Is there any other difference between a UC cable clutch pedal and a rat trap LH style pedal besides the uc having the hook on the top and is it possible to modify the top of the LH one to enable a uc cable clutch setup?
cheers dennis
clutch pedals
_SLR Goat_
, Feb 07 2010 09:35 PM
4 replies to this topic
_SLR Goat_
Posted 07 February 2010 - 09:35 PM
Posted 07 February 2010 - 10:30 PM
AFIK you can mod them, Toranamuk sells both the hook for the mod and the completed pedal, 6 and 8cyl.
Edited by TerrA LX, 07 February 2010 - 10:34 PM.
_SLR Goat_
Posted 08 February 2010 - 03:57 PM
This is the pedal i have i did some measuring and the hole in the bracket is just about the same position as the hook on a uc one so if cut and a slot for the cable in theory it should work right? its a m20 behind a red 6 in a uc
cheers dennis
cheers dennis
Edited by SLR Goat, 08 February 2010 - 03:59 PM.
Posted 10 February 2010 - 11:45 AM
Yes that is what I used to do.
Just remember the OEM cable does not take much abuse, any miss alignment or extra stress from differing leverage angles from OEM will end with snapping cable ends.
_SLR Goat_
Posted 10 February 2010 - 05:51 PM
Cheers for the heads up tho it dosent look like im going that way now ive found a complete setup out of a uc i can use
