Fastest Holden 6 Powered Sedan
#276
_gmlj6_
Posted 03 May 2012 - 10:04 PM
#277
_Bad Blood_
Posted 04 May 2012 - 08:09 PM
#278
_gmlj6_
Posted 12 July 2012 - 10:22 PM
#279
_ljxu1torana_
Posted 12 July 2012 - 11:21 PM
my copper head gasket on my turbo 186 is 1.6mm.going by memory that the copper head gaskets are available in 1mm.i think 1.2mm and 1.6mm.acl dont make copper head gaskets.they gave me nason phone number in brisbane who makes the copper head gaskets.when brought mine about 2 years ago it was about $200.thanks jason.Damn this motor is so timing sensitive. small chamber 9 port, flat tops and a n/a cam that builds a bunch of cyilinder preasure by its self without nitrous. down to 16 deg total on nitrous and pump fuel. does anyone know the thickness of the tw0 types of acl composite head gaskets are for 202s. the only info they have are their copper ones and they are 40 thou and 63 thou?
#280
Posted 13 July 2012 - 08:10 AM
http://www.aclperfor...pperGaskets.htm
#281
_gmlj6_
Posted 13 July 2012 - 07:35 PM
#282
Posted 13 July 2012 - 07:39 PM
_gmlj6_
Posted 13 July 2012 - 07:58 PM
#284
_CraigA_
Posted 13 July 2012 - 09:16 PM
#285
_ljxu1torana_
Posted 14 July 2012 - 12:04 AM
what was his times and mph.
#286
Posted 14 July 2012 - 08:10 AM
#287
_gmlj6_
Posted 14 July 2012 - 01:23 PM
#288
_NYS 71_
Posted 20 July 2012 - 03:47 PM
hey pal if you don't mind just wondering what the cam specs, converter size and compression your running in your weopon.that car has gone 1.61 60ft 7.2 1/8th and 11.57 114. with 4.11s and a cold low bottle. is the vid we changed to 3.45s and had 950psi in a full bottle. the time boards werent working right but its deffenetly picked up top end. id think it would have gone 116mph easy.
#289
_gmlj6_
Posted 22 July 2012 - 08:34 PM
in. 248@50
ex.248@50
in.lift.334
ex.lift.334
108 lsa
1.5 ratio rocker on intake and 1.6 on the exhaust.
the converter is a tce 8 inch 3500 stall speed and flairs to about 4500 on nitrous.
about 11.5.1 commpression ratio.
the cam is designed for a n/a motor and probably not the best for nitrous but we are only shooting 100 hp at the moment so it loves it.
#290
Posted 13 August 2012 - 07:31 PM
#291
Posted 14 August 2012 - 12:59 PM
Is this a stick car or bleeder?
#292
Posted 14 August 2012 - 06:25 PM
That's good mph.
stick of course, runs a t5 and hilux diff.
#293
_STRAIGHTLINEMICK_
Posted 14 August 2012 - 08:16 PM
#294
_holset444_
Posted 15 August 2012 - 08:17 PM
#295
_LJ355_
Posted 15 August 2012 - 08:46 PM
#296
_ChevLX_77_
Posted 15 August 2012 - 10:46 PM
does anyone know anymore about it??
#297
_V6 UC_
Posted 16 August 2012 - 12:33 AM
#298
Posted 16 August 2012 - 07:39 AM
#299
_holset444_
Posted 16 August 2012 - 07:50 PM
#300
Posted 17 August 2012 - 07:39 AM
How about an 8.8 second for quarter mile out of a 202
that is so impressive
Bing (1)
