Fixing my brothers UC hatch
#176
_darrenmark1_
Posted 18 January 2010 - 06:58 PM
#177
_evil UC hatch_
Posted 18 January 2010 - 07:00 PM
#178
_dirtbag_
Posted 18 January 2010 - 07:52 PM
Did you have the UC hatch when you were here? What colour is it?
#179
_evil UC hatch_
Posted 18 January 2010 - 07:57 PM
#180
_dirtbag_
Posted 18 January 2010 - 07:59 PM
What are you going to do with the hatch? Wanna sell????
#181
Posted 18 January 2010 - 08:06 PM
#182
_evil UC hatch_
Posted 18 January 2010 - 08:14 PM
#183
_dirtbag_
Posted 19 January 2010 - 06:00 PM
#184
_evil UC hatch_
Posted 19 January 2010 - 06:26 PM
when I bought my motor I was offered a shift kitted T700 with some sort of hi stall for an extra $500, I had no intrest in that at all because it wasnt a manual
Edited by evil UC hatch, 19 January 2010 - 06:29 PM.
#185
_dirtbag_
Posted 19 January 2010 - 08:49 PM
Today was a fun old day. We went out into an old wrecking yard, in the Qld summer heat and cut the dash out of an old LX sedan. Yippee.
It was a rusty old beast too. Scored a few cuts from rusty edges.
Here's the dash donor.
Pretty sweet ride huh : )
After a lot of sweating and a bit of swearing, we had the dash out. The ends are a bit rusty, but we can't be too picky. Not many of these lying around these parts.
Here's the old UC dash that has to be removed. This is mainly so people can see the difference. I've never done this before, so I didn't know the difference until now.
With the dash out, there sure is a lot of room : )
Had to do a trial fit of the LX dash. I put the dash pad on just to get an idea of alignment. Looks a million bucks already.
Pity the new dash had the rust in it. Otherwise it would be all fitted by now. Instead I need to add some metal to the ends.
The LX dash lines up fine. Looks a lot better too.
The lower lip of the windscreen frame was sanded back to metal and holes drilled for the new dash to get plug welded in.
Here's the rust on the drivers side of the dash repaired. Fiddly crap work, this is : )
It's starting to look a bit better now.
The left side needs a little bit of a repair too.
Another trial fit during the rust repairs, just to make sure it still fits. Once it's all done and tacked into place, I'll put the dash together and make sure it's in the exact right position. Once I'm sure it's right I'll strip the dash again and weld it in properly.
The gearbox tunnel is the next thing to get replaced. The T56 is a big box, so will need a larger tunnel. It's been cut open so I can fit the box to determine how big to make the new tunnel.
#186
Posted 20 January 2010 - 07:20 AM
something stock-ish, but different enough to set it apart?
#187
_dirtbag_
Posted 20 January 2010 - 07:44 AM
The answer is no though. It'll be a stock LX dash for this car. That's what my brother wants, and I agree with his taste, they're a nice simple design. I've seen a fair few LH/LXs with custom dashes but am yet to see one I really like.
#188
_dirtbag_
Posted 21 January 2010 - 11:18 PM
With the rust in the dash on the left side fixed it was time for another trial fit.
I then mounted the lower part of the dash so I could see if it was all square and looked decent. I like it.
I thought the dash could stay out until the new tunnel was made and the A/C fitted, just to make access a bit easier.
Time to look at fitting the T56.
It's a big unit. Here it is with the CRS crossmember fitted.
With the tunnel split we were able to get the box into position.
See how close the gearstick and shifter base are. I was thinking I'd have to move the handbrake, but a different shifter will solve the problem. It's a B&M unit. I had to take apart the old shifter and this one bolts on over the top of the plate that mounted the original shifter.
I also turned the gear stick mount around 180 degrees to get the shifter away from the handbrake. That's the black "L" shaped thingy.
The crossmember is a nice piece of work.
Next step is to start making the new tunnel. I cut nearly all of the old one out, and will make the new one in sections.
I then shaped up a bit of metal to form the mid section of the tunnel. I made it so it overlapped with the floor. Once I was happy with it's placement, I tacked it in. I then ran a 1mm cut off wheel along the overlap, in sections, so it became a butt weld with no overlaps. Looks much neater and doesn't trap moisture.
The next piece to get added was the part that covers the bellhousing. It takes a little while to get the shape right, but it's not hard to do.
The area around the shifter will be done in a few pieces. I've only tacked in one side at this stage, but will get it finished soon. I hope : )
#189
_dirtbag_
Posted 21 January 2010 - 11:24 PM
The top of the scoop is a bit ordinary, so it'll need a bit of attention to get it looking nice.
It's hard to see in the pic. but the top is sagged in the middle. The front needs a bit of work too.
A few hours with some filler and sandpaper later.....
The scoop still needs more work, as it's still a little low in the middle, but that's what tomorrow is for : )
#190
Posted 21 January 2010 - 11:51 PM
#191
_dirtbag_
Posted 21 January 2010 - 11:59 PM
Drop off your HD? I love HDs. Hardly ever see one any more. You can drop it off whenever you like. Can't guarantee I'll give it back though:P
#192
Posted 22 January 2010 - 12:19 AM
thinking of going similar ls2 route to your hatch
#193
_dirtbag_
Posted 22 January 2010 - 01:40 AM
6 speed manual I hope?
#194
_dirtbag_
Posted 22 January 2010 - 01:47 AM
The Nissan V8s are really big. I'm in the process of stuffing a VH45 into my wifes 1968 firebird and it took a lot of work to get it in there. We bought a complete front cut for $1800. Bargain.
Your ute looks awesome BTW, and the sedan looks like the perfect base for a project. Look forward to seeing what you do.
#195
Posted 22 January 2010 - 05:13 AM
Really enjoying it and love the work and the fast progress.
#196
_AD_75_
Posted 22 January 2010 - 04:23 PM
#197
_dirtbag_
Posted 24 January 2010 - 04:11 AM
The tranny tunnel is pretty much done now. I've just got to make the bolt on top section that will cover the gearstick and have a rubber shield to stop gunk from coming inside the car from underneath.
The next job on the list while the dash was still removable was to fit the A/C unit. It's a cool old school unit, but is a little heavy and awkward to get into position myself. I struggled with it for a while before deciding I'd just rip the dash out and mount it to the dash on the work bench.
It was much easier to sort it out on the bench, however I did have to do some figuring in the car, as it's a fairly big unit and I had to not have it hit the firewall.
Once all the measurements were taken, I mounted the unit to the dash with the mounts that came with the unit. I also added a brace from the top of the dash to one of the mounts, just to help support it. Now it's really solid even out of the car. Yay.
It's not pretty, but it does the job. This pic is during test fitting, so is only tacked together. It's all welded now.
Not only is there exposed wires everywhere, they used masking tape to insulate the joins. Nice! : )
Here's the dash clamped back into place with the A/C fitted.
It was hard to get a pic, as there's no room, but you can sort of see through the glove box opening how close to the firewall the unit sits, without actually touching it.
Just a view from the passengers side. I like the retro look to it. Suits the dash. Wont look so weird when the interior is in.
There's not a lot to say it's a UC anymore apart from the handbrake. That's the best bit.
The scoop is still getting some work to fix the saggy look. I hate using filler, but in this case it's a necessary evil.
Plus, it makes the front of the scoop look like a butt print : )
#198
Posted 24 January 2010 - 07:22 AM
Did you just trust that the g/box x member would place it correctly?
#199
_Herne_
Posted 24 January 2010 - 07:39 AM
One thing troubles me a bit, you are bogging up an old saggy scoop but why didnt you opt for a new one?
This has to be one of the most informative threads I have read here in ages.
Herne
#200
_dirtbag_
Posted 24 January 2010 - 08:32 AM
As for fitting the gearbox without the motor - when we had the motor in place I measured how far it was from the firewall, to see how much room there would be for bellhousing bolts. So when the box went in I set it up at the same measurement.
