Xu1 gearbox cross member
73 replies to this topic
#51 _NYS 71_
_NYS 71_
Posted 07 August 2012 - 07:40 PM
Hi NYC 71,
I have 71 LC was originally auto, the cross member ends were "wrapped" in a rubber block insulator when I purchased the car. I believe they were factory fitment.
May still have them in the shed if you are chasing pictures, I didn't use them when I fitted the 4 speed,
Regards Simon
hHi Simon
yeah mate that would be great if you could get a picture, can't seem to find much about them or if anyone makes an aftermarket version
#52 debkar
debkar
  • 912 posts
  • Car:1971 LC 2 Door
Posted 07 August 2012 - 08:01 PM
Will do, I'll dig through the shed tomorrow, I think I still have the rubbers there
#53 S pack
  • 15,764 posts
Posted 07 August 2012 - 10:50 PM
hHi Simon
Have a look here in judgelj's build thread, page 3, 17th post down.
You get a partial view of the rubber insulator and the metal retainer that encapsulates it and bolts up to the chassis rail.
Disregard the 10mm thick home made metal spacer that Jacob has installed between the insulator and the rail.
http://www.gmh-torana.com.au/forums/topic/60596-lc-s-coupe-rebuild/page__st__50
#54 debkar
debkar
  • 912 posts
Posted 08 August 2012 - 06:13 PM
Thanks Dave, had forgotten Jacob's car,
Here are the auto insulators , hope this is a help,
#55 _NYS 71_
_NYS 71_
Posted 08 August 2012 - 07:40 PM
thanks mate thats a big help, now i know roughly what i'm looking for. ive never seen any like that on a torana that ive worked on, so does anyone know if anyone makes a aftermarket version or similar. i couldn't find much out about it on the internet.
#56 ribz0
ribz0
  • 512 posts
  • Name:Eric
  • Car:LC Torana & 1975 South African Mini
Posted 08 August 2012 - 07:52 PM
This might help...
I had to take them off when I did a manual coversion on mine...
#57 debkar
debkar
  • 912 posts
Posted 08 August 2012 - 07:55 PM
I've never seen them after market. I can get measurements for you of the steel brackets, the rubber, possibly make out of solid block.
#58 _NYS 71_
_NYS 71_
Posted 09 August 2012 - 07:08 PM
yeah mate that would be great might have to try to fab some up. thanks i'll keep an eye for some, theres a few swaps coming up.
#59 debkar
debkar
  • 912 posts
Posted 09 August 2012 - 07:15 PM
No worries, I'll measure up Saturday morning.
Regards Simon
#60 debkar
debkar
  • 912 posts
Posted 13 August 2012 - 07:24 PM
Hi
Overall length of the bracket is 185mm
Overall width of the bracket is 45mm
Overall depth of the bracket is 30mm
Length where rubber insert sits is 110mm x 42mm
Between bolt holes is 145mm which should line up with threaded holes in the car
Hope that helps,
Regards Simon
#61 _parap187_
_parap187_
Posted 24 August 2013 - 12:06 AM
Hi Guys
Please help out,
I have an LC 71 2door with aussie 4 speed.
My x member has two spacers on each side of the cross member and nothing under the rear engine mount????????????
So it has 4 spacers all up, they look like two different thinknessess......
Please help................
#62 N/A-PWR
  • 9,644 posts
Posted 24 August 2013 - 12:19 AM
The above picture Nathan say's you need a spacer on the outer edges and one at the gearbox mount. Dave I
#63 S pack
  • 15,764 posts
Nathan, this is exactly what you need, 3 spacers for LC with Aussie M20 4spd. Same as the 3spd. There is no spacer between the crossmember and the rear mount
Only the Opel 4 spd had four spacers.
#64 N/A-PWR
  • 9,644 posts
Posted 24 August 2013 - 12:23 AM
OK - I agree with Dave - did not say Opel up there.
So that makes Nathan's LC Correct, except remove one spacer from each side - Yay
Edited by TORYPOWER, 24 August 2013 - 12:27 AM.
#65 S pack
  • 15,764 posts
Posted 24 August 2013 - 12:29 AM
That's because that drawing/diagram was pre Aussie M20 release in LC Torana.
Edited by S pack, 24 August 2013 - 12:29 AM.
#66 _parap187_
_parap187_
Posted 09 May 2015 - 08:40 AM
thanks, you mob
#67 ChrisLC
ChrisLC
  • 105 posts
  • Name:Chris
  • Car:1971 LC Four Door S
Posted 17 May 2015 - 10:35 AM
Just saw this old thread thaks to parap187, and  I am very surprised. My 71 LC S had a Opel box, it did not last long once the 2250 engine got the flick for a hot 186. I loved the gear ratio's though, especially winding it out to 160k's in third gear down Cosgrove Road Enfield many years ago (usually well after midnight on way home from a night out). But the business with the crossmember spacers has my interest. I remember those metal end spacers when I replaced the Opel with a M20 and I re-used them. That was over 30 years ago. Looking at S pack's photo above, I am confused as in earlier posts, it is stated that these end spacer blocks are only for the Opel's. So what should I have?  Does anyone know why the spacer was required for a Opel but not a M20?
#68 S pack
  • 15,764 posts
Posted 17 May 2015 - 09:56 PM
Chris
For the Aussie M20 4spd you need the same spacers as the M15 3spd.
The M15 3spd is the crossmember depicted in the middle in this diagram.
#69 ChrisLC
ChrisLC
  • 105 posts
  • Name:Chris
Posted 19 May 2015 - 07:43 PM
Thanks S Pack. I am pretty sure I re-used that extra spacer under the engine mount. I wonder what ramifications it has/had? Gear shifters a little higher? I think I remember them too close to the hole.
#70 jd lj
jd lj
  • 2,120 posts
  • Name:James D
  • Car:LJ
Posted 09 January 2019 - 06:22 AM
Can anyone tell me if the 72 and 73 LJ cross members are interchangeable in regards to the same bolt spacing to the chassis rails? If the 73 cross member is wider front to back are the holes spread further apart also? Would a 72 cross member bolt straight up to a 73 car?
#71 S pack
  • 15,764 posts
Posted 09 January 2019 - 06:37 AM
Yes, all the transmission support member mounting holes (7 bolt holes in each rail from memory) in the chassis rails remained the same from the 1st LC to the last LJ.
#72 jd lj
jd lj
  • 2,120 posts
  • Name:James D
  • Car:LJ
Posted 09 January 2019 - 06:46 AM
Thanks Dave,
I thought that you'd be able to answer that for me.
#73 limo
limo
  • 2,673 posts
Posted 10 September 2019 - 05:45 PM
This is a spacer kit for an Opel gearbox. As far as I know, the Aussie used the two rectangular spacers on the crossmember as well (but not the big ones in the centre).attachicon.gif2976_1.jpg
Found this old thread
Anyone know the measurements of the big spacer ?
Always  had trouble  (since restoring) changing into  second up or down  with Opel in my LC GTR, seems to hit console
The spacer is missing so figure if I put one in should  change shaft angle  and change correctly
#74 _LONA-CK_
_LONA-CK_
Posted 11 September 2019 - 07:47 AM
I have an original one here mate will message you today cheers gong
