Fixing my brothers UC hatch
#701 _dirtbag_
Posted 28 April 2010 - 08:35 AM
Well here's a little update.
I got the tank straps mounted. They'll have rubber behind them once they're painted, as I like the look of it having a black border.
Here's a pic of my old 4 door showing the look I'm going for.
Next job was to rip the steering arms out to send them away to get the tie rod holes reamed to suit the new power steering rack.
It sure is a crap design when you have to remove the calipers and rotors just to get the steering arms off, but that's life : )
I even gave the arms a hit with the wire wheel, as they were a tad crusty.
With the motor and box coming back out, I had to undo all the wiring and what not. Not too hard I guess, but it takes a while shoe horning all this stuff back in : )
I'll finish a few things in here to get it paint ready, but might still have to put the motor back in to check for sump clearance to clear the power steering.
The last thing done before pulling the motor and box out was finalising the clutch stuff. We had to find a good place to let the hydraulic line go through the tunnel to the slave cylinder, and also find a good place for the reservoir. I was originally going to put it behind the drivers side air vent, but my brother wants all vents to work, so it's now on the firewall. Held on with nutserts of course : )
The fluid line will run through the hole under the reservoir into the pedal/master cylinder. It wont be too obvious here, as it's lower than the engine covers.
Because I reskinned the whole top of the chassis rails, where I bored the holes for the intake pipe left a gap showing between the two layers. To stop gunk going in there I sikaflexed the gap up.
It's not often you have to do bodywork on a dash top, but because this dash was removed from another car and needed some rust repairs, it also needs a bit of filler to get it looking good.
All the stuff is now ready to get sent away for HPC coating.
My brother bought new fuel rails and regulator, which showed up yesterday. Now it can have a return line.
Rails look nice and shiny : )
#702 _Kush_
Posted 28 April 2010 - 11:29 AM
#703 _sjohnst7_
Posted 28 April 2010 - 05:24 PM
Here: http://www.gmh-toran...topic=1369&st=0
Another huge bundle of pages to read!
#704 _dirtbag_
Posted 28 April 2010 - 05:44 PM
With the motor and wiring back out and accessible I can finally put all the wires for the oil and temp senders inside the main harness, as they look scraggly hanging about.
After cutting the harness open, stuffing the 4 wires inside and taping it all back up again it looked like this.
Time to start on the new fuel rails. The holes where the injectors go were too sharp on the corners, so I had to take the edge off with a countersinking tool.
After lots of patience and rubber grease, I finally got the new rails on.
The braided line that came with the rails was way too long, unfortunately, so I marked where I had to cut it. I hate braided hose. It's the devils work : )
Plus I decided it would be easier to go and get all new fittings for the rails, as the 90 degree ones that came with them just didn't work.
After finally getting the fitting back on and all hooked up it looked pretty good.
I bought new barbs for the in and return line.
I knew the engine covers weren't going to fit now as the crossover pipe has moved, so I went to fit the engine cover mounts, only to find they didn't fit anymore as the new fuel rail mounting bolts were in the way. To fix it I straightened the 90 degree bend in the mounting plates and re folded them in a slightly different spot so they'd clear the fuel rail mounting bolts. Just another little unseen problem in a sea of unseen problems : )
The one on the left has had the tabs bent in a slightly different spot. It's about 2mm difference, but enough to make them actually fit on.
Here it's obvious why the cover doesn't fit anymore. It's also obvious where the old crossover pipe used to be, as now there's a big gap that needs fibreglassing up.
Here's the new crossover pipe area cut into the cover so it sits on properly, and my sexy hand is pointing to where I need to glass up.
Very pretty : )
The dash top is now ready for primer. Fun job that was : )
Time to get to all the tiny imperfections that need to be seen to before the paint prep. There's not too many thankfully, but it's important to fix them now.
The rear panel had a couple of little issues that are now fixed and ready for more primer.
And so it the drivers side rear roof gutter where it was replaced.
These little things seem to take so much time, but they're nearly all done and then some colour can go on. Can't wait.
Tomorrow will hopefully see the main body shell and engine covers ready for their last shot of primer before topcoat. Fingers crossed anyway.
#705
Posted 28 April 2010 - 06:33 PM
#706
Posted 28 April 2010 - 07:18 PM
Looking forward to seeing some colour on it.
Cheers Mick.
#707 _nial8r_
Posted 28 April 2010 - 08:26 PM
#708 _jabba_
Posted 28 April 2010 - 10:48 PM
#709 _BlownUC202_
Posted 29 April 2010 - 10:21 AM
#710 _DomDom_
Posted 29 April 2010 - 05:24 PM
Can you please hurry this build up. I can't wait for you to finish. Ha ha.
What's next?
Just kidding. To think that this only started in December is absolutely amazing.
Keep up the awesome work.
Dom
#711 _dirtbag_
Posted 30 April 2010 - 08:15 AM
Well it's back at a slow stage now where it never looks like anything has been done, but it's a really good stage too. Final prep for paint : )
The rear panel needed a little bit more work so get right, so now it is totally ready for it's last shot of primer.
The drivers side of the car is now all sanded with 240 grit dry paper. That still sounds like rough paper, but it's buttery smooth. You just have to be patient when sanding with the 240 though, as it takes a fair while. There's one bit I want to fix in the door jam, but other than that this side is ready for final primer.
The engine bay is nearly all sanded with 240 as well. Still a bit of the firewall to go yet.
Here's the engine covers with the new fibreglass bits I added cut to shape. They just need a tiny smear of filler and they're finished.
Last this we did yesterday was rip the hatch back off so I could send the hinges away to get HPC coated with the rest of the stuff that got sent the day before.
They should look a bit better next time we see them.
#712 _dirtbag_
Posted 30 April 2010 - 06:23 PM
Today was another day of doing stuff that can't be seen.
I finally finished the filler neck for the windscreen squirters. It sits just behind the drivers side headlight. The lid will be painted, so I don't think it will stand out too much. At least the bottle itself is out of sight.
And I converted all the top front guard mounts to nutserts. Not only because nuterts are awesome and fun, but because the original speednuts are a pain, as they scratch the hell out of the paint when you put them on. And nutserts are awesome : )
Just so you know, this is how the underside of a nutsert ends up after it's squeezed into place.
I also did the filler work on the engine covers where I had to fill the space where the original fuel rail crossover pipe was. The covers are now ready for their final coats of primer before topcoat. I'm also going to smooth the intake manifold. It's got a rough finish with little dots embedded in it. You can see I've sanded one of the intake runners smooth. Only 7 more to go : )
It was the highlight of my day sanding the radiator support panel : )
Note all the little dabs of filler where I've been touching up the little pinholes and what not. The pinholes are so tiny after the filler is sanded you can hardly see it, but if I didn't do it now the finished result would look crap. Nearly done now!!!
The dash and plenum are all done now ready for primer.
I've had the chassis number taped up during all the priming, so it doesn't get full of paint and disappear. I untaped it today and sanded all around it to smooth the edges, but will tape it again until the very last coat of primer.
The headlight buckets and master cylinder are also ready for their final coats of primer before being top coated.
Well the engine bay is finally ready for it's last coats of primer before top coat. It's been a lot of work but once it's coloured in I think the work will have been worth it.
Go on, touch the screen, feel how smooth it is now. Go on : )
Hopefully the weather will be good for the next week so I can get a heap of priming done. I just need to sand the roof and left rear quarter with 240 and the whole shell is ready for it's final primer. Can't wait to see colour!!!!!!!
#713 _Viper_
Posted 30 April 2010 - 07:50 PM
With the nutserts in the guards... don't the usual speednuts allow for abit of adjustment? ie they can move around a little? is there enough movement in just the guard holes? I hope so cos I wanna do this with mine too
#714 _dirtbag_
Posted 30 April 2010 - 08:15 PM
#715
Posted 30 April 2010 - 08:48 PM
#716 _Azza_
Posted 01 May 2010 - 10:20 AM
#717 _nial8r_
Posted 01 May 2010 - 07:38 PM
#718 _red roar_
Posted 01 May 2010 - 08:44 PM
plenty of work in the rubbing.....
#719 _wblje_
Posted 01 May 2010 - 09:58 PM
a, really love my brother and cant do enough for him
b, my brother is paying me heaps to do this
c, i won lotto a while back and have nothing else to do
d, its a guilt thing. me his missus one night to much grog. oh god i hate myself.
answer a,b,c or d
top work there. some awesome dedication
#720 _greenmachine215_
Posted 01 May 2010 - 10:29 PM
I think once its done you should just say Thanks bro for letting me keep this hatch. maybey let him take it for a spin round the block.
Are you in the automotive trade at all or just a keen DIY Man, cos your work could be in elite summernats.
#721 _dirtbag_
Posted 01 May 2010 - 10:40 PM
wblje, it's a combination of a and b. d is funny : )
greenmachine, it sure is tempting to finish it and accidentally move away somewhere with it : )
As for a trade, unfortunately no, I'm self taught. I have worked in a couple of hot rod shops building chassis' and doing big panel work - chop tops, 2 door conversions etc, but there is no trade for that stuff. Sure is fun though : )
#722 _AD_75_
Posted 01 May 2010 - 11:27 PM
could you answer one of the following.
answer a,b,c or d
HAHAH that's gold. specially option d..
Btw tim, loving ya work that engine bay was so smooth i wanted to caress it gently..in a non ghey way of course..
#723 _Viper_
Posted 02 May 2010 - 09:26 AM
#724
Posted 02 May 2010 - 03:23 PM
#725 _dirtbag_
Posted 02 May 2010 - 03:43 PM
Hi Ang. The proper wheels have been taken back off the car, so you'd only have seen one of the old dunger wheels : )
Had me worried though : )
