Trimatic gear selection help
#1 _1ARC_
Posted 28 January 2010 - 11:20 AM
I have been told that the gear selector lever on the tramsmission is in the park position when it is fully pushed forward (to wards the front of the car). On the shifter the shifter arm is fully to the rear (even though the the shifter is fully forward) when in park. My question is: if the gear selector lever is fully forward and the shifter arm is fully to the rear how are the gears selected.
When you look at my drawing this does not make sence as the rod can not move to select gears. Logic says that the selecter lever at the transmission should be fully to the rear (in Park) which will then allow the rod to move forward and select the appropriate gear.
Is there an issue which my transmission set up.
I have not tried to connect the shifter and selector via the rod as I am not sure what damage I may cause.
#2 _lx5008_
Posted 28 January 2010 - 11:33 AM
Posted 28 January 2010 - 12:01 PM
The lever on the gearbox points up on a floor shift setup.
Therefore the following statement can not be true for both.
I have been told that the gear selector lever on the transmission is in the park position when it is fully pushed forward.
I suspect that when the gearbox lever is in the floor shift position all the way back is the park position.
To confirm the park gearbox lever position, move the lever all the way back then try and turn the tail shaft. Then move the lever all the way forward and try and turn the tail shaft.
The manual shows two part numbers for the gearbox lever. One for the column shift and one for console shift.
Edited by ls2lxhatch, 28 January 2010 - 12:11 PM.
#4 _1ARC_
Posted 28 January 2010 - 02:53 PM
I think that this is where the confusion is with what I was told.
I will now connect the shifter rod and lever external control with the lever external control fully to the rear. I will also test with tyring to rotate the tail shaft with the above connection.
Thanks for the responses.
Posted 28 January 2010 - 05:21 PM
That is definitely correct, the person who told you the wrong thing must have been a little confusedI agree that the lever external control (located at the transmission) for floor shift must be fully to the rear to be in park.
Edited by 76lxhatch, 28 January 2010 - 05:21 PM.
#6 _1ARC_
Posted 28 January 2010 - 06:22 PM
Thanks 76lxhatch
