hatch project
435 replies to this topic
#426 derrin71
derrin71
  • 491 posts
  • Name:Derrin
Posted 08 March 2013 - 08:41 PM
Bought mine through JEGS, i'm sure Sumit would have them as well.
Cost $550 US. Sounds like a lot but you factor in the cost of a normal surge setup with 2 pumps, extra tank, fittings etc, price doesn't look too bad.
Forgot to mention it can also be used on a carb setup, as long as you use a regulator with a return line to the tank.
#427 SmacT
SmacT
  • 978 posts
  • Name:Sam
  • Car:LX 4dr 383, TKX, BW
Posted 08 March 2013 - 08:50 PM
Thanks mate, I posted too earlyin my excitement - found it on summit. Which hose fittings did you also need? I actually think its good value and looks good quality. I look forward to your updated post.
#428 derrin71
derrin71
  • 491 posts
  • Name:Derrin
Posted 08 March 2013 - 08:55 PM
I had all of the -6 AN fittings and hoses from the old setup. I had to buy 3 x -6 ORB to -6 AD adaptors which screw into the billet top plate. Got them from JEGS as well. Also forgot you need an inline filter between pump and engine.
I had all of the -6 AN fittings and hoses from the old setup. I had to buy 3 x -6 ORB to -6 AN adaptors which screw into the billet top plate. Got them from JEGS as well. Also forgot you need an inline filter between pump and engine.
#429 _TheJeanius_
_TheJeanius_
Posted 08 March 2013 - 11:41 PM
Derrin, I am super impressed.
This thread makes me want to work on mine even more. You have done an amazing job. I have taken notes for future reference. ;)
#430 derrin71
derrin71
  • 491 posts
  • Name:Derrin
Posted 11 March 2013 - 11:24 AM
Here's an update on how the new fuel pump setup is going.
In a word, FANTASTIC, no more surge issues, ran the tank down almost dry and no loss of fuel pressure.
The pump is quiet. The car seems smoother to drive especially at low speed, might have something to do with more consistent fuel pressure.
I would recomend an Aeromotive Phantom Fuel System to anyone who was considering an EFI conversion.
#431 _j.e.d._
_j.e.d._
Posted 11 March 2013 - 11:27 AM
This is excellent info - thanks Derrin!
#432 Statler
  • 6,317 posts
Posted 11 March 2013 - 12:45 PM
I thought it was illegal in Qld to run the exhaust under the diff?
That's what the local exhaust shops are telling me.
#433 derrin71
derrin71
  • 491 posts
  • Name:Derrin
Posted 11 March 2013 - 02:38 PM
No issue as long as clearance to ground is at least 100mm.
#434 DanWA
DanWA
  • 2,440 posts
  • Car:LS1 LX 4 Door
Posted 23 October 2014 - 02:02 PM
Came to check out your pump setup, ended up reading the whole thing
Thanks again mate!
#435 _Meggsy83_
_Meggsy83_
Posted 28 July 2016 - 08:00 PM
Hi.  I've installed the same Aeromotive Phantom system unit into my LH. where did you run the Vent?  new setup or stock setup.
#436 derrin71
derrin71
  • 491 posts
  • Name:Derrin
Posted 30 July 2016 - 03:30 PM
It runs to the charcoal canister which is hidden under the front passengers guard. Same setup as standard except everything is hidden.
