I believe the ground cycles at for example 20hz, then the time that it is grounded for is varied. That way you could have it ground 20 times a second for very brief periods of time, adjustable until you hit the next cycle?
Posted 01 September 2011 - 10:27 PM
Posted 01 September 2011 - 10:30 PM
Posted 01 September 2011 - 10:36 PM
Yes but how does the MS vary the frequency? Say you want from 20khz to 200khz Thats why i mentioned a variable resistor to vary the frequencyyay for wikipedia
The average value of voltage (and current) fed to the load is controlled by turning the switch between supply and load on and off at a fast pace. The longer the switch is on compared to the off periods, the higher the power supplied to the load is.
The PWM switching frequency has to be much faster than what would affect the load, which is to say the device that uses the power. Typically switchings have to be done several times a minute in an electric stove, 120 Hz in a lamp dimmer, from few kilohertz (kHz) to tens of kHz for a motor drive and well into the tens or hundreds of kHz in audio amplifiers and computer power supplies.
Sounds like what i said.
Posted 01 September 2011 - 10:39 PM
|---|---|---|---|would provide more current than
Edited by jabba, 01 September 2011 - 10:47 PM.
Posted 01 September 2011 - 11:15 PM
Ok so it will be a set speed which will go forward and reverse, i confused myselfms doesn't vary the frequency, it vary's how long it holds the switch closed during each cycle.
For (a very poor) example say its set at 5hz (it cycles on and off 5 times a second)|---|---|---|---|would provide more current than|-|-|-|-|
- = time spent grounded
| = switching to ground
Sorry, really really bad example?
So the frequency that it operates is only really important to how smooth it operates, its how long it holds the switch closed that varies the current flow... I could probably use one of the pwm outputs for the idle air control motors, since there just stepper motors. I think it does a 4 wire output for those, I'm guessing so it can change directions rather than me relying on something to return to a position when current is removed.
Posted 02 September 2011 - 07:14 AM
Posted 02 September 2011 - 08:21 AM
Posted 02 September 2011 - 08:25 AM
Posted 02 September 2011 - 10:44 AM
I just thought of a possible problem with using stepper motors.
I have a mate building his own cnc setup. One of the things he has to do is include end stop switches to tell the machine that the stepper motors have reached the end of their travel. Do you have to do this with your possible setup?
That might mean you either have to set it up mechanically or an actuator/solenoid as you have said.
Glenn
Posted 02 September 2011 - 10:51 AM
Posted 02 September 2011 - 11:08 AM
Posted 02 September 2011 - 12:19 PM
Posted 02 September 2011 - 12:45 PM
That would work well.Maybe what I want is a servo motor not a stepper. I was just thinking about my toy helicopter and how it changes the pitch of the blades
Posted 02 September 2011 - 12:46 PM
Edited by hanra, 02 September 2011 - 12:49 PM.
Posted 02 September 2011 - 01:25 PM
Posted 02 September 2011 - 02:01 PM
Edited by Bart, 02 September 2011 - 02:08 PM.
Posted 02 September 2011 - 02:10 PM
Posted 02 September 2011 - 02:24 PM
Edited by r2160, 02 September 2011 - 02:25 PM.
Posted 02 September 2011 - 05:30 PM
Posted 02 September 2011 - 07:14 PM
Posted 02 September 2011 - 07:35 PM
Hang it off your engine crane lolhttp://www.robotmarketplace.com/products/0-PL1390.html
Overkill but wow, that would do it.
Posted 02 September 2011 - 07:38 PM
Posted 02 September 2011 - 07:49 PM
Edited by jabba, 02 September 2011 - 07:58 PM.
Posted 02 September 2011 - 07:53 PM
Posted 02 September 2011 - 07:55 PM
