* * * * * 1 votes
Fixing my brothers UC hatch
1690 replies to this topic
#876 _dirtbag_
_dirtbag_
Posted 31 May 2010 - 03:29 PM
Well today I finally had a chance to check out this power steering rack.
No surprises then when I found out it didn't fit, as Andy (ls2lxhatch) had tried the same thing last week.
I'm not bagging the conversion, it's a great idea, it just isn't built for an LS1.
I first bolted the crossmember to the engine and then tried holding the rack in place to see how far it was out, but that was too hard on my own, so I bolted the rack to the crossmember and used the engine crane to help hold the crossmember in place.
I bolted the crossmember to the left hand engine mount, as I knew that side would fit as it was. I then swung the crossmember up on the drivers side to see how far the engine mount was from lining up.
You can see how far out the engine mount holes are here.
Here's the front of the engine mount and you can also see where the rack mount is touching the sump.
The line running front to back on the sump is how far from the edge it needs to be cut down so the rack mount can fit there. Goodie : )
Unfortunately, under the part of the sump that needs to be removed is where the oil pick up is.
The only way I could see it working was to swap the oil pick up to the other side. It's not finished yet, and I need to get another 90 degree bend, but there's enought there for me to make sure it will all fit. Once I have all the pieces tacked together I'll oxy weld it all up and pressure test it.
Looks like there might be a chance of this working. The rack and crossmember are now all bolted up. Still need to modify the sump again though.
I'll have to cut the tab from the side of the block to give the banjo fitting a bit more room.
Another shot of the banjo fitting and the tab on the block.
I never thought I'd have an LS1 and torana crossmember upside down on my engine crane : )
Thanks again have to go to forum member L32M20 for the loan of the crossmember. Wouldn't be too fun doing all this in the car.
There will be some paint shots soon, I promise.
#877 _torana_umunga74_
_torana_umunga74_
Posted 31 May 2010 - 04:19 PM
love ur work.. CLEARANCE IS FOR PUSSIES!!!
#878 _The Baron_
_The Baron_
Posted 31 May 2010 - 05:40 PM
Time for a dry sump?
#879 _Yella SLuR_
_Yella SLuR_
Posted 31 May 2010 - 05:58 PM
ooooOOOOooooh! shiny bits!! :spoton:
I 2nd "shiny bits".
#880 _dirtbag_
_dirtbag_
Posted 31 May 2010 - 06:00 PM
Thanks Nic :rockon:
Baron, yes, why not. Everything else has been changed : ) hahaha
Hopefully after a bit more cutting and welding on the sump and it will all be good. There seems to be plenty of room there now. Having said that, a dry sump sure would be nice.......
#881 _Yella SLuR_
_Yella SLuR_
Posted 31 May 2010 - 06:02 PM
So what's with the Yella Torrie in your Avtar?
#882 _dirtbag_
_dirtbag_
Posted 31 May 2010 - 06:06 PM
grrrrrrr.....IT'S NOT YELLOW....hahha. It's barbados green. I used to own it a few years ago. I know it's a bit sad putting a car on there I don't have any more, but I didn't think a hilux would be fitting here : )
Anyway, it's a 4/74 LH SLR5000 that I had a tunnel rammed 308, top loader, 9inch, drop tank, full cage and 8 and 10 inch hotwires. It was a great car. I sold it to a guy in canberra, but don't know what happened to it after that?????
#883 _Yella SLuR_
_Yella SLuR_
Posted 31 May 2010 - 06:34 PM
Interesting. Lets not get too hung up on colour, I may be slightly colour blind (everything looks better in Yella).
Wonder if Roy knows? Very interesting. Not many green ones down here that I've seen. Might be a shed dweller.
#884 _eh-buddy_
_eh-buddy_
Posted 31 May 2010 - 06:35 PM
finaly some pics
looks like a fun job tim any more cutting off the sump and it will be its own crank scraper :)
#885 _dirtbag_
_dirtbag_
Posted 31 May 2010 - 07:10 PM
hahaha Paul. That's a great idea : )
#886 76lxhatch
  • 7,208 posts
Posted 31 May 2010 - 08:17 PM
It would be a shame if it didn't all fit, great work and hopefully no further obstacles!
#887 ls2lxhatch
  • 5,332 posts
Posted 01 June 2010 - 02:12 AM
You make fitting the Subaru rack look easy. :)
The factory Camaro oil pan (f-body) is so shallow at the front that crack scraper does not start until the second bank.
It even has a little lump to clear the crank.
#888 _gtsgeoff_
_gtsgeoff_
Posted 05 June 2010 - 04:51 PM
oi dirt bag
I know the colour and the wheels.
and i am your father!
#889 _Kush_
_Kush_
Posted 05 June 2010 - 10:25 PM
Must be cruiza's inside man. :).� but seriously dirtbag, hurry up I wanna see some stuff! I don't know what to do with myself!
Edited by Kush, 05 June 2010 - 10:28 PM.
#890 _DomDom_
_DomDom_
Posted 06 June 2010 - 10:23 AM
oi dirt bag
NOOOOOOOOOOOOOOO!
It can't be true.
#891 _dirtbag_
_dirtbag_
Posted 06 June 2010 - 07:19 PM
Hahahaha. You guys are awesome :bowdown:
Geoff, yes, I'm sure you know the colour and wheels, but I also know you like it rough and manly :rockon: I still remember the day I painted Kat's HZ and I was hammered on paint fumes and you were writing stuff on the ground in the overspray and freaking me out hahahahaha.
Sorry Kush, I know I said there would be paint pics by now, but there was a couple of set backs and then on friday finally some base coat went on the inside of the doors, bonnet and hatch. The painter wasn't happy with the coverage of the colour even over a white base, so now he's going to try something else and will hopefully get some cleared shiny paint pics soon. I HOPE!!!!!
DOMDOM - hahahahaha... Love it :spoton:
#892 lxsstorana
lxsstorana
  • 2,499 posts
  • Car:SS Hatchback
Posted 06 June 2010 - 07:31 PM
Good to see you're human and slowing down abit on your brothers hatch. (lol)
Hard to believe it's less than 6 months since you started and you've done so much.
Looking forward to seeing some paint.
Mick.
#893 _cruiza_
_cruiza_
Posted 06 June 2010 - 10:00 PM
Under cover cruiza here
I have the dirt on mr dirt
I know the colour and the wheels I have pics using top secret spy cam and will post as soon as I can make a clean get away from from the lions den
#894 _DomDom_
_DomDom_
Posted 06 June 2010 - 10:17 PM
I couldn't help myself.Posted Image
Dom
#895 _jabba_
_jabba_
Posted 09 June 2010 - 06:32 PM
please...must...have...update...
I was so used to checking back every day to find huge updates, this is killing me.
#896 _Kush_
_Kush_
Posted 09 June 2010 - 07:27 PM
back of the line, buddy! :)
#897 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 09 June 2010 - 07:28 PM
We were used to that with the monaro to until the celica came on the scene.
But yeah i'm with jabbba, we all eagerly await every update!
#898 _dirtbag_
_dirtbag_
Posted 09 June 2010 - 09:00 PM
Well I had to steal cruiza's camera, as he took pics without me knowing. Only problem is they're in B&W and they're spy pics : )
Here they are.
The inside of the doors, bonnet and hatch.
Under the bonnet.
Under the hatch.
Here's the basecoat going on the door and hatch jams and the engine bay.
Here's the engine bay with the black radiator support and dash and all cleared.
It looks good grey huh? : )
#899 _sjohnst7_
_sjohnst7_
Posted 09 June 2010 - 09:13 PM
So it did go black!
#900 _dirtbag_
_dirtbag_
Posted 09 June 2010 - 09:16 PM
You know what they say - once you go black, you never go back : )
