My lowered spring dont look so low?
#51
_BLACK DICE_
Posted 28 February 2010 - 09:05 AM
#52
Posted 28 February 2010 - 11:41 AM
1/2" UNF studs are Ford.
#53
Posted 28 February 2010 - 02:12 PM
i figured that if i had to change one i would go bigger so i was going to buy 1/2 inch for rear but last night i had all sorts of trouble getting my wheel nuts into my mates mag. he has 7/16 studs i think. i havent bought new studs yet for rear so i might go the 12mm on front instead.....
Black Dice, thanks for the info mate. man they are some big boots on the rear. i guess with the super lows you have to sacrifice travel and also have hard shocks. thats what i am trying to avoid. looking at the travel in my front end, i can afford to drop an inch and have a good ammount of travel left....... hopefully. whats you car like to drive, like a go cart or can you comfortably drive it all day??
Edited by Torryhead, 28 February 2010 - 02:21 PM.
#54
_evil UC hatch_
Posted 28 February 2010 - 03:39 PM
in my opinion King springs tend to be pretty firm, so using them on a Torana with a small sidewall tyre will result in a fairly harsh ride
#55
_BLACK DICE_
Posted 28 February 2010 - 08:30 PM
#56
Posted 28 February 2010 - 09:32 PM
hey just on the HQ stubs. will it change the geometry at all where it's not such a good idea cos i do have some HQ stubs and can have UPC provide the right adapter for the big brakes... also do i need to change steering arms???
#57
Posted 01 March 2010 - 12:22 AM
Dan
#58
Posted 01 March 2010 - 06:18 AM
#59
Posted 01 March 2010 - 11:43 PM
#60
Posted 02 March 2010 - 02:36 AM
#61
Posted 02 March 2010 - 06:35 AM
Had a quick look - you basically said front 7" wide with 5" backspace and rear 9" wide with 5.5" backspace. My thoughts:has anyone had a look at all the gobble i wrote about my wheel order, dimensions and offsets etc etc???? does it look alright?
The rears should fit OK, they would be tucked in about as far as they can go which might leave some excess space to the flare, but then that will help with clearance. Too big a tyre may get a bit close on the inside.
The fronts I'm not so sure about, seems like a lot of backspace on a 7" wheel. Obviously again you're looking for maximum clearance on the outside of the wheel but I suspect it could be very close to fouling on the inside. Someone else needs to comment here, probably more in the realm of the guys who use 7" wheels without flares.
#62
Posted 02 March 2010 - 01:02 PM
i think i'm being conservative because i really want to make sure the wheel fits up under the guard in the event that i lower the big girl...... just enough to have the tire sit up under.....
also i have effectively brought the wheel out half an inch and his whell worked lock to lock so i think i'm fine, cheers man
Dan
#63
Posted 02 March 2010 - 01:12 PM
#64
Posted 02 March 2010 - 05:55 PM
so let me know.
Dan
Posted 02 March 2010 - 08:32 PM
#66
_LH8VD69_
Posted 04 March 2010 - 09:13 AM
#67
Posted 05 March 2010 - 12:49 AM
just on the springs. i still dont know WTF is going on. looking at the front of the car the wheels and pulling in signifigantly at the bottom. it starts to level out with about an extra 160 kg (2 mates) in the engine bay with the donk but i wont be adding anywhere near that much extra weight. and being that they should be lowered 30mm you would expect the adverse reaction. so while i wanted to use drop stubs to get a little lower without sacrificing suspension stiffness and travel. i still need to get the god damn wheels at the right camber!!!!!!!!!
What is going on!!!!!!!
