![](https://secure.gravatar.com/avatar/d41d8cd98f00b204e9800998ecf8427e?s=100&d=https%3A%2F%2Fwww.gmh-torana.com.au%2Fforums%2Fpublic%2Fstyle_images%2Fblackstream%2Fprofile%2Fdefault_large.png)
15x 8 and 15x10 Tyres, What size?
_markbeath_
Posted 16 February 2010 - 09:16 AM
Iv got 15x8 rims for the front of my Torana and 15x10 for the rear. The car will be flared when i put the wheels on and just wondering what size tyres people are running as i have no idea what size to go with. Photos would be great as well.
Mark Beath
Posted 16 February 2010 - 09:55 AM
_markbeath_
Posted 16 February 2010 - 10:12 AM
the best rear tyres are the 285-40-15 matched to 225 50 15 on the front. the 285's are expensive howverever there was a set on ebay recently I believe.
Thanks for that REDA9X. So these fit well under the flared guards?
_89'King_
Posted 16 February 2010 - 10:28 AM
Posted 16 February 2010 - 10:33 AM
You could also go for a 295/50, but they might be a squeeze. 285's and 275's are more uncommon which means very $$$$$$$$$$$$$$$$$$$$$$$$$$$
Posted 16 February 2010 - 10:52 AM
Yep, the 285/40 mentioned above would be nicer on the rear but you need deeper pocketsMost common size people will run are a 265/50 and a 225/50.
_markbeath_
Posted 16 February 2010 - 10:54 AM
Posted 16 February 2010 - 11:07 AM
if you run a 265 50 15 on the rear the wall height is 132.5mm
if you run a 225 50 15 on the front, the sidewall height is 112.5mm
a 285 40 is 114mm
whatever you decide to use, you need to conside what the sidewall is going to look like, and how the front tyres will go when you turn the wheel.
you could be up for about $1500 or more for a set of 285's
Posted 16 February 2010 - 11:10 AM
Posted 16 February 2010 - 12:22 PM
Supplied in Perth
Posted 16 February 2010 - 01:15 PM
_markbeath_
Posted 16 February 2010 - 01:26 PM
Posted 16 February 2010 - 01:48 PM
Posted 16 February 2010 - 02:49 PM
I've got the same size wheels on my hatch - modified GTS rims, front 15 x 8 and rear 15 x 10.
Running 225 x 50 x 15 on the front and 265 x 50 x 15 on the rear.
Here's a photo,
Mick.
![Posted Image](https://cache.gmh-torana.com.au/i72.photobucket.com/albums/i189/lxsstorana/torana383045.jpg)
_markbeath_
Posted 16 February 2010 - 02:54 PM
Hi Mark,
Here's a photo,
Mick.
Thanks for that Mick. Any chance you have a behind shot?
Posted 16 February 2010 - 03:10 PM
![Posted Image](https://cache.gmh-torana.com.au/i72.photobucket.com/albums/i189/lxsstorana/torana383038.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i72.photobucket.com/albums/i189/lxsstorana/torana383039.jpg)
Posted 16 February 2010 - 03:34 PM
By the way..NOICE!! Mick....(wasnt it white before???)
Edited by rorym, 16 February 2010 - 03:35 PM.
Posted 16 February 2010 - 03:42 PM
The white hatch is still white. I'm like you a multi car owner, the grey hatch is a work in progress (very slow though).
You're right about the height difference, definitely higher in the rear.
I'd like the car to be about 20mm higher in the front and would have preferred a wide 60 series tyre but couldn't find me.
Cheers Mick.
Here's a photo to prove they are not the same car.
![:lol:](http://www.gmh-torana.com.au/forums/public/style_emoticons/default/laugh.gif)
![Posted Image](https://cache.gmh-torana.com.au/i72.photobucket.com/albums/i189/lxsstorana/SS383043-1.jpg)
Posted 16 February 2010 - 06:09 PM
![Posted Image](https://cache.gmh-torana.com.au/i190.photobucket.com/albums/z244/v8comp/Torana/dscn0114.jpg)
It would be nice to sit a bit more level but I've never seen one that does due to the differences in width and the available space front and rear
Posted 16 February 2010 - 06:39 PM
Hi Rorym,
Cheers Mick.
Here's a photo to prove they are not the same car.![]()
You capitalist !!...owning 2 hatches!!......Can I come over and steal one?..Hang on...you are with the constabulary...I might re-think that one..Lol!
Nice mate.
Posted 16 February 2010 - 08:12 PM
Hi Rorym,
Cheers Mick.
I was about to say, YOU BASTARD! You got two hatches!
Then I remembered I have two myself! HAHA!!! (Granted the SS aint even close to yours!)
![Posted Image](https://cache.gmh-torana.com.au/i29.photobucket.com/albums/c257/253ToranaSS/NewHouse/25102009143.jpg)
Then there is a 3rd Hatch in the shed too... LOL
#22
Posted 16 February 2010 - 08:53 PM
#23
Posted 16 February 2010 - 10:06 PM
tell me more about the hatch in the back of the shed
http://www.gmh-torana.com.au/forums/index.php?showtopic=18968
Enjoy the read! I might have a read over it again and get some motivation!
#24
Posted 24 February 2010 - 02:50 PM
225/50, but fronts are only 7" wide (need 8" ones!)
Hey mate, with your 225/50's, why would you prefer 8's on the front rather than 7's. You want less sidewall bulge, better handling, more dish???
The reason I ask is that I'm planning to buy a set of fronts for mine at some stage in the future. I want to keep my cheese-cutters (15 x 4's) just for drags, and run either 15 x 7's or 8's on the front for day to day driving. I want to run 225/50's, so it's just a matter now of deciding if I buy 7" rims or 8" rims!
#25
Posted 24 February 2010 - 07:30 PM
It used to have 8s before I changed the wheels and these were advertised as 8s but found they were only 7s when I received them. The upside of the narrower wheel is that bringing the outside of the tyre in a bit means less issues with clearance. I'd like to go to an even wider tyre at the same time but I'd start having to make more serious metal changes to clear at full lock.
I'd say buy whatever is going to best match the look of your rear wheels and tyres.
