spay gun tip sizes for acyrillic
_beergut_
Posted 09 February 2010 - 06:16 PM
just wondering what tip sized gun i should buy to spray acyrillic
gravity feed is my weapon of choice
tanks
al
_yldlj_
Posted 09 February 2010 - 07:24 PM
_beergut_
Posted 09 February 2010 - 09:11 PM
saved me some $$$$
i might owe you a beer or two
lol
_yldlj_
Posted 09 February 2010 - 09:33 PM
_beergut_
Posted 09 February 2010 - 11:43 PM
but at least i know i can use this one till then and not have to buy tips or anything for it
and when i go shopping for a new one i know what to get
cheers for that cuz
Posted 10 February 2010 - 05:25 AM
_MYLJ_
Posted 10 February 2010 - 07:47 AM
Is a 1.4mm tip a bit small for acrylic lacquer?
yes 1.4mm is a bit small for acrylic,
you can use a 1.4mm but it will take longer and can lead to other problems,
I'd recommend at least a 1.8mm tip, and for some heavy metalics I go even bigger.............
Posted 10 February 2010 - 08:35 AM
_yldlj_
Posted 10 February 2010 - 07:38 PM
_yldlj_
Posted 10 February 2010 - 08:30 PM
how caould it be all overspry and dry? don't you have air pressure? 1.4 tip applys nice, thin and wet well when i'm spraying anyway. all the spraypainters at my work suggest 1.4 for all types of top coats. 1.8 is used for primers especially 2k hifill, puts it on nice and thick.
Posted 10 February 2010 - 08:41 PM
FYI at TAFE we were taught with a 3mm gun on acrylic, I could not believe it myself but the results spoke for themselves.
I am a firm believer in bigger is better.
_Pete_
Posted 10 February 2010 - 09:07 PM
2K Basecoat = 1.2mm,1.3mm,1.4mm,1.5mm tip
2K Solid & Clear = 1.3mm, 1.4mm, 1.5mm tip
Acrylic Primer = 2.0mm tip
2K Primer = 1.8mm or 2.0mm tip
Plenty of people will tell you what they have used or gotten away with in the past, the above are typical recommendations or guidelines that will get you going in the right direction.
Using a smaller tip like a 1.4mm with Acrylic Lacquer will require you to thin down your paint a hell of a lot to get it to flow out of the gun nicely, when you over thin it will not only take you longer to get any decent coverage with a low solid style paint like Acrylic you can also run into bigger problems like solvent boil and the thinners biting into the substrate and making it fry up leaving you with a big mess to have to sand out and start all over again. Then there's also the very good chance if you are a beginner that you won't be able to acheive a decent finish.
A 3.0mm tip is like a bloody Garden hose.....and is really only useful for painting Spray Polyester, using a monster tip like a 3.0mm will run a beginner into plenty of problems too.
Spray Guns are getting so cheap to buy these days, get yourself a 2.0mm tip gun if you want to have the least hassles/risk and concentrate on getting a good finish. And you might get lucky with buying a cheap gun and get one that will flow paint but if you spend some money on a good quality gun you will get better results.
Posted 10 February 2010 - 10:20 PM
_beergut_
Posted 10 February 2010 - 11:12 PM
explained another problem i had
looks like i might buy another tip after all
Posted 10 February 2010 - 11:23 PM
Agreed with Petes size recommendations.
Me too.
Posted 11 February 2010 - 03:51 PM
Posted 11 February 2010 - 04:21 PM
_beergut_
Posted 11 February 2010 - 10:06 PM
thanks again for the advice
_UCV80_
Posted 15 February 2010 - 03:02 PM
_beergut_
Posted 15 February 2010 - 08:50 PM
see if i can look at one in the flesh at my dealer
got my primer gun and probaly use it as a top coat gun on this project as it's only a bog and flog deal
#21
_gtr161s_
Posted 22 February 2010 - 04:24 PM
Thought he was nuts, I found that the gravity gun kept giving me a dry look, tried the pot gun and it was a totally different look...much much wetter.
#22
Posted 23 February 2010 - 01:13 PM
going on recent advice from my pain supplier...
so whats her name kev??? shocked to read that your into B&D mate
