what is your holden 6 combo
109 replies to this topic
#26 Zook
Zook
  • 1,536 posts
Posted 14 January 2010 - 08:13 PM
he he, and sounds like no red six I've ever heard... it's mental!!
#27 _Bomber Watson_
Posted 14 January 2010 - 08:30 PM
Hmmm, to join the pissing contest or not to....
#28 _CraigA_
_CraigA_
Posted 14 January 2010 - 10:12 PM
Are you guys running mechanical or electric fuel pumps?
I'm using a factory VK type and am concerned it won't do the job at higher revs.
And do Chev small block fuel pumps bolt straight up?
#29 GTR600
GTR600
  • 169 posts
  • Name:Brock
  • Car:72 LJ GTR
Posted 14 January 2010 - 10:21 PM
Using the small block chev high volume type,
does the job for mine but they dont look the best.
#30 TerrA LX
Posted 14 January 2010 - 10:32 PM
Give Marielli performance in Belar st Yamanto or Churchill a call (07) 3812 0544 they sell E85, around $54 ...
Jeez that's tuff, they sell it here at the pump for around $1.30.
#31 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 14 January 2010 - 11:29 PM
heavy 9" too.
in all honesty, the 9 inch was a step forward, higher ratio gears available for starters, and the weight difference between full spool 9" and mini spooled borgwarner was minimal.
and you dont have a worry with it either, unlike borgwarners and replacing gears every 2 meeting, has anyone else had that problem too?
Edited by greens nice, 14 January 2010 - 11:30 PM.
#32 rodomo
  • 18,020 posts
Posted 15 January 2010 - 12:09 AM
Is this what you're using?
#33 _NZ Toranaman_
_NZ Toranaman_
Posted 15 January 2010 - 04:56 AM
Engine: VK black carb 202 - ACL pistons, Balanced, knife edged crank.
Flywheel-Clutch: Smallest clutch mated to lightened flywheel (15lbs), clutch uses strenghtened straps.
Induction: Redline manifold, 45 Webers with 38 chokes with stacks, stock black motor fuel pump with adjustable regulator to 3PSI
Ignition: Stock regraphed Bosche VH Electronic with Bosche Super plugs no vac.
Exhaust: Pacemaker running 2" all the way to tail pipe
Cam: Kelford F14 Blank-
[email protected] .483 Lift with 1.5 rockers
Compression: Approx 10.2:1
Head 12-port cast iron Yella Terra with crow springs (Unmodified)
Power adders N/A
1/4 mile and mph
[email protected] LC Torana 98 pump + 1/4 mix of avgas (watch this space)
Driveline m20 4 speed Banjo 3.55 gears open wheeler 205x60x14 street tires (upgraded this now, 3.9 LSD Hilux diff and 235x50x15 performance street tires)
I have unofficially run faster than 103mph but I will have to wait until the 30th to try and make it official. I am now struggling hugely with traction and last time out was still spinning at 1/3 track. hopefully I have it all together now.
Edited by NZ Toranaman, 15 January 2010 - 04:59 AM.
#34 _CraigA_
_CraigA_
Posted 15 January 2010 - 06:39 AM
Rodomo, mine is like this but factory type.
To be honest I'd rather keep a mechanical pump than go to the trouble of putting an electric one in.
#35 rodomo
  • 18,020 posts
Posted 15 January 2010 - 09:08 AM
I can't see the number on the box but I reckon that one is G7736?
A In this pic is G7736
B Is similar to what you are running? (Not exactly the same, just a comparison pic)
C Is G4044
This from the Goss catalogue:
VC, VH, VK 80-86 6cyl ‘blue’, ‘black’ 2.85,3.3L carburetted - standard replacement metal top pump see Tip below G7736 5 940KT 6
VB, VC, VH, VK 78-86 6cyl ‘red’, ‘blue’, ‘black’ 2.85,3.3L carburetted - uprated pump - high fl ow/standard pressure see page 163 G4044 4 nr
Unfortunately, the catalogue doesn't go up to page 163, it stops at 159. :Headbang2:
http://www.noelsautoparts.com.au/Goss%20Catalogue.pdf
I'm with you and would rather run mechanical, G4044 is what I have on the Bombadoor, but I'm only feeding a 350 Holley.
Another forum member has a G4044 fitted with triple 175's and reports no problems.
Edited by rodomo, 15 January 2010 - 09:10 AM.
#36 _CraigA_
_CraigA_
Posted 15 January 2010 - 10:07 AM
Thanks for the effort Rodomo Posted Image
'B' is most like the one I have - a flat top with a series of screws around the edge.
Does anyone know how many gallons per hour (GPH) the pumps are rated at?
The small block chev pumps appear like they would fit and there are a wide range of high volume ones available.
#37 _CraigA_
_CraigA_
Posted 15 January 2010 - 01:25 PM
Here's a picture of my current one
#38 _ChevLX_77_
_ChevLX_77_
Posted 15 January 2010 - 05:18 PM
I run 2 one Holley Blue for the carb
and a carter for the nitrous
#39 _Bomber Watson_
Posted 15 January 2010 - 07:08 PM
I have an Edelbrock Performer series SB chev pump, bolts strait up.
Cheap from Summit.
#40 _CraigA_
_CraigA_
Posted 15 January 2010 - 07:54 PM
Thanks guys, will have a look at the SB Chev ones. Sorry for the thread hijack
#41 _Bomber Watson_
Posted 15 January 2010 - 11:31 PM
http://www.summitrac...ET/?Ns=Rank|Asc
That should give you a head start, plenty to choose from.
Basically, if they have two bolt holes they will bolt up, if they have four then they wont.
#42 GTR600
GTR600
  • 169 posts
  • Name:Brock
  • Car:72 LJ GTR
Posted 16 January 2010 - 01:25 AM
Thats the one im running rodomo as in you picture,
I think there on the cheaper end of the market but run the triples with a reg on the original fuel lines with no worries.
its not a chevPosted Image sorry dont have a part number.
Never even considered electric i really wanted to stick with the class bowl.
Was always told if i was going to change diffs to go borgwarner before the 9" because of weight when running a six,but i think these other cars are in a different
field and therefore . ITS CHEAPER IN THE LONG RUNPosted Image
#43 mr5000
mr5000
    chief break-everything
  • 3,455 posts
  • Car:77 lx 4door
Posted 16 January 2010 - 08:46 AM
vh slx
Engine blue 202
Induction standard 12 port manifold webber downdraught off xe
Exhaust genie extractors that are a shithouse fit and fouled everywhere
Cam wade 242a
Compression standard
Head vk efi mild porting crow heavy duty valve springs had all the valves and seats done also
Power adders nil
1/4 mile and mph dont no yet will no later this year
Driveline traumatic and salsbury at the moment is getting a borgwarner later on
#44 _Gunmetal LH_
_Gunmetal LH_
Posted 17 January 2010 - 03:07 PM
Engine: Factory spec 202 with added oil breathers around rocker cover, side plates, dipstick tube, sump, rear main and timing cover seal.
Induction: Holden cast tuned, coolant heated alloy 1 barrel manifold. Downdraught stromberg with heavy fuel tint.
Exhaust: Carbon lined cast iron manifold type with mud insulated 1 3/4" iron oxide tubing to rear.
Cam: Factory spec, hardened layer removed with added pits.
Compression:
9.5:1 reduced to somewhere between a pfff and a fart.
Head: Yellow painted with standard sized valves and oversized valve stem seals.
Power adders: Modified air cleaner can by removing outer edges by 1"
1/4 mile and mph: 17.5 sec @wasn't looking
Driveline: Trimatic with breather treatment similar to engine specs and 3.36 diff gears.
All this under the stunning form of a HJ Kingswood, 1/4 tank, with timing carried out with meticulous attention to odometer while using a stopwatch.
(Sorry, couldn't help myself. I don't wish to detract from the awesome engines people have revealed so far.)
#45 gtrboyy
gtrboyy
  • 3,204 posts
Posted 17 January 2010 - 05:39 PM
Engine red 202
Induction aftermarket pushrods,hi vol oil pump..basic stuff,whatever broke got upgraded.
Exhaust crappy genie headers(seemed too small) 2 1/2 exhaust with a straight through muffler
Cam Arthur Johnstone solid
Compression We never checked,had 40 thou pistons...could have used more comp for the cam in it imo.
Head xu1 head that copped alot of port work,larger valves,dual springs
Power adders cain manifold,triple webbers,longer ram tubes,electronic dissy...chev fuel pump.
1/4 mile and mph Pb was a 13.1 at old eastern creek track
Driveline m20,lightened/chopped up flywheel,modified 1 tonner clutch & 3.90 bango
Cousin in law did a 14.1 when he owned it with a hydraulic cam,m21,3.08 single wheeler.A mate & I did gave the engine a speed rebuild,also changed a few things when I was still apprentice mechanic.Went hard for what it was & didn't cost much either,probably had a high 12 in it if I'd experimented more...got sick of breaking driveline then did the efi 5l conversion.
Must admit I enjoyed driving the car more as a triple webbered six,surprised alot of people at just how quick it was back then.
Edited by gtrboyy, 17 January 2010 - 05:42 PM.
#46 orangeLJ
Posted 18 January 2010 - 11:03 AM
DOOOOO IT!
I just need to find my cam specs before I post anything!
#47 _2door350_
_2door350_
Posted 18 January 2010 - 11:19 AM
red 186 plus 40
acl race series flat tops bearings and gaskets, starfire rods, balanced and blue printed
lightened flywheel
186 style head - high comp, rocker studs pinned, factory style adjustable rockers, SBC double spring, slightly bigger Stainless valves, unleaded inserts.
10.2 compression
465 Avenger series Holley on Cain manifold
big duration solid cam ex 85-44 in 45-84 .475 lift
locked blue dizzy
cast headers with 60" primaries
made 115 rwkw
#48 Heath
  • 18,368 posts
Posted 18 January 2010 - 12:13 PM
I need to put something together :cry:
#49 orangeLJ
Posted 18 January 2010 - 01:14 PM
red 186 plus 40
lightened flywheel
10.2 compression
locked blue dizzy
made 115 rwkw
That figure makes me VERY happy about my last combo.
202, 30 though over
about 8.5:1 compression
running a 356661 camshaft from this link
http://www.crowcams.com.au/media/catalogues/30.2%20Holden%206%20All.pdf
Holden stage 3 head, mild portwork
triple 1.75" SUs on long runner manifolds and running rich as shit
HPC coated extractors and a press bent 2.25" exhaust
Holden elec ignition and an old MSD 5 spark box
Made 94kW at the wheels and definitely had alot more in it with some more left in it (better tune etc)
New combo is shitloads quicker (when I get it running right!)
so will be interesting to get it on the dyno and tuned to see what it pulls.
#50 _Drag lc_
_Drag lc_
Posted 20 January 2010 - 10:42 AM
Engine RED cranked 202ci
Induction 45mm webers
Exhaust off the shelf ones carnt member
Cam [email protected] flat tappet cam
Compression 11.1
Head iron 9 port
Power adders
1/4 mile and mph 12.79 @ 105.88mph
Driveline npc clutch, m22 ,alluminium 9" centre full spool
this was a couple of years ago now we have a new combination that we are trying to get a handle on atm it has been pushed aside latley as i have other stuff to do.
Cheers Hayden
