Any panel/paint Expert wanna be my MSN mentor?
#76
_yldlj_
Posted 11 January 2010 - 08:01 PM
#77
_yldlj_
Posted 11 January 2010 - 08:09 PM
#78
_beergut_
Posted 11 January 2010 - 08:41 PM
by that
i mean fill the dent then "add" a little more all over the repaired area to cover what your about to sand out
and yeah forgot to say sand in a cross hatch patten first off
#79
Posted 11 January 2010 - 08:43 PM
There may be highs around it or maybe the repair is deeper than you think.
#80
_Viper_
Posted 11 January 2010 - 09:54 PM
#81
_yldlj_
Posted 11 January 2010 - 11:04 PM
#82
Posted 12 January 2010 - 07:40 AM
#83
_Viper_
Posted 12 January 2010 - 12:42 PM
Also if you sand through the primer and a little bit of filler is showing do I have to spot prime that? or is fine to paint straight over it?
#84
Posted 12 January 2010 - 12:56 PM
Yea I usually guide coat the filler, ok thanks guys... ill see how I go...
all repairs should be primed.
#85
Posted 12 January 2010 - 01:52 PM
#86
_yldlj_
Posted 12 January 2010 - 07:47 PM
#87
_yldlj_
Posted 12 January 2010 - 08:04 PM
Edited by yldlj, 12 January 2010 - 08:05 PM.
#88
_Viper_
Posted 13 January 2010 - 12:26 AM
Strip to metal
Panel beat as best I can if needed
deox
prepsol
Epoxy
Block epoxy with 180 to find the highs/lows (dont block it completely flat, just enough to see the lows)
fill with the thicker filler (K&H Kahfill)
Guide and block with 80
Prepsol
Hi-fill
dryblock with 180
Fill lows with K&H Pedigree
Block with 180
Cry cos somehow all the edges of the filler have lows next to them even tho I filled right past where the low was (we talked about this earlier)
Fill and block again
Yay all flat.
Guidecoat
Sand with the orbital with interface pad and 320
Guidecoat
Sand with the orbital with interface pad and 400
Guidecoat
Wet block with 600
Spot prime bare metal and filler showing thru (this is the bit I was talking about)
Ok so yea thats where Im at so far.... My friend whos a apprentice spray painter said at work and at tafe they just use some Etch primer in a can to spot prime the bare metal spots??? is that right? using a pressure pack would be sooo much easier...
Am I supposed to mask the rest of the panel when I spot prime?
And then when I have spot primed do I just block it with 600wet? or (just read ur last post) you reakon just leave it aint paint over the small bits of metal/filler showing?
#89
_Viper_
Posted 13 January 2010 - 03:57 PM
Shit... so I think back and I never did specify 2-pac to him so rang him up to check and he says yea he only does Acrylic! and cant give a refund on mixed paint only on the clear (which is fair enough) Omg feel so stupid i didnt specify2-pac to him :/
So anyone want some cheap Cherry black 2-pac? lol
#90
_2runa_
Posted 13 January 2010 - 04:35 PM
Now i'm confused...... didn't you want 2-pac and now your selling it..... Clint the paint fumes must be getting to youOmg feel so stupid i didnt specify2-pac to him :/
#91
_Viper_
Posted 13 January 2010 - 05:44 PM
#92
_beergut_
Posted 13 January 2010 - 05:56 PM
aycrlic is easier for first timers/backyard jobs anyway
but i will take it off your hands if the price and funds come together
pm me dude
#93
Posted 13 January 2010 - 07:18 PM
Probably why Viper wants to be rid of it.
_yldlj_
Posted 13 January 2010 - 11:00 PM
#95
_Viper_
Posted 20 January 2010 - 05:24 PM
I did it with the primer as well but I thought it was just how the primer was and cos its thicker... but when Im spraying its not landing on the panel as a fine mist... well not like superfine like id expect its more chunky... I should have taken a pic after the 1st coat as you could see it really well.. now it just looks like really bad orange peal...
So any ideas? I was putting it on fairly wet.... as wet as id dare go anyway... too much pressure? not enough? etc? i used the tip that was recommended (1.3) and the correct thinning ratios...
Edited by Viper, 20 January 2010 - 05:38 PM.
#96
Posted 20 January 2010 - 06:38 PM
If its hot try a slower reducer....make sure your using the correct reducers.
Are we talking the base or clear here?
#97
Posted 20 January 2010 - 08:10 PM
#98
_gen3torrie_
Posted 20 January 2010 - 08:47 PM
#99
_yldlj_
Posted 20 January 2010 - 09:02 PM
#100
_Viper_
Posted 21 January 2010 - 09:05 AM
And yea I was hoping to have it ready for motorvation.... but obviously didnt make it...
