haydens supercharged 78 UC
261 replies to this topic
#126 Neils LX
Neils LX
  • 2,074 posts
  • Name:a
Posted 21 May 2012 - 08:13 AM
Cool, I wanted to do that aswell, are u running a bcm so the odometer/trip etc. Work?? I want the big tacho, not interested in running another external gauge
Thats the pic out of my old ute, The UC that i seen was running a Lev 3 dash from a VN all you would have to do is add a patch harness from a Calais.Distance to empty runs off the computer not bcm afaik.
#127 _judgelj_
_judgelj_
Posted 21 May 2012 - 10:39 AM
I've installed heaps of central locking, but not power windows. couldn't imagine them being that hard...
#128 _V6 UC_
_V6 UC_
Posted 15 June 2012 - 07:14 PM
Got a couple hours spare yesdy arvo. The fuel filter after pump had minimal shit in it, which I think is a good sign. I also fitted the fmhe, had to cut a lip off the rad support, Which left 2 skins apart (the lip had spot welds) so I just put a few stitches with the tig along it. I nutserted the top and bottom rails so removal is easy if needed. I'm sitting on the plane going back to work now for 4 weeks then going Europe for 4 weeks after that so progress is going to be slow, which sucks as I've got everything ready to go, including the link ecu. Probably won't make powercruise.
Still trying to come up with interior ideas. Something like this is more than likely instore for the doortrims but maybe not as pointy looking
And I might cut the headrests off the front seats
#129 _V6 UC_
_V6 UC_
Posted 22 June 2012 - 04:28 PM
My uncles going to look at a vs statesman interior on the weekend as I'm still away at work. Goin to dummy it up n see wat it looks like, the front sets have a nice shape with a bit of sidewall to hold u in. I'm also tryin to figure out wat to do with the dash the odometer has shit itself again and fuel
Gauge doesn't work with cell. The haltech racepack seems like an easy solution, has everything I want but a digital dash in a Torana/street car?? Do you think it will look out of place or what? Opinions please :-)
http://www.hioctaner...h-racepak-dash/
#130 _V6 UC_
_V6 UC_
Posted 30 June 2012 - 12:47 AM
been getting a bit done on the car lately. i chucked my job in, vought a new camera today so time for an update with some nice pics, ur probly all getting sick of the iphone quality. i decided to remove the fan box in the bay the heater underdash, vents the whole lot. Takes up so much bloody room.
now il have space to relocate the relays in the bay under there, along with the a few new bits and pieces. I also relocated the carbon cannister to under the drivers guard, suprising how much rooms under there, the horns and w2a pump will also be joining it. Im going to stall on the interior now and focus on getting the new ecu in, new wiring and ecu all sorted, extra switches for nitrous, AIM MXL digital dash or the haltech, still undecided.
That way i can move switches around when we build the console and make it all neat and trimmed in. heres a few pics of what ive been upto.
nitrous bottle installed, il be building a false floor around it, the heights going to be inline with the top of the bracket ive welded onto the cell.
the spaghetti under the dash, including alarm that spacs out everytime you open a door/boot glovebox haha, randomly started doing it after last tune. Wires tapped into wires upon wires.
cooler lines have been mounted to rad support, just got to get some more fittings to run braid off plastic pump.
testing out my new bench grinder\polishing setup, come up ok, i didnt spend much time on it, was in pretty average condition to start with.
The bay with the fan removed, im going to bolt a plate over it for now, WHEN engine lets go, lol il smooth bay and do it all properly. But now il have room for ls1 coils and oil catch can
#131 _V6 UC_
_V6 UC_
Posted 29 August 2012 - 10:37 PM
update time, been in europe 4 weeks but getting a bit more done now im back and not doing fifo work anymore/
-12 fittings welded on, spent a bit of time polishing these up nice. They had some deep scratches and were in a flat #2 finish when i bought them. Now full #8 mirror finish.
more port work on the blower, ive removed the "bridge" this normally seals air off to the factory intake manifolds square intake, Now that im going to be raunning a w2a core under it i need as much surface area as possible so ive opened it all up and ported the intake manifold to match.
cooler plate pulled down, n cleaned up, now resealed.
Since im going to be running ls1 coilpacks i wont be needing these bolt bosses anymore. Plenty hours ahead!
basic shaping
only had 150grit sandpaper, not course enough to get my lines set n straight. Yes im a fussy prick :)
On another note i pulled wiring loom out and also discovered that the e85 in my lines has eaten thru the permaseal on the fittings in my fuel rails....
you can see the green coming thru, the e85 has been in there since january, im going to assume my injectors are gummed up aswell, i might also cut down a piece of rubber hose inline and have a look inside. Lucky there is very minimal rubber hose maybe 180mm total on supply side
#132 _V6 UC_
_V6 UC_
Posted 06 September 2012 - 10:09 PM
in my quest to produce a good looking v6 bay, much dattomans disgust(not that he would even come into my thread) haha, ive finished the tensioned, plans are to polish and relocate the alt to powersteering pump pos, this will fully expose the charger. The plan is to make it look as little commy v6 as possible.
#133 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 06 September 2012 - 11:16 PM
nice polishing job. amazing what you can do with some patience!
#134 FLY_LX
FLY_LX
  • 183 posts
  • Car:LX sedan
Posted 14 September 2012 - 08:09 PM
nice work.
do you recon you'll have any problems with boost feeding into bearings?
#135 _V6 UC_
_V6 UC_
Posted 20 September 2012 - 12:09 AM
The bearings are still sealed. I've read up that the holes are only there to press the bearings out if a rebuild is needed. 15 odd psi shouldn't worry them at all.
Fitted my wide band sensor bung tonight.
#136 _V6 UC_
_V6 UC_
Posted 30 September 2012 - 10:08 PM
Chopped my centre up again. Fitted wideband display into the centre and glassed an Ali plate in place to cover existing heater control hole. Also fitted nitrous/purge solenoid arm switch and purge button to the right and over the other side thermo fan and bottle warmer switches. Left some room for warning lights
#137 Heath
  • 18,378 posts
Posted 03 October 2012 - 10:14 AM
Loving this.
#138 _V6 UC_
_V6 UC_
Posted 03 October 2012 - 07:16 PM
Cheers Heath. Atleast a few ppl seem interested
#139 _DomDom_
_DomDom_
Posted 03 October 2012 - 11:00 PM
I love this build. Top job. It's great to see UC's being utilized. They are a very modern looking car.
#140 _alchemist_
_alchemist_
Posted 04 October 2012 - 01:51 AM
Hey dude great work, I've been following your thread for a while now.
Shouldn't be long before I get a build thread up on my UC, I'm in Perth too.
#141 _tyre fryer_
_tyre fryer_
Posted 04 October 2012 - 12:26 PM
Love this build buddy, best of all is the amount of work you do yourself!
Keep it up, there's more people watching than you think. haha.
#142 fatslr
fatslr
  • 1,247 posts
  • Name:Garth
Posted 04 October 2012 - 03:02 PM
Hey Hayden
Looking good mate nice work on the dash and mount brackets are you hoping to run Nostalgia drags at the end of month ?
Garth
#143 _V6 UC_
_V6 UC_
Posted 04 October 2012 - 04:34 PM
That was my aim but I'm not going to make it now. Also the nostalgia drags is andra rules so if go any quicker than last time I'm going to need a ss lic/ loop/cage / get booted out etc. few guys earlier this yr got booted if u remember. Wed nights on the other hand I'm free to run till the 10.5 barrier
#144 _V6 UC_
_V6 UC_
Posted 12 October 2012 - 11:47 PM
Started making up some catch cans this arvo. Mines going to have -12s n a mates -8. I've put a -4 on mine to dummy up a return to intake to keep the boys in blue happy, even tho it's going to have a filter breathing to atmosphere. I went to put the second -12 fitting on n got a stray arc which rooted the thread. Goin to have to get another tommorow.
The gas lense I was using was Probly a bit too big as I was trying to get good gas coverage and a nice clean weld. Shit happens.
Finished product
I also scored one of these dirt cheap. It's only had dyno work for around 4-5 hours
#145 _A9XOSS_
_A9XOSS_
Posted 13 October 2012 - 04:20 PM
wow, your doing a great job there. like your engineering/modifing abilty.
#146 _UCV80_
_UCV80_
Posted 14 October 2012 - 06:38 AM
Good work on the polishing, came up great. The engine bay will look trick. I like that dash alot too.
#147 _V6 UC_
_V6 UC_
Posted 14 October 2012 - 03:18 PM
Yeah kept it black for now. Might change it to oyster leather if it looks wrong after we do interior. I got my catch can/ w2a resevoir/water pump fitted last night and an just plumbing everything up n making braided lines. Getting closer :-)
#148 _V6 UC_
_V6 UC_
Posted 15 October 2012 - 12:03 AM
progress shot
#149 _Emu_
_Emu_
Posted 15 October 2012 - 09:23 AM
Cool work bloke - nice car and awesome ET's.
What fifo work were you doing? What are you doing now? You should be doing fabrication work....well done. :)
#150 _V6 UC_
_V6 UC_
Posted 15 October 2012 - 10:29 AM
Was working dido as a sheet metal worker which is my trade then was fifo for a bit as a boily. I'm working back in Malaga now as a welder/boily. It's good to be able to go home every night and get a bit done on the car.
