Super cheap 560kg engine stand...... dodgy?
33 replies to this topic
#1 _bradman_
_bradman_
Posted 16 February 2010 - 09:09 AM
Hi guys,
I was looking for an engine stand for my 308 so i went to supercheap and brought the largest one they had (560kgs..... $189)
Got it home put it together tightened everything up and put the 308 on it.
Even with just the block i noticed and huge amount of leaning on the stand but thought it was normal so put on heads and manifold, Now it looks to me like it wants to snap and is impossible to turn over as the way the engine leans forward make it too hard.
Even with just the block it was quite hard to turn......
If you just touch the engine it bounces very slightly on the stand for ages,
Should i take it back??? or is this normal?
Cheers Brad
That pole that holds the engine was straight before the engine went on.
Edited by bradman, 16 February 2010 - 09:11 AM.
#2 Statler
  • 6,318 posts
Posted 16 February 2010 - 09:20 AM
That doesn't look right!
Can you reverse the upright?
I have my 308 [complete] on a stupidcheap stand. It is still diffficult to roll it, but it doesn't look like that!
#3 _Big T_
_Big T_
Posted 16 February 2010 - 09:21 AM
Doesnt look normal to me and I dont even have an engine stand. I wouldnt have thought there would be so much lean. Doesnt look like there is much bracing of the main pole either, just a bracket and a couple of bolts.
#4 Rockoz
Rockoz
  • 4,035 posts
  • Name:Rob
Posted 16 February 2010 - 09:28 AM
Looks like poor design work.
I got the cheaper one and it isnt bad.
#5 GML-31
Posted 16 February 2010 - 09:41 AM
i think I would be removing it from there asap, doesnt look good to me at all
#6 gtrboyy
gtrboyy
  • 3,214 posts
Posted 16 February 2010 - 09:44 AM
I got one that looks similar from rare spares,doesn't bow that much at all.Annoying thing I found was that it didn't bolt up properly to turbo pattern blocks...had to modify it a bit & get different bolts.
#7 76lxhatch
  • 7,208 posts
Posted 16 February 2010 - 09:47 AM
Are you sure the upright doesn't just go on the other way around? It would normally have some lean backward to make up for flex with the weight on it.
I have one of the cheapie versions rated at 340kg or so, I've hung plenty off it and it has been fine. Its not perfectly straight but welds and steel are up to the task.
#8 GML-31
Posted 16 February 2010 - 09:49 AM
^^^ after having a good look at pic I agree the upright is bolted wrong way around, its not getting any back support that way
#9 _bradman_
_bradman_
Posted 16 February 2010 - 09:59 AM
I'll go and check it now......i currently have it supported with my engine crane
Just checked it and the pole is the same on both sides, exactly the same? even double checked it with the tape measure? i have had a look through the instructions and it doesnt mention anything on there?
Maybe i should send an e-mail to super cheap with the picture?
Cheers Brad
That support pole is the same on both sides, the back is the same as the front
#10 GML-31
Posted 16 February 2010 - 10:03 AM
yes but the angle it is bolted on with should be on the back not front
#11 76lxhatch
  • 7,208 posts
Posted 16 February 2010 - 10:52 AM
^ Yep if it will spin around 180 degrees then that will be it
#12 _bradman_
_bradman_
Posted 16 February 2010 - 11:55 AM
The angle is on both sides? If you pulled it off it looks the exact same at the bottom.
2 angles 1 each side
Edited by bradman, 16 February 2010 - 11:56 AM.
#13 Collo
Collo
    ( . Y . )
  • 114,647 posts
  • Car:A Black POS
Posted 16 February 2010 - 12:00 PM
Turn the vertical post around so it's angling backward.
#14 _bradman_
_bradman_
Posted 16 February 2010 - 12:35 PM
ok turned it around....heres what happened
Ahhhh now it looks even worse,
Contacted super cheap going back for refund,
Went to auto barn and the ones there are the exact same as this one :Headbang2:
Edited by bradman, 16 February 2010 - 12:36 PM.
#15 76lxhatch
  • 7,208 posts
Posted 16 February 2010 - 12:46 PM
So without the engine on the upright is perpendicular?
It is a bit of a strange design as there's not much at the bottom of the upright to support the weight, most would have the front wheels attached to a single centre support so the base is an H pattern rather than an open square.
#16 _bradman_
_bradman_
Posted 16 February 2010 - 12:52 PM
Yeah it is straight mate,
I know very crap design they are usually the t shape
#17 _beergut_
_beergut_
Posted 16 February 2010 - 01:31 PM
mine don't do that and it's a el cheapo (not super crap but_)
defentily something wrong there
looking at the photos again even the legs look bent
oh and demand cash off them i'm still waiting for a week for those
arrogount basterds to refund $$$ into my account
Edited by beergut, 16 February 2010 - 01:41 PM.
#18 myss427
myss427
  • 1,636 posts
Posted 16 February 2010 - 01:55 PM
I have a super cheap one which I use as a rotisery and its straight. Must have got a bad one!
#19 _UCV80_
_UCV80_
Posted 16 February 2010 - 02:10 PM
Everything from supercheap auto is junk! Everything.. and its also now one of the most expensive places to go.
I always keep my recipt when i shop there, iv been through a couple of orbital sanders haha, as long as they keep breaking ill keep bringing it back. There own fault for selling inferior products. The amount of stuff I have had to refund is unreal.
#20 TerrA LX
Posted 16 February 2010 - 02:16 PM
Try a tool supplier.
#21 mr5000
mr5000
    chief break-everything
  • 3,455 posts
  • Car:77 lx 4door
Posted 16 February 2010 - 04:11 PM
get the folding one they had at supercheap looks like mine that i got from fjs discounts and its solid as doesnt even dip with a 308 on it
#22 Swarbs
Swarbs
  • 1,671 posts
  • Car:LX 5000
Posted 16 February 2010 - 04:12 PM
Looking at that is like watching a trip to spinal rehab unfold
Take it back and wrap it round their ears
The whole weight of the motor is flexing against that 1 weld. -- which was probably done by a 10 year old in a sweat shop wearing thongs
I would personaly get that off the stand before it ends in tears - or hospital
(Cant believe these company's get away with this type of sh*t)
#23 Ice
  • 15,204 posts
Posted 16 February 2010 - 06:06 PM
What do you expect made in f@#%$^& china stupid cheap autos sell crap part from ryco and a few other parts the rest is for ricers.
#24 _bradman_
_bradman_
Posted 16 February 2010 - 06:14 PM
I agree with you 120%
Im worried that some one out there will buy one and have it fall on them!
Imagine the damage it would do to your foot.
Super cheap i must admit were pretty kool with me bring it back although i would hate to see one collapse on some one.
For $189 clams i wasnt expecting it to bend like that, but i agree alot of their stuff now is crap and expensive!
#25 _uncleian_
_uncleian_
Posted 16 February 2010 - 06:22 PM
upright is backwards and the engine mounts are on upside down..................motor is sitting way to high
