slight problem with frontend
4 replies to this topic
#1 _355lxss_
_355lxss_
Posted 10 April 2006 - 01:37 PM
After installing the rebuilt uc front end into my hatch ive noticed that the upper arms rubs against the cup thingy where the bushes go under the rails. Has anyone experienced this problem before? Would it be rubbing because theres no weight on the frontend allowing the upper arms to be at the angle they are? I was thinking of bashing the cup thingy a little to clear the top part of the arm? Any thoughts?
#2 _HB1200_
_HB1200_
Posted 10 April 2006 - 04:44 PM
I checked mine (UC cross member in LH) and it only has a little bit more room than yours. The photo is taken with the front off the ground as well.
HB1200
#3 LXCHEV
LXCHEV
  • 3,655 posts
  • Car:'76 LX - 383 Chev
Posted 12 April 2006 - 10:29 AM
I had a look at my LX front-end this morning for you. (Original LX K-frame fitted with UC upper control arms). The very tops of the upper arms have a good 10 or 15 mm clearance at least. (ie. they sit a fair bit lower than both pics posted so far.
Looking at HB1200's pics there, I would also say my bolts are slightly lower too (ie. positioned maybe a further 10mm lower than his), explaining why I have so much more clearance.
It does ring a bell that when you compare LH / LX / UC front ends (early, late, nonRTS and RTS), there are many variations in the positioning of those bolts. It's common practice for people to lower them too by re-drilling the holes down further.
I can't recall if this info is in the Sticky front-end thread or not, it may pay to have a read through it, although the discussions I remember may have been lost on the old forums...
Hopefully some of the guru's on here may be able to tell you which front-ends from which models and years, had which bolt positioning......
Cheers,
Brett.
#4 _HB1200_
_HB1200_
Posted 12 April 2006 - 06:03 PM
Maybe the UC steel cup for the front bush is a different height. I'll have to check.
HB1200
#5 _QIKSLR_
_QIKSLR_
Posted 19 April 2006 - 08:13 AM
Cheers,
Brett.
You must have a late RTS LX then. They have the bolt holes lower. As far as I know your setup is ideal, late LX subframe (lower mount point) and UC arms and steering rack.
I've got a UC crossmember and I redrilled the mount points lower. I don't trust it so I'm trying to hunt down an LX subframe with the factory lower mount points.
LX35SS, are you sure the crossmember is seated properly? If your motor isn't in, you could try backing off all the bolts and see if theres any adjustment in it.
Edited by QIKSLR, 19 April 2006 - 08:17 AM.
