msd dizzy clearence problems
_SSbloke_
Posted 22 January 2010 - 03:58 PM
Posted 22 January 2010 - 04:00 PM
_SSbloke_
Posted 22 January 2010 - 04:29 PM
i was hoping you werent goin to say that ......Cut the firewall lip or replace the dizzy...? :(
has anyone ever heated the dizzy cap and angled the back three nibs forward
Posted 22 January 2010 - 06:52 PM
_SSbloke_
Posted 22 January 2010 - 07:23 PM
I wouldent.....
yeah ive been looking at it that would just wreck it ,just looking at what other caps will fit it. gunna at least try all options before i start hacking into the car, see how i go
Posted 23 January 2010 - 03:48 PM
Cheers,
Tony.
_mumbo_
Posted 23 January 2010 - 04:11 PM
_mumbo_
Posted 23 January 2010 - 04:50 PM
_SSbloke_
Posted 23 January 2010 - 05:29 PM
Just found box it came in it is a MSD PRO-BILLET DISTRIBUTER part#8589. Only thing i can think of is iam not using the lead clamp on top because i am using dif brand of leads
looks pretty good to me mumbo there is 2 different sort of lead caps in the kit that i got might give the smaller ones a go before i start hacking into the shell
MSD don't make a cap that fits, I've tried. I ended up getting an original dissy rebuilt & regraphed to the same specs as the MSD, coverted it to electronic pickup & hooked it into the white wire on the MSD box. The MSD dissy in my toolbox waiting for the next car that it will fit into.
Cheers,
Tony.
i emailed MSD in the U.S. about this problem and it says the cap of 8437 fits this dizzy and has about 1/2 inch lower difference but is a standard leads end cap might be worth a try as well
Posted 23 January 2010 - 06:19 PM
I dont no what you guys are doin but mine fits easy no mods
The difference between the HQ and Torana engine mount plates may be enough to make the dizzy fit with one but not the other. Which engine mount plates do you have mumbo?
Edited by ls2lxhatch, 23 January 2010 - 06:19 PM.
Posted 23 January 2010 - 06:49 PM
Don't suppose they gave you the part number of the different cap?
Posted 23 January 2010 - 06:54 PM
Posted 23 January 2010 - 06:55 PM
Correct, standard cap has female terminalsWhen they say std leads I assume that this style of lead connection isn't std. Correct?
Posted 23 January 2010 - 06:59 PM
Posted 23 January 2010 - 07:11 PM
http://www.msdigniti...istributor.aspx
_mumbo_
Posted 23 January 2010 - 07:16 PM
Mine has the same cap as yours so it must be the engine mounts my engine seems to sit ferther forward.Here's how well mine fitted. I think I had HQ mounts at this stage. Torry mounts didn't really make it any better. When they say std leads I assume that this style of lead connection isn't std. Correct?
My dizy is not under the lip like yours it just in front
Edited by mumbo, 23 January 2010 - 07:20 PM.
Posted 23 January 2010 - 07:24 PM
_SSbloke_
Posted 23 January 2010 - 08:07 PM
if you get on the u.s. msd site look for 8437 distributor cap it has a photo and they were $21 U.S
Posted 23 January 2010 - 08:29 PM
_mumbo_
Posted 23 January 2010 - 08:42 PM
#21
Posted 23 January 2010 - 09:00 PM
Another possible cause of clearance issues is the angle of the engine. The engine angle can vary considerably depending on gearbox and crossmember choice. It may be the engine is lower at the back on cars with clearance problems which would cause the dizzy to lean into the lip. A spacer under the gearbox mount may do the trick.
#22
Posted 23 January 2010 - 10:05 PM
#23
Posted 24 January 2010 - 02:05 AM
Angle grinder to trans tunnel or angle grinder to firewall...
_ass308_
Posted 24 January 2010 - 10:04 AM
problem solved.
#25
Posted 24 January 2010 - 01:46 PM
I wish I had. Too late now.take it back buy an ice system
