LX Hatch RB30 Turbo
183 replies to this topic
#151 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 25 June 2012 - 09:07 PM
I could probably do one of 3 things to get into the 9's.
1, change the diff gears from 3.25 to 3.5.
2, get dominator to build a better stall
3, get a hard tune on c16 or e85 and turn up the boost to 30+ psi.
or i do all 3, but for the moment i'll leave it how it is.
Also built myself a car trailer, sick of hiring dodgy servo trailers.
Made the guard fold down for more door clearance.
Quick tie down for the front wheels.
#152 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 25 June 2012 - 09:36 PM
Any chance of a tech drawing for that trailer?
#153 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 25 June 2012 - 09:45 PM
If i get a chance i'll start a thread on it with all the measurements and material that i used.
#154 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 25 June 2012 - 10:22 PM
legend!!!
#155 _Viper_
_Viper_
Posted 25 June 2012 - 11:17 PM
x2
Any idea how much it weighs?
#156 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 26 June 2012 - 07:16 PM
The trailer weighed 620kgs without the spare tyre, the deck is 4000x1900mm and the draw bar is 1600mm.
Edited by turbo76lx, 26 June 2012 - 07:17 PM.
#157 _Viper_
_Viper_
Posted 27 June 2012 - 12:11 AM
Towed anything on it yet? How does she feel
#158 _j.e.d._
_j.e.d._
Posted 27 June 2012 - 12:55 PM
Just saw this mate....
http://www.youtube.c...h?v=P0_fa0KvBBU
#159 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 27 June 2012 - 09:40 PM
That was taken at last years Show us your wheels at Numurkah and yes i am that ugly.
Clint, i've had a v8 HJ station wagon on it behind my vy wagon and it towed good and had the torana on it behind my
dads GQ patrol and could hardly tell it was there. I used slipper springs not rocker springs.
I find the rocker springs make the trailer bounce more.
#160 _BARRY JACKPOT_
_BARRY JACKPOT_
Posted 27 June 2012 - 10:04 PM
I'm down for some plans too, what a great looking trailer.
#161 orangeLJ
Posted 28 June 2012 - 01:26 PM
+1 on the trailer plans and dims.
Just about to embark on a similar project (well, between now and the end of the year)
#162 RBTORY
RBTORY
  • 133 posts
  • Car:lj 2 door / RB30ET
Posted 29 June 2012 - 12:20 AM
Turbo76 great to hear shes doing some numbers now. Finally got mine engineered ended up using boneville consulting, great guy to deal with, anyway enough about me, what about wheelspin is that slowing you down at all?
#163 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 29 June 2012 - 06:15 AM
Hi Andrew, good to hear you got yours enngineered and found a good engineer to deal with.
No wheel spin off the line yet, letting the transbrake go at between 4800-5200rpm you feel it bite hard then die off a bit.
That's why i'm thinking new diff gears or a stall.
#164 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 29 June 2012 - 05:19 PM
Started the trailer build thread in fabrication section. Be patient it may take a few weeks to put all the info up.
http://www.gmh-toran...ld/#entry683888
#165 RBTORY
RBTORY
  • 133 posts
Posted 29 June 2012 - 09:53 PM
Yeah it could be the gears boging it down a bit, sounds likes its a weapon still!
#166 _TRBOLJ_
_TRBOLJ_
Posted 19 May 2013 - 09:13 PM
hey mate love the set up. Mine is almost identical in a LC. Hopefully will be at JPC in the next few months getting tuned. Have you had any problems with cooler piping blowing off? Mine looks a little tight coming out of the trottle body and into the cooler.
#167 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 20 May 2013 - 07:43 PM
Hi, haven't had any pipes blow off, but haven't pushed it over 26 psi yet.   ;)
#168 _jabba_
_jabba_
Posted 21 May 2013 - 11:24 PM
Hey, does your ecu support some form of launch control. With your foot on the brake you can cut x spark from y events and dump loads of fuel in there and build a shitload of boost... It can also retard the ignition timing to after tdc to really spool her up.
#169 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 22 May 2013 - 07:11 PM
The vipec can do anti lag but the extra heat you put into the turbine can kill the turbo faster.
#170 _jabba_
_jabba_
Posted 23 May 2013 - 12:45 AM
Yeah fair enough, sounds fun tho ha.
#171 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 16 August 2014 - 07:15 PM
Pulled the stall out today, going to get a new one built. hopefully this will get me into the 9's.
#172 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 20 October 2014 - 07:29 PM
Went to Heathcote a few weeks ago to try out the converter, done a few passes, felt better off the line but a bit slower on the mph.
Then 2 runs back to back, on the second run about 3/4 track I seen blue smoke behind me. So take it home, motor out, head off to find this.
Drained the fuel tank by turning the fuel pumps to find out it sucked the surge tank dry with in 20 second,
so I disconnected the carter black lift pump to find it was only flowing about 1 litre per minute, it should flow about 350 litres an hour,
I still need to pull out the pre filter and check that. So I think the back to back runs have not let the surge tank refill and it's leaned out.
#173 WA1TNC
WA1TNC
  • 358 posts
  • Name:Nig
  • Car:HX ute(daily) LH Torana(Harrop Blown LS1) in the build
Posted 21 October 2014 - 10:10 PM
Bummer mate, that's always been a concern of mine with surge tanks when your foot gets heavy in quick concession. Is there a way that you can integrate a warning light hooked up to a sensor inserted into the bottom 1/4 of the surge like an oil level sensor for your engine?
Just thinking....
Cheers, Nig.
Edited by WA1TNC, 21 October 2014 - 10:11 PM.
#174 MictheAussie
MictheAussie
  • 235 posts
  • Name:Mic
  • Car:LJ
Posted 22 October 2014 - 10:54 AM
Here is your answer to surge tanks:
http://aeromotiveinc...om-fuel-system/
#175 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 20 September 2015 - 07:57 PM
Got the motor back the other week, changed out the "H" bean rods for a set of nitto "I" beam rods and some custom CP pistions with upgraded wrist pins.
Also gone with a Ross full race balancer with the tooth wheel to run a crank sensor pick up and need to make a mount for a cam sensor.
I have run a second -6 fuel line and changed the pick up and the position of the fuel filters.
