LX sedan + left over parts
228 replies to this topic
#201 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 07 May 2015 - 09:58 PM
I'll see if I can get some photos on the weekend.
#202 SmacT
SmacT
  • 977 posts
  • Name:Sam
  • Car:LX 4dr 383, TKX, BW
Posted 07 May 2015 - 10:47 PM
Thanks Glen. I have an idea how best to do it, but am tipping you have a better/neater/awesomer solution than I can think of. :-)
#203 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 08 May 2015 - 07:56 PM
Sam this is how I mounted the seats, I based the mounting position off the rear out side original seat mounting hole to match the commodore mount I welded tow pieces of 50x6 flat bar on the front of the slides to pick up the original  and drilled a new hole through the floor for the rear inner.
IMGP2741_resize_zpsrjuwmlby.jpgAttached File  IMGP2741_resize.JPG   146.77K   1 downloads
Front outer.
IMGP2738_resize_zpswdprided.jpgAttached File  IMGP2738_resize.JPG   136.48K   1 downloads
Front inner.
IMGP2737_resize_zpslclkrv6a.jpgAttached File  IMGP2737_resize.JPG   129.77K   1 downloads
IMGP2743_resize_zpsofobpatn.jpgAttached File  IMGP2743_resize.JPG   139.38K   1 downloads
IMGP2744_resize_zpsku0ygmtj.jpgAttached File  IMGP2744_resize.JPG   134.3K   1 downloads
I machined up some mounts to go under the rear commodore mounts to set the angle of the seat, they are 17mm high and tapered down 5 deg.
IMGP2740_resize_zpsghcdwejn.jpgAttached File  IMGP2740_resize.JPG   100.85K   1 downloads
IMGP2742_resize_zpszlzumsua.jpgAttached File  IMGP2742_resize.JPG   147.6K   1 downloads
The passenger side mounts need a 20mm spacer in the inner commodore rail.
IMGP2745_resize_zps8lvhjwx4.jpgAttached File  IMGP2745_resize.JPG   123.79K   1 downloads
Edited by turbo76lx, 22 October 2017 - 12:20 PM.
#204 SmacT
SmacT
  • 977 posts
  • Name:Sam
Posted 08 May 2015 - 08:45 PM
Glen, thanks for the detail! That's great. And yes, better than I dreamed up. I can't machine anything myself, but I can get it done.
Appreciate the effort to do this, thanks.
#205 _76lxJAS_
_76lxJAS_
Posted 08 May 2015 - 09:01 PM
When I fitted harnesses I was told seat mounts and seat belt mounts had to have a 100mmx100mmx3mm plate under the car to bolt to. Not sure if this is still required or not?
#206 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 30 May 2015 - 07:54 PM
Fitted the central locking to the front doors, used the thin type actuator.
IMGP2761_resize_zpshzqa0unn.jpgAttached File  IMGP2761_resize.JPG   174.73K   1 downloads
20150504_170058_resize_zpsmdrg8h83.jpgAttached File  20150504_170058_resize.jpg   60.2K   1 downloads
20150504_170128_resize_zpsjazkuwhu.jpgAttached File  20150504_170128_resize.jpg   56.44K   2 downloads
Just clears the window regulator.
20150504_170014_resize_zpsiy5qg2s5.jpgAttached File  20150504_170014_resize.jpg   144.56K   1 downloads
Flipped the door lock nob rod to the other side of the mechanism so it's in-line with the actuator.
20150504_165549_resize_zps6fhfxrc9.jpgAttached File  20150504_165549_resize.jpg   121.09K   1 downloads
20150504_171044_resize_zpsypdue4q0.jpgAttached File  20150504_171044_resize.jpg   66.81K   1 downloads
Edited by turbo76lx, 22 October 2017 - 12:25 PM.
#207 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 30 May 2015 - 07:58 PM
Also fitted the front and rear windscreens, cut the mylar at 45 deg because I couldn't fit the corner pieces.
20150516_161737_resize_zps6xivofzy.jpgAttached File  20150516_161737_resize.jpg   89.75K   1 downloads
Edited by turbo76lx, 22 October 2017 - 12:27 PM.
#208 _jakeslxss_
_jakeslxss_
Posted 30 May 2015 - 10:08 PM
just a daily.... looks like a damn good daily!!
keep the updates coming cos were all loving the work that your doing
#209 _76lxJAS_
_76lxJAS_
Posted 31 May 2015 - 12:20 PM
nice work mate. i done the same with my mylars. i think it looks much better like that..
beware of the central locking how  it connects to the rod with them clamps. i have had a few cars over the years slip on them  and get stuck in the locked position,
#210 _mick74lh_
_mick74lh_
Posted 01 June 2015 - 02:07 PM
Fantastic as always!
#211 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 27 June 2015 - 09:37 PM
Got the seats re-trimmed, the fronts are vn HSV seats.
 IMGP2768_resize_zpsjapd14l6.jpgAttached File  IMGP2768_resize.JPG   125.18K   1 downloads
IMGP2769_resize_zps55vfjafr.jpgAttached File  IMGP2769_resize.JPG   110.73K   1 downloads
Random photos.
IMGP2788_resize_zpsmavpmzui.jpgAttached File  IMGP2788_resize.JPG   143.06K   1 downloads
IMGP2787_resize_zpsfbtkdxnk.jpgAttached File  IMGP2787_resize.JPG   135.92K   1 downloads
IMGP2786_resize_zpsnujgmtdi.jpgAttached File  IMGP2786_resize.JPG   119.03K   1 downloads
IMGP2785_resize_zpsmizijtow.jpgAttached File  IMGP2785_resize.JPG   142.82K   1 downloads
IMGP2784_resize_zpsog30fy73.jpgAttached File  IMGP2784_resize.JPG   113.76K   1 downloads
IMGP2783_resize_zps8htsdnwi.jpgAttached File  IMGP2783_resize.JPG   146.43K   1 downloads
IMGP2781_resize_zpssq5p1hlg.jpgAttached File  IMGP2781_resize.JPG   137.07K   1 downloads
Edited by turbo76lx, 22 October 2017 - 12:30 PM.
#212 _LS1 Taxi_
_LS1 Taxi_
Posted 28 June 2015 - 09:13 AM
Clean as a whistle!!
Awesome job Glen. I love how you've modded things but made it look original and only car guys would pick that's it's had work done.
Looking forward to seeing it out and about :)
#213 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 28 June 2015 - 07:49 PM
Running a Dakota Digital thermo fan controller which can run off the engine temp sender but I think it was coming on to late and is
not a true indicator of the radiator temp . From what I have read  it is better to have the sensor in the bottom of the radiator.
So I pulled the radiator out and welded in a bung and fitted a new sensor for the controller.
IMGP2791_resize_zpsidfpmjgw.jpgAttached File  IMGP2791_resize.JPG   119.31K   1 downloads
IMGP2790_resize_zpsql8yr7ff.jpgAttached File  IMGP2790_resize.JPG   136.83K   1 downloads
Edited by turbo76lx, 22 October 2017 - 12:31 PM.
#214 308mate
308mate
  • 523 posts
  • Name:scott
  • Car:76 SS hatch (Royal Plum, Chevron Chamois interior), HQish Van (Orchid Metallic)
Posted 29 June 2015 - 08:22 AM
Real clean, great daily! Is it rego'd?
#215 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 29 June 2015 - 08:29 AM
Not yet.
#216 axistr
axistr
  • 1,212 posts
Posted 29 June 2015 - 08:45 AM
Why not just use the engine E.C.M to control the fans, The E.C.M uses a earth output to control a relay(swaps from a positive to a negative) to trigger. Using the E.C.M  your fans will automatically cut out when the vehicle speed is over 55 kph, has much more advantages. I also wired in an override switch on the console but haven't look like needing it yet.
#217 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 29 June 2015 - 07:59 PM
I did set up the fans originally with one on a manual switch and the other one triggered by the ecu. I ran the car on the fan controled by the ecu only and the fan came on to late (97deg).
#218 axistr
axistr
  • 1,212 posts
Posted 02 July 2015 - 04:32 PM
When one of my fan relays on the hatch played up it started overheating at lights very quickly. Only had one out of the two fans pulling the air through the radiator. The new style fans we see these days pull the temp down very quickly. They only cut in for 30-40 seconds on the hatch and SLR even on a 40 deg day.
If you remove the radiator cap with the engine running on cars from the 90s up till today they will very quickly start to bubble and then boil over. The engines and cooling systems are designed to run between 95 to 105 degrees C . They do this to reduce emissions, if it wasn't for the pressure cap regulation the pressure all these cars would boil. The higher the pressure the higher the boiling temp.
I wouldn't get too excited about the fan cutting in at 97. However when I got the SLR E.C.M reprogramed I got them to set the E.C.M fan cut in at 93 and I fitted a 85deg thermostat. The heater works great during winter to. The original Torana temp gauge never gets over 1/4. 90-95
I used two individual 30 amp relays for the fans that the E.C.M controls and a third relay that triggers the two 30 amp fan relays so I could run the system through a manual switch on the consol. I have never had to use the over ride switch yet.
The other benefit running it through the E.C.M is the fans cut in automatically when my air conditioner compressor cuts in under 55 kph  to give more air flow over the A/C condenser and keep the cooling system temp stabilised. I don't even think about the temp anymore it's all done automatically, don't need to watch the temp at light and reaching for a manual fan switch like I had to in my early days.
Its just a thought as I have seen so many aftermarket fan controllers play up.
I am running a Ford EL twin fan setup on both cars with three core brass/copper Torana radiator.
#219 _mick74lh_
_mick74lh_
Posted 06 July 2015 - 09:18 AM
Love the interior mate. Looks absolutely wicked!
#220 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 11 July 2015 - 05:53 PM
Changed out the steering rag joint for the double knuckle so made a cotter pin remover out of some 50x25mm flat bar.
IMGP2795_resize_zpsviwefnta.jpgAttached File  IMGP2795_resize.JPG   135.4K   1 downloads
Ended up fitting a cat.
IMGP2794_resize_zpsvsapc8sj.jpgAttached File  IMGP2794_resize.JPG   132.75K   1 downloads
Got some centres routered out for the centre caps.
IMGP2799_resize_zpswtv1wval.jpgAttached File  IMGP2799_resize.JPG   124.96K   1 downloads
And now have twins. :D
IMGP2803_resize_zpskmyygup7.jpgAttached File  IMGP2803_resize.JPG   145.54K   2 downloads
Edited by turbo76lx, 22 October 2017 - 12:34 PM.
#221 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 19 July 2015 - 08:56 PM
I have found that there is a vibration over 100 kph I tried swapping the rear wheels which had no effect, then I checked the driveline angles.
The motor was 4.5 deg down to the rear and the pinion was 1.5 deg down, the pinion should be pointing up anywhere from 1 to 4 deg to match the engine.
So took a spare pair of lower trailing arms and shortened then 10mm which brought the pinion angle to 1.8 deg up which should be ok as I am running rubber bushes which under load the pinion should rotate up closer to the 4 deg required, but the vibration was still there. I checked the unis and found the rear had 0.6mm side play in the yoke so made two 0.25mm shims and fitted them each side of the caps, but still had the vibration.
I then set the car up on stands in the shed and ran it up to 100 kph with the wheels on and off, still had the vibration, I checked the tail shaft with a dial indicator and found it was out +/-0.35mm so put the two 0.25mm shims on one side of the yoke this brought it back to +/-0.08mm and no more vibration.
IMGP2804_resize_zpsvbwld6je.jpgAttached File  IMGP2804_resize.JPG   172.67K   1 downloads
Tyres between the car and bench just in case it come off the stands.
IMGP2805_resize_zpsjax32ez7.jpgAttached File  IMGP2805_resize.JPG   97.36K   1 downloads
Edited by turbo76lx, 22 October 2017 - 12:36 PM.
#222 tefa
tefa
  • 191 posts
  • Name:Teflon
  • Car:LX 4 Door SL
Posted 22 July 2015 - 08:53 PM
is it a custom tail shaft?
#223 turbo76lx
turbo76lx
  • 645 posts
  • Name:Glen
  • Car:LX
Posted 22 July 2015 - 09:20 PM
Yes 3.5" with 1350 series unis, the tail shaft was not the problem, one of the small side retainers on the diff yoke was worn or bent.
I'm changing the centre at the moment, 3.5 ratio is a bit to low so changing to the spare 3.25 with a detroit locker.
Made up a bracket to hold the centre on the trolley jack.
IMGP2816_resize_zpsdy5x4rng.jpgAttached File  IMGP2816_resize.JPG   142.76K   1 downloads
IMGP2814_resize_zpsycbopqmj.jpgAttached File  IMGP2814_resize.JPG   140.98K   1 downloads
Edited by turbo76lx, 22 October 2017 - 12:38 PM.
#224 _The Baron_
_The Baron_
Posted 22 July 2015 - 09:27 PM
Nice diff centre jig.
#225 Heath
  • 18,385 posts
Posted 22 July 2015 - 10:00 PM
hahaha your diff jig is awesome and I've never seen one before! Those steel/iron 9" centres are offensively heavy.
