How 2 keep dust out of your shed ?
_BlownOutlaw_
Posted 11 March 2010 - 01:54 PM
Has anyone tried to make their shed dust proof? and if so what did you do? was it a steel or brick shed? roller doors or other etc?
I have a steel shed. I didn't get a roller door because of the gap up the top where it rolls. So I made solid swing doors and I have got rubber strips glued to the edges to stop dusty air flow past the edges.
I have got spray expanda foam and squirted under all the corrugations in the roof steel near the gutters and ridge cap.
Ive tried screwing some of the corners in tighter to seal better with extra nuts and bolts.
Ive cemented around the edges of the tin, to seal the bottoms off and create a footpath in the process.
But I still get dust. Admittedly its a lot better now but I'd rather there was none.
Posted 11 March 2010 - 02:03 PM
Dust particles are generally so fine they will get around anything, plus, you have to open the door sometime! when you do, the dust comes in with the air and lingers, so when you close the door and there is no breeze, it simply settles on everything.
your clothes, the carpet and seats in the car, any mats or seats in the shed etc all have dust in them, so you wont ever stop it completely.
You could always try wetting the floor down all the time and running extraction fans+filters (turn it into a spray booth!
_mello92_
Posted 11 March 2010 - 02:13 PM
You cannot stop dust!
But, try to organise the shed so that you can hose down the walls and floor every now and then.
Dust in your shed usually means you need to use it more.
Posted 11 March 2010 - 02:14 PM
_uncleian_
Posted 11 March 2010 - 02:22 PM
Posted 11 March 2010 - 03:22 PM
Posted 11 March 2010 - 04:26 PM
_WOZ_
Posted 12 March 2010 - 07:28 AM
_LXATIV_
Posted 12 March 2010 - 01:16 PM
make the misses live in there
LMAO
_BlownOutlaw_
Posted 12 March 2010 - 01:56 PM
I was thinking of painting the floor, I think that would make it a bit easier to keep clean. Might look further into that.
I think i might need to do more with the expanding foam perhaps, seal off other areas where dust can come through.
Also some pink bats behind gyprock screwed to the walls may help too.
Edited by BlownOutlaw, 12 March 2010 - 01:57 PM.
_Genuine S_
Posted 12 March 2010 - 03:50 PM
