My newer Monaro
#376
_jabba_
Posted 28 June 2011 - 10:05 PM
#377
_jabba_
Posted 28 June 2011 - 10:35 PM
You can see both here
This is how the window seems to sit at the moment
I find if i put pressure on the glass pushing towards the rear of the car it winds up a lot better and doesnt seem to loose contact with the runner, i think i might have to remove it all again and see if theres a way i can get the rollers to hug the guide tighter. I have replaced the rollers with rarespares jobbies. The only thing i can think of is to loosen the nuts holding the rollers to the glass and pushing them closer together?
#378
_jabba_
Posted 28 June 2011 - 11:44 PM
Still, if anyone can grab some pics of inside the rear 1/4 window area that would be great.
Damien
#379
_LH8VD69_
Posted 29 June 2011 - 08:32 PM
#380
_jabba_
Posted 30 June 2011 - 06:23 PM
I guess the biggest thing when building a car is to write down your goals and stick too them otherwise these things seem to blow out. My biggest problem is i've never set any real goals so the post keeps shifting every time i have a good idea
#381
_jabba_
Posted 21 August 2011 - 09:20 PM
#382
_Quagmire_
Posted 21 August 2011 - 09:29 PM
#383
_jabba_
Posted 21 August 2011 - 09:30 PM
#384
_jabba_
Posted 30 August 2011 - 09:17 PM
My idea so far is to keep the standard fuel injectors that come with the throttle bodies and set them up to fire sequentially, then have another 8 larger injectors that stand over each trumpet that kick in when required. This is all supported with the megasquirt 3 code, so it shouldn't be too hard. The benefits of the stand off injectors should be better fuel atomisation and the fuel should also cool the intake charge. I'm thinking ill run dual VL fuel pumps in parallel to flow the required fuel, since two vl pumps are cheaper than one large pump
#385
Posted 31 August 2011 - 07:56 AM
#386
_nzstato_
Posted 31 August 2011 - 08:21 AM
#387
Posted 31 August 2011 - 09:57 AM
I was checking out these throttle bodies, they come in a few different year of manufacture. Are there any differences in these throttle bodies between 2002 to 2010 or are they the same?
#388
_jabba_
Posted 31 August 2011 - 11:21 AM
The thottles also have a little lever on them that when pulled it cracks the throttle plates open slightly, so basic idle air control could be as simple as hooking up a small solinoid to pull the lever when the engines cold. There are other ways to do idle control but i dont think the complexity is worth it for a weekend car
Edited by jabba, 31 August 2011 - 11:31 AM.
#389
_nzstato_
Posted 31 August 2011 - 11:34 AM
#390
_jabba_
Posted 31 August 2011 - 11:49 AM
Heres a youtube video showing the shower injection that i'm thinking of using along with the standard busa injectors.
Its just a thought at the moment, i like the challange to fabricate such a beast and i think it would perform well
I'm having other dumb ideas running through my head like adjustable length trumpets, possibling controlled by the megasquirt. Ill just have to play around and see what i can create to see if its viable tho
#391
_nzstato_
Posted 31 August 2011 - 01:58 PM
Here's a little bit of inspiration.
#392
Posted 31 August 2011 - 10:26 PM
I think Porche did adjustable length trumpets? I love this stuff, i will check in regularlyUsing motorbike throttles seems fairly 'common' in the 4cyl world but i hadnt really seen it used on a Chev or any old school v8's. I always wanted to do ITB but the costs are outragious, upwards for $3,000 for maifold and ITB. These motobike ones are perfect really, huge range of sizes from 36-46mm and the gsxr ones can be seperated!
Its just a thought at the moment, i like the challange to fabricate such a beast and i think it would perform well.
I'm having other dumb ideas running through my head like adjustable length trumpets, possibling controlled by the megasquirt. Ill just have to play around and see what i can create to see if its viable tho.
#393
Posted 31 August 2011 - 10:30 PM
Shower
http://www.youtube.com/watch?v=y2iBbwocYZw
Edited by Bart, 31 August 2011 - 10:30 PM.
#394
_jabba_
Posted 01 September 2011 - 11:51 AM
Oh yeah another name shower injection goes by is stand-off injection
Edited by jabba, 01 September 2011 - 11:52 AM.
#395
_jabba_
#396
Posted 01 September 2011 - 12:32 PM
As opposed to either up or down? I wouldn't have thought it was more difficult to do.
Glenn
#397
Posted 01 September 2011 - 12:43 PM
Yeah a on/off actuator would probably be good enough but if you want more variability you would use a stepper motor with a rack and pinion setup. I would love to see the F1 setup more closelyBart, you are youtube champion! Why couldnt i find those videos! How awesome do the variable intakes look. i dont think they would be that hard to create either. although ill probably make mine out of aluminium not carbon fibre
. I just need a electric solinoid to push it up and down, rather than using vacuum or compressed air... It would just be a simple switch in the megasquirt that said if tps = >x and rpm >x switch on. I have to find a way of calculating the stack length, and if it takes into account the distance from the throttle to valve or if its just throttle to end of horn.
Oh yeah another name shower injection goes by is stand-off injection.
#398
Posted 01 September 2011 - 01:51 PM
Or variable actuatorYeah a on/off actuator would probably be good enough but if you want more variability you would use a stepper motor with a rack and pinion setup. I would love to see the F1 setup more closely
Bart, you are youtube champion! Why couldnt i find those videos! How awesome do the variable intakes look. i dont think they would be that hard to create either. although ill probably make mine out of aluminium not carbon fibre. I just need a electric solinoid to push it up and down, rather than using vacuum or compressed air... It would just be a simple switch in the megasquirt that said if tps = >x and rpm >x switch on. I have to find a way of calculating the stack length, and if it takes into account the distance from the throttle to valve or if its just throttle to end of horn.
#399
_jabba_
Posted 01 September 2011 - 02:06 PM
Having it looked up to the throttle would be no good because you want longer runners at low rpm and shorter at higher rpm
#400
Posted 01 September 2011 - 02:25 PM
