BLACK DICE
#126
Posted 11 February 2010 - 08:23 PM
#127
Posted 11 February 2010 - 08:32 PM
#128
_SSL31_
The mounts and filters are off a Kenworth Truck , all heavy f#cking duty , to cop caining not for prance
So your saying that my orange SS L31 torana hatch back is'nt upto scratch to have that custom made tank that i designed and made myself!
8 inchs w*nker.lol
#129
_j7723_
Posted 12 February 2010 - 07:57 AM
#130
Posted 12 February 2010 - 01:39 PM
Anyway both tough hatches
#131
Posted 12 February 2010 - 01:54 PM
#132
_niterida_
Posted 12 February 2010 - 06:25 PM
ls2lxhatch when the fuel level gets to half way it will sit in the outer 2 sections as it is all open inside, as you go around corners the fuel should wash over the 2 humps i am hoping, once the tank gets down to half way i will refill it if possible, to stop the outer sections of the fuel from going off.
Doesn't that sort of defeat the purpose of having a large drop tank ? Why don't you just run a couple of hoses from the bottom of each side, under the exhaust at the diff end of the tank and then into the centre section where the pickup is - that way the fuel won't sit in the two outside cells. Or maybe even a couple of T pieces in the pickup lines and run outlets in each section ??
#133
_niterida_
Posted 12 February 2010 - 06:32 PM
#134
_BATHURST-32D_
Posted 12 February 2010 - 06:50 PM
cheers gong
#135
_scottya!_
Posted 12 February 2010 - 07:31 PM
How boring would it be going to a car show and looking at toranas that have the usual big feet, flares and drop tank. You look at an XY GT Falcon by itself, nice ! Look at 15 of then all side by side. Yeah F%#@ing boring. My opinion only.
#136
Posted 12 February 2010 - 08:25 PM
I like GML-31's orange hatch a lot - I even like the exhaust the way it is - looks tuff and purposeful and different - thumbs up !!
not my car its John's SSL31
#137
_brett_32i_
Posted 12 February 2010 - 08:46 PM
Yeah I don't like how that exhaust finishes one bit either, tank looks nice though! First bit of work done on my car at a workshop was putting a tailpipe on the exhaust and the bloke put the rubber mount in a visible position, absolutely hate it! That is definitely going soon.
yeah, my exhaust guy fitted a muffler that has a central end and an offset end. decided to have the offset end pointing out the back. looks odd, but not worth changing now. mine also has truck mounts, the stud type, hidden well.
#138
Posted 12 February 2010 - 08:54 PM
#139
_BlownOutlaw_
Posted 13 February 2010 - 10:55 AM
One question, did you have those exhaust headers built or were they bought off the shelf somewhere? Do they fit well into the Torana clearance wise?
#140
Posted 13 February 2010 - 12:11 PM
This car has big wow factor, job well done
Edited by LS1LX, 13 February 2010 - 12:12 PM.
#141
_BLACK DICE_
Posted 13 February 2010 - 03:48 PM
#142
_BLACK DICE_
Posted 13 February 2010 - 04:11 PM
#143
_BLACK DICE_
Posted 13 February 2010 - 04:26 PM
niterida I agree the fuel tank needed separate lines to each side of the fuel tank but this would make it look clattered or dangerous having the fuel lines hanging under the exhaust. I though about having a Y section inside the fuel tank to suck from each side but ended up being more hassle than it was worth.
BlownOutlaw my extractors have been custom made and are tri-Y's, they have been designed to hug the motor for clearance on both sides especially the drivers for steering, these extractors will not fit any other Torana as for the front cross member had been tickled.
#144
_brett_32i_
Posted 13 February 2010 - 04:35 PM
#145
Posted 13 February 2010 - 04:39 PM
Edited by Heath, 13 February 2010 - 04:40 PM.
#146
_BLACK DICE_
Posted 13 February 2010 - 04:51 PM
Heath gets a GOLD star
#147
_BLACK DICE_
Posted 13 February 2010 - 05:01 PM
#148
_BLACK DICE_
Posted 13 February 2010 - 05:15 PM
The green torana is not mine it was at powercruise.
#149
_SSL31_
Posted 13 February 2010 - 10:13 PM
I rarely take it out these days , every blue moon i might take it down to munchies for a cruze.
Might have to take you up on that offer in Redlands , even though shes not a show car , have to clean her up abit if i do go , always too busy working on my other hatch i m building on the spit and mucking around with my 4 door LXs. So my papaya SS just sits there...lol
On my tank i have four pick ups , 2 in the centre at the rear and one each side from the fronts with an internal pipes picking up at the rear of the tank.
#150
_2wild4u_
Posted 14 February 2010 - 03:32 PM
