconds from fine tuning things, well done.
Posted 02 October 2006 - 06:12 PM
Posted 03 October 2006 - 02:47 AM
Posted 03 October 2006 - 04:11 PM
Posted 04 October 2006 - 12:01 AM
Posted 04 October 2006 - 10:15 AM
The 11.5 was run with my old converter, about 3800rpm.Thanks Struggler,
With your timeslips your 11.534 @118mph is almost identical to my 11.611 @116mph, (I haven't posted it yet) What converter did you run that night? and what did you change too when you ran 11.0??
Posted 05 October 2006 - 07:15 PM
Posted 05 October 2006 - 09:36 PM
