LX sedan + left over parts
#51
Posted 18 March 2010 - 06:19 PM
I have "repaired" a few locks, though only damaged ones and all I did was threw out the offending bent/worn plate/s.
Kids cars.
#52
Posted 27 March 2010 - 09:51 PM
Got keen/ bored today so pulled out the motor, if anyone is interested the measusrment from the fire wall above the "lip" to the back of the motor is 78mm with the modified mounts.
IMGP0747_resize.JPG 130.91K
2 downloads
Also put the car up on the rotator, the best thing i ever made.
IMGP0750_resize.JPG 160.28K
2 downloads
IMGP0751_resize.JPG 159.5K
3 downloads
I know it's over kill with 75mm bearings and a 100/1 gearbox but it makes life easier.
IMGP0748_resize.JPG 149.1K
3 downloads
IMGP0749_resize.JPG 181.47K
2 downloads
Edited by turbo76lx, 22 October 2017 - 10:56 AM.
#53
_nial8r_
Posted 29 March 2010 - 06:56 AM
#54
Posted 03 April 2010 - 07:19 PM
Found something i didn't want the other day when i took the sump off, rust over the crank, rods and in 2 cylinders. I knew when i
brought this motor for $700 it was to good to be true. So pulled the heads off and cam out, thankfully ok and draged out a old 308
that only needed rings and bearings, after a quick (cheap) rebuild now have a motor ready to go.
Today relocated the shock mounts on the diff using the brackets of a VN diff, now i will use HQ rear shockers and will give enough
room for a VN rear brake conversion.
IMGP0768_resize.JPG 158.07K
4 downloads
IMGP0769_resize.JPG 155.24K
3 downloads
Edited by turbo76lx, 22 October 2017 - 10:57 AM.
#55
Posted 03 April 2010 - 07:44 PM
Started on the rust behind the bonnet hinges, the only way to fix it is cut it all out.
IMGP0772_resize.JPG 151.21K
3 downloads
Had to cut more than i thought. Before i cut it all out i scribed a line through the centre of the hinge holes and took some measurements.
IMGP0773_resize.JPG 168.85K
2 downloads
Clamped some sheet behind the hole and made a scribe mark then cut it out. You can see the scribe line between the 2 black arrows for the bonnet hinge holes.
IMGP0775_resize.JPG 158.09K
2 downloads
Tacked in the new piece and marked the hinge holes and a quick hammer. This is as far as i get because i ran out of gas for the tig.
IMGP0778_resize.JPG 170.75K
2 downloads
Edited by turbo76lx, 22 October 2017 - 11:02 AM.
#56
_nial8r_
Posted 04 April 2010 - 11:36 AM
#57
Posted 04 April 2010 - 07:26 PM
Yes the rust was nasty but the rest of the car is rust free.
Decided to give the back tyres a bit more room, cut out a small section at the rear of the tub and moved it into the rail.
I did have to stop myself from cutting the entire wheel tub out and starting from scratch, but it's only going to be a daily driver.
IMGP0781_resize.JPG 173.5K
6 downloads
IMGP0782_resize.JPG 153.82K
6 downloads
IMGP0783_resize.JPG 168.9K
8 downloads
Now can just fit a 265 tyre but still needs some more work.
IMGP0786_resize.jpg 122.88K
3 downloads
Edited by turbo76lx, 22 October 2017 - 11:04 AM.
#58
Posted 04 April 2010 - 08:14 PM
#59
_nial8r_
Posted 06 April 2010 - 08:29 AM
#60
_Apotheosis_
Posted 06 April 2010 - 10:32 PM
#61
Posted 07 April 2010 - 07:44 PM
#62
Posted 10 April 2010 - 08:56 PM
Got lazy so had all the suspension blasted also had some of my next projects suspension done aswell.
IMGP0793_resize.JPG 132K
0 downloads
Finished welding the pieces behind the bonnet hinges, filled some holes and hammered out where the brake lines go through the guards.
IMGP0799_resize.JPG 131.93K
0 downloads
Edited by turbo76lx, 22 October 2017 - 11:05 AM.
#63
Posted 02 May 2010 - 07:11 PM
All the suspension parts are now painted, no room to store then in the shed so put them in the spare room.
IMGP0801_resize.JPG 144.46K
0 downloads
Also painted under the car with KBS chassis paint, used gloss black but might put some satin black over it, just a bit to shiny.
IMGP0841_resize.JPG 150.9K
0 downloads
Edited by turbo76lx, 22 October 2017 - 11:06 AM.
#64
_nial8r_
Posted 02 May 2010 - 08:19 PM
#65
Posted 02 May 2010 - 09:01 PM
When i hammered/smashed out the inner they go through a stage of "how the hell am i going to fix this" but just kept hammering.
IMGP0791_resize.JPG 136.38K
2 downloads
IMGP0787_resize.JPG 135.41K
0 downloads
IMGP0789_resize.JPG 145.66K
0 downloads
Edited by turbo76lx, 22 October 2017 - 11:07 AM.
#66
_The Baron_
Posted 02 May 2010 - 10:37 PM
I also like the gloss black, maybe just used black tar, stone protector in the wheel areas to protect the paint.
You should mark up plans of the "rotator" as it looks so handy, maybe make up "rotator" kits and sell them but with a source your own jacks and gearbox option.
#67
_leej08_
Posted 11 May 2010 - 01:33 PM
#68
Posted 11 May 2010 - 09:19 PM
#69
Posted 23 May 2010 - 08:44 PM
Haven't been to motivated but have rebuilt the front end, all new bushes and ball joints. The front brakes are HQ discs and a mix of HX PBR and LX PBR calipers also rebuilt.
Had to lip the upper control arm to clear the caliper same as what i done to my hatch front end.
IMGP0844_resize.JPG 149.06K
0 downloads
Motor and gearbox also ready to go. Now need to find some more motivation to start the body work.
IMGP0846_resize.JPG 136.13K
0 downloads
Edited by turbo76lx, 22 October 2017 - 11:09 AM.
#70
_dirtbag_
Posted 23 May 2010 - 09:29 PM
I love watching your work progress.
#71
Posted 29 May 2010 - 09:04 PM
Painted the floor inside the car today and tryed to pick out the best doors. Yes i have been accumulating a few spares. Body work starts tomorrow.
IMGP0847_resize.JPG 150.76K
0 downloads
Edited by turbo76lx, 22 October 2017 - 11:10 AM.
#72
Posted 06 June 2010 - 08:15 PM
Been busy over the weekend taken most of the shell back to bare metal, what a fun job that is.
At least i didn't find to many surprises just a few small rust spots around the front windscreen and
above the LH rear wheel arch.
IMGP0848_resize.JPG 147.49K
0 downloads
Edited by turbo76lx, 22 October 2017 - 11:11 AM.
#73
_DomDom_
Posted 06 June 2010 - 10:16 PM
Keep it up and post more pics please.
#74
Posted 06 June 2010 - 10:41 PM
sh*t that sure is some nasty rust were the bonnet hinges go
Pretty standard rust for this model.
Loving the work in this thread.
#75
_TJ308_
Posted 06 June 2010 - 11:10 PM
