haydens supercharged 78 UC
261 replies to this topic
#26 _BlownUC202_
_BlownUC202_
Posted 12 July 2010 - 10:32 PM
Nice work mate cant wait til i finish mine we should go up against each other i recon ill give you a run for your money ha ha.
#27 _V6 UC_
_V6 UC_
Posted 12 July 2010 - 11:32 PM
yeah man definetly keem. That was on street tyres with the stock VN stall,m only stalls to around 1900, you can hear my tyres screech cos im loading it up so hard haha, i was planting it foot to the floor(street tyres) and it was hooking up 100% definetly more in it with a decent launch, i was only getting 1.9-2.0 60ft times, should be able to get that down to 1.7ish
#28 _slr253_
_slr253_
Posted 14 July 2010 - 11:42 PM
Great build. Love the driveline combo. Giving me ideas now...
Did you have to mod the trans tunnel for the T700?
Cheers,
Brett
#29 _V6 UC_
_V6 UC_
Posted 22 July 2010 - 11:13 PM
no mods to the tunnel, fits like a finger in a bum :)
#30 _V6 UC_
_V6 UC_
Posted 24 July 2010 - 12:13 PM
bit of an update, took my car over warwick pits on wednesday to get the conversion signed off(engineering, mod application done etc.) they were happy with the conversion but i got pinned for the battery box in the boot which was the shitty plastic type. Apparently it has to be sealed inside the car and vented to the outside unless u have a sealed battery. also got done for having my surge tank fuel lines to close to the exhaust.
It Was pretty funny when the inspector took it for a drive, we were cruisin along at about 30-40 then he dropped it back to first and planted it, arse end stepped out a bit lol, guy looks at me n goes o yeah, she got some balls ay, haha. He had a bit of a winge cos its sposed to be stock but was ok about it.
I made a battery box up at work out of ali and some stainless heat shields for the fuel lines, heres a couple pics, i didnt realise how bad having the battery vented inside the boot wwas, the corrosion around the bottom of the box is pretty bad, lucky il be stripping it all back out in a couple weeks to get it ready for paint.
punching holes to run the leads thru
#31 _V6 UC_
_V6 UC_
Posted 30 July 2010 - 11:32 PM
i started stripping the torrie down tonite, removed the front end/door trims/chrome trims/badges and a few other little things. Got a little bit of repair work to do on the front drivers side, looks like its had a bit of a whack in the past, the headlight surround is a bit mangled. Gotta power thru, ive got till the end of august to get as much as i can done while my uncle is on holidays and i have access to his garage, hopefully get it to the stage where its ready to be blocked and painted.
will keep yas posted with how i go, im no panel beater btw lol, just thought id give it a go, my cousins gonna give me a bit of a hand aswell
#32 _BlownUC202_
_BlownUC202_
Posted 31 July 2010 - 08:22 AM
Looks like that right hand headlight mount is pretty bad i might have a good one on my wreck ill have a look when i get home on monday if your interested
#33 _V6 UC_
_V6 UC_
Posted 31 July 2010 - 11:47 AM
yeah mate definetly, thanks
#34 _TJ308_
_TJ308_
Posted 31 July 2010 - 07:08 PM
awsome car and wow its quick!
#35 _BlownUC202_
_BlownUC202_
Posted 01 August 2010 - 08:26 AM
No worrys ill have a look at it tomorrow and let you know
#36 _BlownUC202_
_BlownUC202_
Posted 02 August 2010 - 03:56 PM
I had a look at my wreck it looks ok ill pm you my details and you can come have a look.
#37 _V6 UC_
_V6 UC_
Posted 03 August 2010 - 10:31 PM
did a bit more work over the weekend. After taking the rear bumper off i found the damage to be a little worse than i thought it was, previous owner has put another tail light/bumper on to hide the damage. Im borrowing my uncles mig so i can do repairs properly, gonna try get it out with a slide hammer and ratcheting off another vehicle. Also gonna fill aerial hole and badge holes
#38 _BlownUC202_
_BlownUC202_
Posted 10 August 2010 - 09:44 PM
Hey mate did you get the headlight surround was it ok?
#39 _V6 UC_
_V6 UC_
Posted 11 August 2010 - 10:58 PM
yep got it, thanks for that, havent been on here in a while been working long hours at work then getting stuck into the rear end damage on the torrie when i get home. Il be doing the headlight next week as i have the week off work :) coming along slowly, finding a bit of bog here n there with the wire wheel but nothing major
#40 micklx
micklx
  • 1,785 posts
Posted 11 August 2010 - 11:09 PM
Those wheels look good, and a great time down the 1/4, well done !
#41 TerrA LX
Posted 11 August 2010 - 11:18 PM
Fantastic conversion, well done.
#42 _mick74lh_
_mick74lh_
Posted 11 August 2010 - 11:40 PM
Mate thats awesome. Love the job you've done. The VE chasers really suit it.
Good luck pulling the dent out of the rear.
#43 _V6 UC_
_V6 UC_
Posted 17 August 2010 - 11:48 AM
cheers for the comments guys
bit of an update, have reparied the damage at the rear end now, the whole right hand side was kinked in about 25 mm starting from just under the number plate. Using a bit of 75x50 rhs chocked across the wheel arches in the boot and a bottle jack, i managed to push it all out fairly straight. pulled the dent out along the back there too by welding various plates/loops etc onto it and pulling using a ratchet strap off my ute.
some pics
a skim off filler to make it all pretty
iv now pulled all the doors off and have started blocking down. i also got hold of a new headlight surround off blownUC202s donor car, which is getting blasted atm along with some other stuff and will be fitted as soon as i get it back. picking up the rest of my paint this arvo :D will be spraying this weekend hopefully.
Heres some pics as it stands now and the boot which had to be bare metalled due to poor prep work on its last respray by previous owner and the paint has started to crack everywhere( tops of all quarter panels and roof also cracking)
its not warped around the weld, just the lighting is poor cos i got the fluro around the back of the car
all badge holes and the aerial hole have also been filled with the mig
#44 _BlownUC202_
_BlownUC202_
Posted 17 August 2010 - 04:45 PM
If theres any other parts you need mate let me know i got heaps of uc parts.
#45 _V6 UC_
_V6 UC_
Posted 17 August 2010 - 06:33 PM
wat about SLE mirrors? the gts style ones, rare spares want 300 a pair! also chasing the little bit of chrome trim for the passenger side mirror, or any chrome tail light surround trim, mines scratched to shit
Edited by V6 UC, 17 August 2010 - 06:37 PM.
#46 _BlownUC202_
_BlownUC202_
Posted 17 August 2010 - 07:24 PM
ok i think i keeped the chrome trim off my old sl wreck ill have a look tomorrow for you dunno about the mirrors ill look tomorrow i got a few mirrors around.
Edited by BlownUC202, 17 August 2010 - 07:25 PM.
#47 _V6 UC_
_V6 UC_
Posted 17 August 2010 - 10:06 PM
also after a torana ashtray or SL is ok
#48 _BlownUC202_
_BlownUC202_
Posted 17 August 2010 - 11:47 PM
probally got one of those 2 will let you know tomorrow.
#49 _BlownUC202_
_BlownUC202_
Posted 18 August 2010 - 11:45 AM
Ok ive got what looks like a full set of chrome trim for a uc. One drivers side gts style mirror but its not all chrome just the base is the mirror surround is painted. I couldnt find a sl ash tray ive only got a sunbird one.
#50 _V6 UC_
_V6 UC_
Posted 18 August 2010 - 01:56 PM
wats the trim for the boot like?
