URGENT - Help Removing Original Steering Wheel
_markbeath_
Posted 19 December 2009 - 04:29 PM
Mark Beath
_sstorana_
Posted 19 December 2009 - 05:31 PM
Hi all im removing my original steering wheel our of my LX and i dont want to damage or brake anything. I have undone the 2 screws at the back of the wheel and removed the rubber cover. I have undone the nut and before i go any further, i wanna make sure theres nothing left to remove.
Mark Beath
The easiest way to remove you steering wheel is with a steering wheel puller.
These are available from most auto shops
Mick
_Woodsy_
Posted 19 December 2009 - 05:49 PM
_markbeath_
Posted 19 December 2009 - 06:09 PM
_markbeath_
Posted 19 December 2009 - 06:41 PM
Posted 19 December 2009 - 09:23 PM
Posted 19 December 2009 - 11:52 PM
Whilst driving, look at the spokes compared to the backdrop (dash?)
E.g r/h spoke is lined up with the 120kph mark on you speedo or something.
Pull over, put the wheel in the position it was whilst driving and from there, re-align the wheel.
Check it on the road again and re-adjust if neccessary before you tighten the nut with a tool.
Posted 20 December 2009 - 08:58 AM
Just loosten it off a few turns.
Posted 20 December 2009 - 11:15 AM
Posted 20 December 2009 - 06:11 PM
A puller is a far better way of doing it as far as I'm concerned, but if you use the hammer pay close attention to the above so you don't wreck the collapsible column.. with both knees behind the wheel with as much tension as you can give it...
_beergut_
Posted 13 January 2010 - 10:03 PM
never hit the nut on the colum you'll destroy it
Posted 13 January 2010 - 10:23 PM
Posted 13 January 2010 - 10:30 PM
Pull on the steering wheel as hard as you can.
Headbutt the nut.
Posted 14 January 2010 - 05:18 AM
It does sound like a very bad idea!would not advise hitting your nuts with a hammer, ever.
