oh and excuse the cut front gaurds. the D@#K head before me did the lovely cut job. i couldnt tell when i bought the car with flairs on....
My lowered spring dont look so low?
Posted 25 February 2010 - 04:29 AM
Posted 25 February 2010 - 05:43 AM
Is that pic with the engine in? Did you buy A9X style springs and put them in a front end with Torana stubs (A9X / HQ stubs are effectively drop stubs)
_uncleian_
Posted 25 February 2010 - 07:05 AM
Posted 25 February 2010 - 07:18 AM
Did you make sure the tail of the spring was located in the recession at the rear of the base?
Posted 25 February 2010 - 07:21 AM
_robrenjus_
Posted 25 February 2010 - 09:36 AM
The springs might not be seated properly in the lower control arm.
they can also be out at the top ,it would pay to get a torch and shine up into the xmember to make sure they are centralised. gee it looks to high even for that though!!
Posted 25 February 2010 - 11:03 AM
Thanks again
Edited by Torryhead, 25 February 2010 - 11:15 AM.
Posted 25 February 2010 - 01:17 PM
Posted 25 February 2010 - 04:21 PM
Posted 25 February 2010 - 09:42 PM
front of the car measurement from the body sill behind front wheel to the ground is 245mm
from the centre of the front hub to the ground is 295mm
back of the car measurement from the body sill in front of the back wheel to the ground is 238mm
from the centre of the back hub to the ground is 285mm
So if the front wheel is 10mm higher than the rear but the body is only 7mm higher then when i have equal wheel on, the front should be 3mm lower. how does that sound, bout right?? i did buy the 35mm lowered springs. i figure with 2 people in the car and all the engine bits in she might sit a little lower. heres a pic
Thanks again guys, saved my arse
Posted 25 February 2010 - 09:48 PM
just a quick question. do any of you blokes have a torry with 18's all round, want to shoot you some questions with regard to clearance. i did read ruts epic on mounting flares correctly and cutting the seam out behind the front wheel. the man is a genius. i'm about to tackle mine. advive would be great.
cheers,
Dan
_Gunmetal LH_
Posted 26 February 2010 - 04:21 AM
Maybe a little trick of the eyes?
Posted 26 February 2010 - 05:54 AM
One thing I would say is don't half-ass it. If you're going to cut, cut as much as you can behind the flares - you'll need all the clearance you can get.i did read ruts epic on mounting flares correctly and cutting the seam out behind the front wheel. the man is a genius. i'm about to tackle mine. advive(sic) would be great.
Posted 26 February 2010 - 10:37 AM
So whats with the car still sitting too high??? will it sink a bit more with radiator, brake bits and all the rest in the engine bay???? ARGHHHHH
Oh and my rear shortened 9 inch comes in at 1500mm wide disc to disc. have no idea what happened there....... supposed to be 1440 right???
Posted 26 February 2010 - 10:46 AM
Posted 26 February 2010 - 10:58 AM
Sorry mate but I'm with Heath, 18s are too big - mainly because you have to put such low profile tyres on the front to get small enough rolling diameter. Either that or they end up tucked in so far that the flares are pointless.Ok this would be the time where you all reassure me that 18 inch rims look good on the Torry!!! <snip> in all honesty what do you think?
Posted 26 February 2010 - 11:46 AM
and why is damn car still so high???
And here is the mag i want. guys i will gladly take advice on mags and suggestions so throw them at me........ any ideas you have, pics anything... i have to order these wheels tonight to have them ready for pick up when i get to Philadelphia in March so bombard me with suggestions. cheers,
Dan
Posted 26 February 2010 - 11:56 AM
Those five spokes are a nice style in my opinion, but they will look truly laughable in 18" OD on the front of a Torana. The only reason you have clearance is because the car is sitting so bloody high hahaha
Seriously stand back and look at that photo with the wheel on the front. Without meaning to offend - to me, that looks completely absurd.
Sorry I couldn't be of more help.
Edited by Heath, 26 February 2010 - 11:58 AM.
Posted 26 February 2010 - 12:04 PM
Any ideas as to why the car is still so friggin high??
Posted 26 February 2010 - 12:16 PM
Do those clear from lock to lock? Just because we don't like the look doesn't mean you're not allowed to, if you like them and they fit then go for it.
The main thing with front wheels is the compromise between diameter and dish, too much of either one or a combination of both will cause the tyre to rub on the firewall edge and/or front guard edge.
#21
Posted 26 February 2010 - 12:33 PM
I would personally, have all the wheels and stuff on, drive the car around etc, then work out how low i want it to sit, then go get my springs compressed or made up to suit.
#22
Posted 26 February 2010 - 01:24 PM
with my mates 18 inch grange wheel, its an 18 x 7 and it works lock to lock. the offset is wrong obviously so i took that into account and also that the wheel needs to be higher. the one thing i do need to do is remove the body seam behind the front wheel and i'll do that before the new wheels turn up. i'll do it like ruts did so there is no chance of scrub. also just need to double check the front flare. i think its ok. keep the feed back coming
i'm hoping the car does settle a bit well a lot. i did push down on the car it at went TWANG as the springs seated... in the thread further up i listed the front springs. do you know if they are the lowered ones? i might call them later and see.....
#23
_Gunmetal LH_
Posted 26 February 2010 - 02:18 PM
look at page 10 of 25
It says: 74-80 TORANA LH-UC 4 & 6 CYL A KHFL-44 KHFL-14
the KHFL-44 lowered and KHFL-14 as standard but these are for 4 & 6 cyl?
If that's the case then I doubt you have the KHFL-14's
#24
Posted 26 February 2010 - 02:19 PM
#25
Posted 26 February 2010 - 03:05 PM
