LX sedan + left over parts
#101
Posted 20 February 2011 - 08:56 AM
#102
_nicko61_
Posted 20 February 2011 - 11:52 AM
#103
Posted 27 February 2011 - 08:39 PM
Picked up a VDO electronic speedo yesterday at the Ballarat swap meet for $5 so i thought i might have a go at converting the
speedo. The bouns will be the R154 gearboxi'm going to use came with a speedo sensor.
I'm just using a set of standard guages.
IMGP1177_resize.JPG 177.18K
0 downloads
Speedos pulled apart.
IMGP1179_resize.JPG 110.46K
0 downloads
Filed the odometer on the original speedo to match the VDO one. Sanded the top of the VDO to fit and cut the rod for the calibration button off flush with the face.
IMGP1180_resize.JPG 167.88K
0 downloads
IMGP1182_resize.JPG 147.02K
0 downloads
Cut the back out of the VDO speedo and glued it into the instrument cluster and filled the tube for the high beam with fibre glass resin and drill a 8mm hole for a new high beam light.
IMGP1186_resize.JPG 106.79K
0 downloads
IMGP1185_resize.JPG 150.2K
0 downloads
Modified the needle and wired a remote calibration button that i will mount under the dash. All done.
IMGP1188_resize.JPG 126.79K
0 downloads
Edited by turbo76lx, 22 October 2017 - 11:28 AM.
#104
Posted 27 February 2011 - 09:12 PM
#105
Posted 14 March 2011 - 08:10 PM
The Dellow bellhousing turned up last week, had i problem with with the spigot bearing being 5mm to long. Also got the new clutch and pressure plate.
Had a 9" centre left over from my panel van build, a 3.5 LSD with a broken hat and worn clutches, done a quick rebuild using a 4 pinion single spinner.
Finally got the car off the rotator and back on its wheels, finished the last of the body work and got it in primer/filler.
IMGP1191_resize.JPG 156.77K
0 downloads
IMGP1192_resize.JPG 131.49K
1 downloads
IMGP1194_resize.JPG 109.29K
0 downloads
Edited by turbo76lx, 22 October 2017 - 11:29 AM.
#106
Posted 27 March 2011 - 08:25 PM
Finished rubbing the body back with 400 dry, the plan is to put some paint on it next weekend. The 31 spline axles turned up last week so decided to put the diff together,
but found a problem with the axles, so need to make a phone call on monday. I gave the brakes a clean up and set them up
You can see the room i have with the shock mounts moved to clear the calipers.
IMGP1201_resize.JPG 132.27K
2 downloads
IMGP1200_resize.JPG 122.22K
3 downloads
IMGP1198_resize.JPG 127.73K
2 downloads
Edited by turbo76lx, 22 October 2017 - 11:30 AM.
#107
Posted 01 April 2011 - 06:08 PM
Got some paint on the engine bay, the colour is "the lone o'ranger". Should get the rest of the body painted tomorrow.
IMGP1206_resize.JPG 138.73K
0 downloads
Edited by turbo76lx, 22 October 2017 - 11:31 AM.
#108
Posted 01 April 2011 - 06:47 PM
#109
_AD_75_
Posted 02 April 2011 - 12:52 PM
#110
Posted 02 April 2011 - 05:45 PM
Adrian, just going the full color.
Got the rest of the body paint today and pulled the old sub-frame out and put the sub-frame in.
IMGP1208_resize.JPG 173.17K
0 downloads
IMGP1209_resize.JPG 118.49K
0 downloads
IMGP1210_resize.JPG 162.13K
0 downloads
Edited by turbo76lx, 22 October 2017 - 11:32 AM.
#111
Posted 02 April 2011 - 07:30 PM
That's a Leyland Mini colour right? I love orange. Looke awesome! Well done.
#112
Posted 02 April 2011 - 07:46 PM
#113
Posted 02 April 2011 - 07:47 PM
Aside from that what shocks are you going to run with the new mounting points on the diff? Did you weld them on yourself? I will have to deal with the same issue myself. Also im impressed with the speedo. I have never seen that done before and think its a fantastic idea!
#114
Posted 02 April 2011 - 07:50 PM
#115
_wblje_
Posted 02 April 2011 - 08:08 PM
#116
Posted 02 April 2011 - 08:10 PM
ahhh yea... the Mini colour was 'Home On Th' Orange'
#117
_Quagmire_
Posted 02 April 2011 - 08:19 PM
It's an LJ and HQ colour, paint code 13135.
my first car (hq) was this orange
looked mint
til i frocked with it
#118
Posted 04 April 2011 - 08:00 PM
Got a few more things done, brake booster and master cylinder, fuel lines, front brakes and fuel tank in.
I cut the filler neck off the tank and fitted a VN filler only because i hate the way the original filler leaks fuel with a full tank when you nail it.
Also you can see where i am running the fuel return line from the surge tank.
IMGP1214_resize.JPG 112K
0 downloads
Edited by turbo76lx, 22 October 2017 - 11:33 AM.
#119
Posted 04 April 2011 - 08:13 PM
Good thinking!I cut the filler neck off the tank and fitted a VN filler only because i hate the way the original filler leaks fuel with a full tank when you nail it.
#120
Posted 10 April 2011 - 08:52 PM
Got the motor and gearbox in, it was a bit of a battle getting the gearbox in because the motor is moved forward the back of the motor wouldn't tilt down far enough
because the sump was sitting on the cross member. So had to sit the clutch and pressure plate on the input shaft then lift the gearbox in. Also brake, clutch and accelerator
pedals in, front brake lines. Made a gearbox cross member and gearbox adaptor to use a holden gearbox mount.
IMGP1218_resize.JPG 136.16K
0 downloads
IMGP1215_resize.JPG 99.1K
0 downloads
Edited by turbo76lx, 22 October 2017 - 11:36 AM.
#121
_Kush_
Posted 10 April 2011 - 09:08 PM
#122
_mick74lh_
Posted 10 April 2011 - 11:06 PM
#123
Posted 12 April 2011 - 09:27 PM
Well found another diff builder i will not be using again. Ordered 31 spline axles from Geelong diff services, spoke to him twice to confirm the order,HQ stud pattern and sipgot ( where the centre bore of the wheel mounts) with VN offset to run modified VN discs with HQ pattern.
When they turned up the spigot was 70mm not 71.3mm (HQ), so when i phoned him he said take them to a local machine shop and he would pay to have a sleeve put on the spigot to bring it up to 71.3mm.
After chasing around getting prices to have this done i thought i should ring him and make sure he was going to pay the bill.
He started whinging that the quote was to much and send the axles back and he would do them straight away and send them back the same day.
Sent them back on Thursday 31/3, Wedensday 6/4 i phoned him but he wasn't there, i was told that he would ring first thing the next morning, 10am the next day he still hadn't phoned so i rang him and was told the axles were in the lathe being done as we spoke. Finally the axles turned up today. Not once did he say sorry.
Now next time i want a 9" diff i'll go back to cutting the housings down myself and order parts straight from the USA.
So sick of being stuffed around by so called diff experts.
Edited by turbo76lx, 22 October 2017 - 11:37 AM.
#124
_Kush_
Posted 12 April 2011 - 09:37 PM
It would make you want to strangle him, then revive him so you can strangle him again.
Then revive him again and pour acid or bleach via funnel into his mouth until he suffers such severe pain until he passes away.......
I'm sorry about the vivid details, but that's what you want to do, isn't it!
That's why I'm doing everything myself on my own car....... So I don't end up in jail
Edited by Kush, 12 April 2011 - 09:41 PM.
#125
_dirtbag_
Posted 12 April 2011 - 09:51 PM
Excellent work as usual Glen!!!!
