2 questions.... Does phosphoric acid (DEOX) that you use to etch the panel before the epoxy effect bog at all? IE should I try avoid the filler when I prep the bare steel?
And I wanna give wet on wet a try (with the epoxy and hi-fill) It just says wait 30mins before topcoating... so is that all? just wait 30mins the spray it with the hi-fill? I dont have to do anything else special...
Oh ok I lied I got 3 questions... In the TDS for the epoxy it says use a 1.3mm or 1.5mm tip... I have both sizes so which one should I use and why?
Here's a few progress pics anyway.
