Drop Tank questions
8 replies to this topic
#1 _youngy_11_
_youngy_11_
Posted 22 January 2010 - 11:18 AM
Hi, I have a drop tank in my LX feeding a efi V6.
I filled it up all the way for the first time yesterday and noticed a small fuel leak when I got home.
It was coming from the plate ontop of the tank where the internal efi pump is. The plate has a gasket and from memory had a good seal.
I have noticed that when taking the fuel cap off a sucking noise, i.e the fuel tank is under negative pressure.
Is this acceptable?
All I have coming from the tank is the feeding fuel line and the return fuel line. I don't need a breather or anything do I?
Im thinking that the negative pressure has pulled the seal in, and I have only noticed it now due to the full tank and a bit of hard cornering.
I just found a photo.
The breather outlet on the other side was blocked off as I was too close to the exhaust.
Thanks Ryan
Edited by youngy_11, 22 January 2010 - 11:26 AM.
#2 76lxhatch
  • 7,207 posts
Posted 22 January 2010 - 03:55 PM
You should have a breather somewhere - with the engine using fuel the return line is never going to return as much as the pump pulls out
#3 ls2lxhatch
  • 5,332 posts
Posted 22 January 2010 - 03:57 PM
You will need some sort of breather system to allow air to replace the fuel as the tank is emptied. A breather system is also required to allow for fuel expansion on a hot day.
The factory petrol cap has a two way valve that allows air in or out if the pressure exceeds a preset amount. There are also breathers connected to the charcoal cannister.
#4 76lxhatch
  • 7,207 posts
Posted 22 January 2010 - 04:02 PM
I didn't know that, how would one identify this cap?
#5 ls2lxhatch
  • 5,332 posts
Posted 22 January 2010 - 04:14 PM
Any Torana that has a charcoal cannister should have the vented cap. If you take the cap off you will see the valve.
#6 _youngy_11_
_youngy_11_
Posted 25 January 2010 - 05:40 AM
I will check the cap but I have a locking type so I bet it doesn't.
Thanks guys I will look into this further.
#7 mr5000
mr5000
    chief break-everything
  • 3,455 posts
  • Car:77 lx 4door
Posted 25 January 2010 - 07:35 AM
i seen a photo of a fuel tank off a bus at tradeskool with no breather fuel tank looked like a crushed can
#8 _youngy_11_
_youngy_11_
Posted 25 January 2010 - 03:43 PM
Yeah thats fair enough, Im thinking about fitting a breather into the top of the neck.
Thanks Ryan
#9 _youngy_11_
_youngy_11_
Posted 27 January 2010 - 01:14 PM
I checked the CAP and it does have a relief valve on it. Will be dropping the tank out soon.
