Coolant capacity for a red 6
16 replies to this topic
#1 _jklumpp_
_jklumpp_
Posted 01 January 2010 - 07:33 PM
Can anyone tell me how much coolant a red 6 Lj torana takes?
#2 LC-069
LC-069
  • 363 posts
  • Name:Mark
  • Car:LC GTR & LX SL
Posted 01 January 2010 - 08:56 PM
total capacity of 10.3 litres with heater.
Edited by LC-069, 01 January 2010 - 08:57 PM.
#3 xu1kid
xu1kid
  • 364 posts
  • Name:anthony
  • Car:lj gtr xu1
Posted 01 January 2010 - 11:55 PM
put around 50/50 coolant water,or 3-4 litres coolant
#4 TerrA LX
Posted 02 January 2010 - 03:05 AM
May I ask what brand of coolant you reccomend?
#5 xu1kid
xu1kid
  • 364 posts
  • Name:anthony
  • Car:lj gtr xu1
Posted 04 January 2010 - 08:14 PM
i buy a 5 litre bottle of coolant concentrate the green stuff burson brand or other known brands
#6 TerrA LX
Posted 04 January 2010 - 08:43 PM
ok, just strange to run 50% isn't it?
Going to the snow?
Edited by TerrA LX, 04 January 2010 - 08:52 PM.
#7 rodomo
  • 18,041 posts
Posted 04 January 2010 - 09:50 PM
I think I know what your getting at Terry.
I don't go to the snow or desert.
I use Castrol corrosion inhibitor. No anti-freeze, anti-boil, just a sraight inhibitor.
Edited by rodomo, 04 January 2010 - 09:52 PM.
#8 TerrA LX
Posted 04 January 2010 - 10:04 PM
I rarely use more than 500ml of concentrate, 3 or 4 Litres of pre mix.
Yeah, inhibitor is only really needed in urban climates.
Edit - I hate the word anti boil, most MSD's for anti freeze/anti boil state running 33 - 50% will raise boiling point by 9deg C - lol - if your car wont run 110 deg C without boiling with plain water then there is something seriously wrong.
#9 rodomo
  • 18,041 posts
Posted 04 January 2010 - 10:28 PM
http://www.autobarn....cts/10/67/8101/
#10 TerrA LX
Posted 04 January 2010 - 11:04 PM
That be my preference too.
#11 mr5000
mr5000
    chief break-everything
  • 3,455 posts
  • Car:77 lx 4door
Posted 05 January 2010 - 09:11 AM
i use that tectacool premix stuff its cheap but doesnt seem like cheap ass coolant like some of the stuff i bought from super cheap once was like cordial
#12 Com_VC
Com_VC
  • 411 posts
Posted 05 January 2010 - 10:55 AM
I'm thinking about using Waterwetter, have heard good things about it so might give it a try. I think we had a discussion on this forum awhile back and most said it was good :)
http://www.redlineoi...asp#waterwetter
http://www.redlineoi...sp?CategoryID=5
#13 _gtr161s_
_gtr161s_
Posted 03 April 2020 - 05:01 PM
Just picked up on this old thread because i wanted to use a radiator coolant product in my car.
short answer is only an inhibitor can be used on the cars running the standard copper brass radiators and cast blocks. The other anti freeze products will damage the radiator
#14 grumpy xu1
grumpy xu1
  • 2,812 posts
  • Name:Gary
  • Car:lj xu1
Posted 03 April 2020 - 07:16 PM
Nulon have a guide you can use, which includes radiator fluids, I'm pretty sure that you can add some royal purple, purple ice to it, no problems. It's been proven to work better than water wetter anyway. Royal purple give mixing ratios on their website. Gary.
#15 Dave6179
Dave6179
  • 577 posts
  • Name:David
  • Car:HJ, VN, VX SS
Posted 20 July 2020 - 09:00 AM
Water Wetter here too. Tried that green shit and the temps went up 15-20 degrees.
Flushed and refilled with WW. Took the pump off last week and found a small glob of white gel in the pump that had chewed a hole through the alloy.
New one on the way.
#16 RallyRed
  • 8,158 posts
Posted 20 July 2020 - 09:56 AM
Always in two minds if the temp seems to rise wgen you try various coolants.
I've heard a theory that all that means is that it is doing a better job. i.e. actually transfering more heat from the block/ head to the coolant. Assuming the sender is in the coolant flow.
#17 Com_VC
Com_VC
  • 411 posts
Posted 20 July 2020 - 04:14 PM
Will probably end up running Toyota long life coolant (red).  I will be using a aluminium radiator though.
