what is your holden 6 combo
109 replies to this topic
#76 dinky48
dinky48
  • 69 posts
Posted 28 February 2010 - 08:21 AM
Dinky,
Sounds like an intreaging little combo.
what sort of car it is in?
your not located in qld any where u?
G'day Drag, its an LC 4door,low bucks project, i'm in Melbourne, still got standard computer, ran that time twice @ Heathcte Oct 09, since then have added YT steel flywheel with bigger bolts & dowels, Rising rate fuel pressure regulator screwed up to 60psi, and working on a cold air induction setup. Hope to run a 13.9 @ 100 mph or better in the next few weeks. I admire all the stuff you are doing with your car, I think its gr8 ! Cheers
lots of people tell you what you cant do, it runs quite well with a big cam & standard computer,car is registered & driven most weekends. cheers
#77 Heath
  • 18,368 posts
Posted 28 February 2010 - 08:43 AM
Bringing it up to the forum's drag day next month?
#78 dinky48
dinky48
  • 69 posts
Posted 28 February 2010 - 09:04 AM
G'day Heath,
when is that on mate ?
Chris
#79 _Bomber Watson_
Posted 28 February 2010 - 09:40 AM
OK ok i gotta comment :P.
Are you certain the cam has 270 @ .050"???
#80 Heath
  • 18,368 posts
Posted 28 February 2010 - 10:46 AM
Solid cam I take it?
#81 _Bomber Watson_
Posted 28 February 2010 - 10:53 AM
What does that have to do wtih the price of eggs?
#82 Heath
  • 18,368 posts
Posted 28 February 2010 - 10:54 AM
http://www.gmh-toran...ic=39746&st=200
#83 _Bomber Watson_
Posted 28 February 2010 - 11:01 AM
Why did i only just notice the drag day???
I should go :D
#84 dinky48
dinky48
  • 69 posts
Posted 28 February 2010 - 09:50 PM
Its a Speco grind, the old number was 22CE, I've got the specs at work, I'll post them up, pretty sure its 270 @050, and it is a solid cam
#85 dinky48
dinky48
  • 69 posts
Posted 01 March 2010 - 08:31 AM
Camshaft Specs are: Duration 270 @.050", Lobe Centre :104 inlet, 112 Exhaust, Gross Lift: .510".
#86 _mello92_
_mello92_
Posted 01 March 2010 - 09:25 AM
Dinky, thats quite impressive mate! To use that cam with VK injection and standard computer is quite remarkable.
Any idea on power output?
#87 dinky48
dinky48
  • 69 posts
Posted 01 March 2010 - 09:37 AM
thanks Mello, no idea on power output, still using standard injectors , needs a lot more development yet, tried some BA ford injectors, went harder in the top end but too rich down low, Bosch Jetronic injection is very simple, so you can get away with the cam as long as you set the idle @1000 to 1200 rpm
Chris
#88 _mello92_
_mello92_
Posted 01 March 2010 - 09:46 AM
What amounts of work has been done to the head Chris?
#89 dinky48
dinky48
  • 69 posts
Posted 01 March 2010 - 12:16 PM
basically nothig, just a clean up of the ports & chambers.
#90 S pack
  • 15,648 posts
Posted 06 March 2010 - 01:55 AM
Engine: JP 202 bored 40th, blue 202 crank & rods, block decked 40th, all crack tested, rods resized, repco hi perf pistons, federal mogul bearings, balanced and blueprinted.
Induction: XU1 175 cd strombergs, mainfold ported and flow tested.
Exhaust: XU1 cast iron manifolds, ported and flow tested, twin 2" S/Steel pipes, resonators and lukey 2x2 muffler.
Cam: Wade billet hyd Inlet 36-84 excl ramps, advertised duration 300, lift at lobe .300" exhaust 82-32
excl ramps, advertised duration 294 lift at lobe .308", anti pump up lifters and XU1 points dist.
Compression: 9.9:1 (from memory)
Head: XU1, crack tested, ported & polished, cc'd, reshaped head stud bosses, pinned rocker studs, new 1 piece std XU1 size valves, manley springs, YT 1.5 ratio roller rockers and holden pushrods that flex too much.
Power adders: Right foot.
1/4 mile and mph: don't know, don't care.
Driveline: 17lb flywheel, XU1 M20 close ratio box, 3.08 LSD Banjo.
Engine built to output at least 1hp per cube by Ron Richards Engine Development Centre. Circa 1987.
#91 _Drag lc_
_Drag lc_
Posted 14 March 2010 - 05:28 PM
com on bomber where is your little combo?
#92 _Bomber Watson_
Posted 14 March 2010 - 08:23 PM
Mate as you saw last night theres a couple of combo's on the go :P
#93 _fossil_
_fossil_
Posted 20 March 2010 - 09:08 PM
Just thought i would post instead of watching. Will be starting the new Torana in May, after Wal wrote the old one off at Willowbank.
New car, so it might as well have a new power plant.
ENGINE 202 blue
INDUCTION 1000hp Billett Turbo
EXHAUST 4 inch
CAM Probably Peter Watson
COMPRESSION 9.3
FUEL PUMP Aeromotive belt drive
HEAD Duggan
POWER ADDERS 35lb boost on Methonal
ECU Autronic
INJECTORS Moran
GEARBOX Dominator Powerglide
CONVERTOR Dominator
DRIVELINE Sheetmetal 9" Floater Hubs
SLICKS Hoosier
Pistons have finally arrived so I will make a decision on the cam in next 2 wks. I have all the rest of the gear.
I know it's not a holden anymore, but I still have the old engine If I break this one.Posted Image
#94 Heath
  • 18,368 posts
Posted 20 March 2010 - 10:11 PM
Ooooo a Duggan head, very interesting. Start a project thread mate!
#95 _rb3torana_
_rb3torana_
Posted 25 September 2014 - 10:21 AM
Engine 202 blue
Induction 650HP ultra holley on sheet manifold
Exhaust  6>1 1 3/4 extractors to single 3"
Cam  266@50 104lsa solid
Compression  10.4:1
Head stockish 12 port black
Power adders NIL
1/4 mile and mph 14.1 @ 97mph
 Driveline  3500rpm stall, 4.3 9 inch diff, Full weight UC torana on 98 PULP
Needs more convertor and compression and possibly a better head lol
#96 darway43
darway43
  • 215 posts
  • Name:David
  • Car:LJ 2 door
Posted 18 November 2014 - 06:03 PM
Engine- blue 202
Induction -3, 175cd's
Exhaust - custom
Cam - Huge wade soild
Compression - N/A
Head 9 port
Power adders - pump fuel
1/4 mile and mph -12.7@109mph, lc gtr in full street trim, street tyres, no fancy stree legal slicks,
Driveline - toyota 5spd, 9inch
Just wondering what size needles you run in your Strommies?
#97 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 19 November 2014 - 02:40 PM
I have no idea what it had.
#98 _Macca97_
_Macca97_
Posted 20 November 2014 - 02:02 PM
Engine, red 202
Induction, stock single strommy :P
Exhaust, genie extractors, 2 1/4 system
Cam, stock i think
Compression, umm 175psi on each and every pot :P
Head, stock 9 port
Power adders, exhaust, CHROME air cleaner
1/4 mile and mph, slow, takes forever to get to 140km/h, on private road of course
Driveline, m20 4 speed, 3:55 banjo, in hj ute
#99 Dave6179
Dave6179
  • 577 posts
  • Name:David
  • Car:HJ, VN, VX SS
Posted 21 November 2014 - 04:19 PM
What is it- 202 + .040 (by me)
Breathe in- 3 HS6 SUs (modified, fitted, tuned, by me) Jag HS8s in the wings.
Breathe out- PaceMaker (ported) into mandrel bent 2.5 by me (with racebox muffler).
Heartbeat- Wade 373 (not big enough!)
Blood pressure- 10.2
Up top- Modified (by me) YT and 1.6 Summit rollers, modified Bosch plugs (by me).
Go faster some more- More right boot! (by me only, no one drives my baby!)
How fast is it?- No idea, strip three hours away, but can still frighten me.
Rest of it- Supra W58, 3.55 Banjo (soon to be 3.45 BW) in HJ sedan.
Edited by Dave6179, 21 November 2014 - 04:24 PM.
#100 _mervx_
_mervx_
Posted 21 November 2014 - 04:43 PM
Dave,can you tell me more about your 1.6 Summit roller rockers please? part no or application? bolt on or mods,?
thanks mervx
