the yellow car is fairly standard,and the blue one modified.
i,m near tamworth.
Posted 02 September 2011 - 08:06 PM
Posted 02 September 2011 - 08:08 PM
Posted 02 September 2011 - 08:12 PM
Posted 02 September 2011 - 08:13 PM
Posted 02 September 2011 - 08:16 PM
Edited by 73BATHXU1HTBATH350, 02 September 2011 - 08:17 PM.
Posted 02 September 2011 - 08:17 PM
Posted 02 September 2011 - 08:22 PM
Posted 03 September 2011 - 06:22 PM
Posted 04 September 2011 - 09:46 PM
Edited by Bart, 04 September 2011 - 09:50 PM.
Posted 04 September 2011 - 09:52 PM
Posted 04 September 2011 - 09:55 PM
Faster wouldnt be a prob for these controllersThat could work but it would need to be faster... I've ordered a big servo from the states to test with, it can move like 90 degree's in under a second... 3 wires, pos/neg and pwm. Hopefully it will magically work when plugged into the megasquirt
. Once it arrives ill test it out with the celicas boost control circuit, or if the ms3 beats it ill use that for testing
Posted 04 September 2011 - 09:58 PM
Posted 04 September 2011 - 10:04 PM
Posted 04 September 2011 - 10:08 PM
Yeah, the PWM input on the controller chip. I think the Tacho signal from the car ecu?? 5V square wave? can be used on the PWM input on the controller chip instead of using the POT. But thats going away from out of the box use for this controller but it can be done with R&D no doubtAhh that would do it, responds fast too
. I really wouldn't want it operated by tp alone tho, it really needs to be set off rpm as well.
Edited by Bart, 04 September 2011 - 10:09 PM.
Posted 04 September 2011 - 10:23 PM
Edited by jabba, 04 September 2011 - 10:30 PM.
Posted 04 September 2011 - 10:29 PM
Not cheapId rather more options than less
. I need to find someone local that stocks aluminium, i need some to turn up new fuel rails. They are just hollow aluminium tube with an o-ring, very simple... I also need some 50-60mm aluminium pipe so i can start making the sliders for the velocity stacks. Know anywhere that sells the velocity stack ends for cheap?
Posted 04 September 2011 - 10:38 PM
Edited by jabba, 04 September 2011 - 10:44 PM.
Posted 04 September 2011 - 10:59 PM
Posted 04 September 2011 - 11:05 PM
I think you will need some sort of O ring to seal the sliding tube, teflon O ring or similarInteresting, look how much 3cm change in length moves the power around! Love seeing real results
. There was another thread i found that had v8 results with long and short stacks... can't find it now tho :(.
Posted 04 September 2011 - 11:07 PM
Posted 05 September 2011 - 11:20 AM
I think O rings would be good, I was thinking Teflon to reduce binding. The shower style injectors should provide some lubrication on the O rings also. Should be as slipery as a butchers prick!Yeah i was wondering if i would need to seal the two tubed together, or just keep the tolerances VERY tight. Hmmm teflon o-ring... google...
Posted 11 September 2011 - 01:49 AM
Edited by jabba, 11 September 2011 - 01:51 AM.
Posted 11 September 2011 - 03:16 PM
