LC/LJ XU1 BATTERY TRAY
Posted 12 January 2010 - 06:53 PM
cheers. Blake
Posted 12 January 2010 - 07:30 PM
Hello. Was wondering if anyone had a photo of an original LC-LJ XU1 battery tray in a car, that hasnt been changed or replaced. need this because i purchased a rare spares one but it has folden egdes and also like to see how there fitted etc. so if anyone has a photo, or an XU1 it would very much appreciated if someone could take a photo of thier XU1 battery tray and post it please. thankyou,
cheers. Blake
Hi
This picture is all I had to go by. It is not real clear whether the edge has been flattened or left folded. I am sure someone here has an original. We have the dimensions of the vertical plate.
Bazza
Posted 12 January 2010 - 07:44 PM
Blake
#4 _sunburst73-xu1_
Posted 12 January 2010 - 07:51 PM
101_1466.jpg 55K 84 downloads
One thing I did learn was the position of the tray,mine had a 6mm gap from the corner of the tray to the radiator support were I know of another forum members one was hard up against.His was a 72 xu1 so could be a 72/73 thing,then again it could just be another holden put where every it fits and hit that spot weld gun,thing.
cheers Dane
Posted 12 January 2010 - 08:03 PM
hey thanks for that bazza. did u say you have the dimensions for that vertical plate? if so would you be able to post them as im currently dummying it all up ready to weld in place, cheers
Blake
Hi Blake
Looking at this picture (I forgot I had it) it is of an original and the facing edge seems to be vertical not turned.
The plate is 1/16th inch thick. The modern equivalent is 1.6mm. I had one cut today for $5 at the local steel merchant.
Bazza
Posted 13 January 2010 - 01:01 PM
Blake
Posted 14 January 2010 - 10:48 AM
This is mine before I replaced it.
cheers Dane
hi dane ..i reckon its a brisbane/adelaide thing..scotty 1973/bruce 1972..both adelaide cars
are touching rad support mine 1972 and yours 1973 are both brisbane cars and have the 4 to 6 mm gap
to rad support
blake if you PM me your email addy i will send you a file (16 pics) to you, to also show you the difference
between LC and LJ xu-1s
cheers johnno
