Fastest Holden 6 Powered Sedan
461 replies to this topic
#176 _Bad Blood_
_Bad Blood_
Posted 09 February 2011 - 09:50 PM
say again
what are you running n/a bad blood?
#177 _gmlj6_
_gmlj6_
Posted 10 February 2011 - 07:09 PM
what times does your car run without nitrous also can u give some details on your set up?
#178 _Bad Blood_
_Bad Blood_
Posted 10 February 2011 - 10:17 PM
Best ET was 13.1 @101mph but more reliable around 13.4sec, 4.44 diff ,trimatic, 3X2in SU,s 202 blue mtr High comp Head(12 port head off a 173 blue mtr with roller rockers)bottom end standard not even balanced flat top pistons crow solid cam not sure of the grind Ive got it some where if u want it I could find it. Did you want details on the nos set up?
Edited by Bad Blood, 10 February 2011 - 10:19 PM.
#179 _ChevLX_77_
_ChevLX_77_
Posted 11 February 2011 - 08:03 PM
Interesting as i have only gotten 13.5 N/A with glide and 4:11 nine inch. 500 two barrel holley
#180 _gmlj6_
_gmlj6_
Posted 11 February 2011 - 08:39 PM
so what did you run on nitrous lxchev?
bad blood,what size stall and what does in flair to on gas? also what mph are u running on gas
#181 _Bomber Watson_
Posted 11 February 2011 - 10:17 PM
IR would be the cause to that difference, most of your fuel is probably dropping out and going where you dont want it with your setup.
#182 _Bad Blood_
_Bad Blood_
Posted 12 February 2011 - 06:25 PM
It stalls to about 3000 rpm but I get a quicker 60ft & ET when I stall it to about 2500-2800rpm. I don't rev it past 6000 between gears but its doing about 6500 at 110mph over the finish line.
#183 _ChevLX_77_
_ChevLX_77_
Posted 12 February 2011 - 11:39 PM
I have never raced the the car on nitrous, But its previous best was 10.4 with a 100hp shot in it
13.5 was straight off trailer ie still big jets for nitrous etc.
Next time the gas will be turned on
#184 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 13 February 2011 - 06:11 PM
that really makes me wanna put an auto and a big sniff of gas on mine....
have you got a video chevlx or bad blood?
chev lx the gear ratios would have been way out with the glide when aspirated correct?
#185 _ChevLX_77_
_ChevLX_77_
Posted 13 February 2011 - 07:03 PM
Not sure to be honest i havent used the car a great deal ( 4 passes and a burnout comp)
Its just been respayed etc so ill be getting it out some more
#186 _gmlj6_
_gmlj6_
Posted 13 February 2011 - 09:08 PM
so what was the old set up?
#187 warrenm
warrenm
  • 2,130 posts
  • Car:1972 LJ Torana
Posted 14 February 2011 - 08:25 AM
Don't do it greens nice, only push bikes have 2 pedals.:wedgie:
#188 rodomo
  • 18,064 posts
Posted 14 February 2011 - 08:12 PM
:iagree:
#189 _gmlj6_
_gmlj6_
Posted 14 February 2011 - 08:47 PM
would u be dissapointed to hear about the doorslammer in the states that ran 5.88 with a auto and converter? two pedals FTW
#190 _ChevLX_77_
_ChevLX_77_
Posted 14 February 2011 - 08:51 PM
Fast Pushbikes!!!
Old setup is current setup....
#191 rodomo
  • 18,064 posts
Posted 14 February 2011 - 08:53 PM
US doesn't count, sorry. :)
#192 micklx
micklx
  • 1,785 posts
Posted 14 February 2011 - 09:41 PM
An auto with a big stally sure would help the Thunderbolt Grease Slapper harness all those ponies Rob.
#193 _gmlj6_
_gmlj6_
Posted 14 February 2011 - 09:43 PM
Fast Pushbikes!!!
so you went 13.5 n/a then 10.4 on a hundred shot?
#194 _ChevLX_77_
_ChevLX_77_
Posted 15 February 2011 - 07:28 PM
i went 13.5 the only time i ever raced the car. That was with the bottle turned off
The guy i bought the car off, has run nemerous 10.4's with a 100 pill in it.
Now i have driven the car and have a general feel i will turn the bottle back on and have some fun!!
#195 _gmlj6_
_gmlj6_
Posted 15 February 2011 - 07:57 PM
that thing must be built for nitrous if it picks up that much.
#196 _ChevLX_77_
_ChevLX_77_
Posted 16 February 2011 - 10:24 PM
Or he could really drive it.......
#197 bluea9x
bluea9x
  • 437 posts
  • Name:King Loz
  • Car:1976 L31 SS
Posted 18 February 2011 - 08:46 PM
This is the old girl in the old paint scheme good luck with it cal
#198 _skidb_
_skidb_
Posted 24 February 2011 - 08:05 PM
im a bit out of my leage here best iv done is a 13.70 on a circuit racing setup(very stiff)tripple webbers wayne jones cam aussie 4 spd 3.90 bango and street tyres, 179 big block lol :nada:
#199 Heath
  • 18,403 posts
Posted 24 February 2011 - 10:25 PM
Don't lose sight of where it all fits in though. 13.7 isn't slow in any way, shape or form. I want to build hot Holden 6s and post some alright times but I won't consider myself a drag racer. If drag racing is the only application of the car then it's a different story and it's fair to expect a bit more from it.
#200 _skidb_
_skidb_
Posted 25 February 2011 - 05:57 PM
:) cheers heath
