hawks uc sunbird
#251
Posted 04 December 2011 - 08:39 PM
#252
Posted 05 December 2011 - 04:15 PM
first i replaced the inlet manifold gasket and we ground down the extractors so the washers sat flat against them and the inlet manifold
then i was helping my grandma so i had roof racks on it for a day lol
heres some pics of it at the maroondah dam run next to brads uc
the rear bushes that failed and were replaced
then yesterday my front wheel nuts came loose and i lost the front wheel and snapped a stud off the front guard is rooted
#253
Posted 05 December 2011 - 04:22 PM
the missing stud
the disc
and all stripped back getting new ball joints and lower arm bushes
should have the lower arm bushes done tomorrow and hopefully ball joints by the end of the week. i have a spare disc and disc guard so they will go on then it all goes back together, both sides are getting the same done.
I'm not sure yet but i may also do the wheel bearings and sway bar bushes.
hopefully its drive-able again by the end of this week or sometime next week
#254
Posted 06 December 2011 - 07:18 PM
#255
Posted 08 December 2011 - 09:22 AM
#256
Posted 08 December 2011 - 05:56 PM
#257
Posted 08 December 2011 - 06:01 PM
#258
Posted 09 December 2011 - 09:08 PM
#259
_CHOPPER_
Posted 09 December 2011 - 09:55 PM
#260
Posted 09 December 2011 - 10:20 PM
#261
_mick74lh_
Posted 09 December 2011 - 10:36 PM
If you mean just removing the shocker then you should be able to leave everything else assembled, unbolt the shock and slide it out the bottom. Should be just enough room to scrape the shock through the hole in the lower control arm.
#262
Posted 10 December 2011 - 06:54 AM
#263
_jay79_
Posted 10 December 2011 - 07:08 AM
#264
Posted 10 December 2011 - 08:09 AM
#265
Posted 10 December 2011 - 08:57 AM
#266
_UCV80_
Posted 10 December 2011 - 09:52 AM
#267
Posted 10 December 2011 - 10:24 AM
#268
Posted 11 December 2011 - 12:36 PM
#269
Posted 13 December 2011 - 09:28 AM
#270
_CHOPPER_
Posted 13 December 2011 - 10:54 AM
This of course is all an assumption.
#271
_mitchells74lhsltorana_
Posted 13 December 2011 - 11:30 AM
#272
Posted 13 December 2011 - 01:27 PM
#273
_CHOPPER_
Posted 21 December 2011 - 10:19 AM
#274
Posted 21 December 2011 - 10:41 AM
Lovells Fitting Instructions
Leave 1/4" to 1/2" space between the end of the coil and the spring seat pocket. This will help prevent spring noise when encountering large bumps.
#275
Posted 21 December 2011 - 10:47 AM
