202 harmonics problem
#76
_70rey_
Posted 31 March 2010 - 08:46 PM
#77
Posted 02 April 2010 - 03:42 PM
Jeez you're a bloody sceptical lot. I've managed to get a hold of the dyno sheet and you can clearly see where the harmonics start to set in..
#78
_82911_
Posted 03 April 2010 - 07:54 PM
Cheers Greg..
#79
Posted 04 April 2010 - 03:58 PM
#80
Posted 04 April 2010 - 05:28 PM
I have a Massey Ferguson Balancer setup for a 202 bought years ago but never used. Sorry cant give pictures as I have lost my camera but anyone in Perth is welcome to come around if interested. Should be worth $150 and sorry, I am not posting, only pickup.
Edited by turbotrana, 04 April 2010 - 05:29 PM.
#81
Posted 04 April 2010 - 05:47 PM
Gee, after all these years I did not realise that the blue/black crank is not fully counterbalanced like the RB cranks. Those RB motors are so smooth.
can i ask why you wont post? ill give u $200 for it right now if u post
#82
_clubspClubsportr8ortr8_
Posted 04 April 2010 - 06:12 PM
Jeff
#83
Posted 04 April 2010 - 06:46 PM
#84
Posted 04 April 2010 - 06:57 PM
I assume Greg ment that half grout filling the block will help stop the flywheels from coming off, not that it fixes the inherent problems of the crank design.....
If you mean the balancer...Yeah well i cant really see what thats gonna fix either but as i said with the torque converter thing it might also band aid the problem enough to work.
Edited by Bomber Watson, 04 April 2010 - 06:59 PM.
#85
Posted 04 April 2010 - 07:09 PM
If you want to stop the flywheel falling off, stop tightening small hex'd nuts up against material that is (relatively) soft. Make up a single donut type washer out of something HARD like chromoly, and get some bolts that have a decent contact area (massive hex), and it'll hold the two dowels you should have in too.
#86
Posted 04 April 2010 - 07:21 PM
Or i might try it first...
Posted 04 April 2010 - 07:29 PM
The power that harmonic is stealing is the frOcking problem, not the flywheel falling off
i disagree, it might help but its not the solution, i reckon its a waste of time.
how many sbc's shake flywheels? i beleive the problem is elsewhere.
also, yella terra flywheels arent soft.
i will keep everyone posted about this cosworth groove i talked about, 10+ people have said it fixed their flywheel problem, so heres hoping. but if not, crank is getting crack tested.
#88
Posted 04 April 2010 - 08:23 PM
And Yella Terra flywheels might not be soft but they're softer than some case hardened chromoly mate
Edited by Heath, 04 April 2010 - 08:30 PM.
#89
_oldjohnno_
Posted 04 April 2010 - 09:07 PM
I agree that using a hard plate is good practice Heath. Most if not all of the engines I work on (mining/construction diesels) use such a thing; it's called a scuff plate and yes it's hard. Even so, the scuff plate and the bolts are replaced every time the flywheel is removed.
#90
Posted 05 April 2010 - 01:51 PM
Why I didn't want to post. I would rather have a chat with someone face to face for an hour for 150 than spend time packaging and posting which will prob take 45min by the time I go to the post office. The extra the buyer paid will cover lost time.
#91
Posted 05 April 2010 - 06:52 PM
