hatch project
435 replies to this topic
#26 Statler
  • 6,317 posts
Posted 28 April 2010 - 01:43 PM
Cool!
#27 derrin71
derrin71
  • 491 posts
  • Name:Derrin
Posted 30 April 2010 - 05:12 PM
Have been mucking around with the fuel pump and filter. Had to move them as my blue plate guy says i can't have them in the spare wheel compartment so i've had to mount them under the car. While i have the tank out again i have changed the fuel filler spout as i have to have a ULP one, i simply modified the commodore one, cut the torana one off and fitted the commodore neck to the tank.
#28 _dirtbag_
_dirtbag_
Posted 30 April 2010 - 06:04 PM
Looking good Derrin. Just so you know, the unleaded neck isn't necessary for a mod plate any more as leaded fuel is no longer available anyway.
Good job with the wiper motor too. If I wasn't so lazy I'd do that as well : )
#29 derrin71
derrin71
  • 491 posts
  • Name:Derrin
Posted 01 May 2010 - 07:51 AM
I'm just following instructions from my mod plate guy in regards to the fuel filler. At least now the fuel cap should seal better than the notoriously leaky old style ones. No more fuel leaking down the back of the car.
#30 ls2lxhatch
  • 5,332 posts
Posted 01 May 2010 - 01:29 PM
The NCOP (WA) still requires an unleaded fuel restrictor and labels even though unleaded fuel is not available. If the rule has not been revised/deleted then the engineer can not sign off on the car without the restrictor and labels. Last time I checked WA had not deleted the rule. Common sense is often not an option when it comes to government departments.
See page 11 item 2.4 of the checklist to be completed by the engineer.
NCOP9 Section LM Fuel Systems 3 Feb 2006
Edited by ls2lxhatch, 01 May 2010 - 01:34 PM.
#31 _doogs_
_doogs_
Posted 11 May 2010 - 02:32 PM
Sweet project mate.
Thanks for putting up the details of how you went about mounting the BW78, interesting stuff.
#32 derrin71
derrin71
  • 491 posts
  • Name:Derrin
Posted 16 May 2010 - 05:28 PM
Remade my front brake lines today, i wasn't happy with my first effort.
The lines run through the chasis rails and under the lip on the firewall that the passenger side line normally runs on top of.
The mastercylinder and booster are off a VK V8 and i believe are the same as an A9X. This gets rid of the ugly proportioning valve and will work well with the 4 wheel discs i am running.
#33 derrin71
derrin71
  • 491 posts
  • Name:Derrin
Posted 19 May 2010 - 05:31 PM
Fitted the battery box today, the cables are routed through the bottom of the box. There is a drain in the bottom and the box will be eventually be completely sealed to comply with Qld rego regs.
#34 derrin71
derrin71
  • 491 posts
  • Name:Derrin
Posted 24 May 2010 - 10:12 AM
Fitted up a set of AU F----n thermo fans the other day. Apparently they are awesome for keeping an engine cool. Just have to be carefull about their power draw. I mounted mine upside down which looks a lot neater and the wiring loom ends up on the bottom and points to the passenger side so i can put the relays etc under the passenger side guard. The shroud needed a fair bit of trimming to make room for the hose outlets etc. I also trimmed a fair bit off the shroud to get it to sit closer to the rediator. By the way the radiator i have used is the one out of the donor commodore. It fits neatly between the chasis rails. I used the original commodore mounting hardware which i simply cut off the commodore and adapted to the torana.
#35 _Barman_
_Barman_
Posted 25 May 2010 - 07:28 AM
Hey
Nice job on the fans,
make sure you run 2 relays and heavy wire,and 40amp fuses.
i found out the hard way that these fans draw about 30/32amp on startup
then drop back to 10 when running,
this is my set up now (it still needs tidy up)
#36 ls2lxhatch
  • 5,332 posts
Posted 25 May 2010 - 10:47 AM
Make sure that the battery you put in the box is a sealed battery. The fumes given off by an unsealed lead acid battery are explosive and corrosive.
You also need to make sure that the battery hold down straps are strong enough to handle the forces involved in an accident.
#37 derrin71
derrin71
  • 491 posts
  • Name:Derrin
Posted 25 May 2010 - 04:51 PM
Thanks Baz i've already spied on your thread and will be doing something similar.
The battery is secured in the box with a conventional battery hold down clamp, the box will eventually be gully sealed, there is a pipe running from the bottom of the box through the floor and venting above the diff housing.
Fitted up a gilmer belt drive today! I've always wanted one of these, i just love the noise they make!
#38 _Barman_
_Barman_
Posted 26 May 2010 - 07:40 AM
Did you buy your gilmer from KSM,
have you been there?
Im waiting for my gilmer set to show up, bought it here for $155.
Have you seen (and heard) Dwaynes HQ Monaro getting around town? its got gilmer and it sound cool,
Thats why i got a set.
Baz
#39 derrin71
derrin71
  • 491 posts
  • Name:Derrin
Posted 26 May 2010 - 12:07 PM
Bought mine off e-bay for $150, it's a pro comp motorsport one. Fits pretty good except for the balancer pulley, i need to make up a spacer for this one. Just using washers at the moment. It seems that the kits might fit a number of engines and they only change the belt lengths to suit.
#40 derrin71
derrin71
  • 491 posts
  • Name:Derrin
Posted 07 June 2010 - 11:43 AM
Wired up thermo fans yesterday, 40amp fuses and relays as suggested by Baz, all wiring will hide under the LHS guard, have installed a Davies Craig fan controller as well, it sits on the radiator support panel.
#41 Statler
  • 6,317 posts
Posted 07 June 2010 - 12:30 PM
Just curious m8, did the alt bracket bolt up to the the VN heads ok?
Edited by coolngroovy, 07 June 2010 - 12:30 PM.
#42 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 07 June 2010 - 12:54 PM
The Torana bracket will bolt straight up to the VN heads no problems.
Great looking build mate, making great progress!!
#43 _dirtbag_
_dirtbag_
Posted 07 June 2010 - 03:56 PM
Looking good. If you want even more entertaining whining sounds you can't beat a gear drive. Both of my torries had them as I think the novelty of them is great : ) The amount of people who asked if my car was supercharged was hilarious. Unfortunately for me though, the answer was no : (
They're cheap and easy to fit too, which is a bonus.
A lot of people said they were bad for street engines and interfered with balance harmonics and crap, but in the 150,000+ km's I did I never once had an issue with either of them.
#44 derrin71
derrin71
  • 491 posts
  • Name:Derrin
Posted 08 June 2010 - 12:32 PM
Yeah, i will probably fit a gear drive as well, not sure when i will rebuild the motor, might just detail it a bit and drive it around stock for a while until i can afford to rebuild it, the motor is fine and was being used as a daily driver before i got it. (unless i win lotto then all bets are off and the sky's the limit!!!!!) In all reality i just want it to be a nice street motor, probably 355 stroker.
#45 ls2lxhatch
  • 5,332 posts
Posted 08 June 2010 - 01:59 PM
Gear drives transmit vibration to the camshaft which can cause valve train problems. Noise = vibration.
Belt drive is considered by many to be the ultimate cam drive system.
#46 _dirtbag_
_dirtbag_
Posted 08 June 2010 - 02:09 PM
Yes Andy, I agree that the belt drive is probably better than a geardrive in a perfect world, but I ran two cars with them over a combined period of about 7 years and never had any issue. I only used them though as I like the sound : )
#47 ls2lxhatch
  • 5,332 posts
Posted 08 June 2010 - 02:38 PM
The difference if any between a gear drive and a belt drive would need to be measured on a dyno.
It would be interesting to see how many engine builders recommend using a gear drive over a belt or chain.
#48 _dirtbag_
_dirtbag_
Posted 08 June 2010 - 03:27 PM
In all honesty Andy I would be surprised if any builder of quality/performance engines recommended a gear drive over chain/belt. I've never had an engine with any more than probably 350 -380hp so I needed to get my jollies by making them sound funny : ) hahaha
#49 derrin71
derrin71
  • 491 posts
  • Name:Derrin
Posted 25 June 2010 - 03:31 PM
Have seriously started to look around for some wheels. I want to run the same size wheels and tyres front and rear so i can have the same size spare as well. Any ideas if 17 x 8" or 15 x 8" rims will fit on the front of an unflared LX? I want to run 235 tyres. Not sure if i will have 15" or 17" rims until i make my final choice. I have measured up and i think that i need 4 1/2" backspace if i run 8" rims. Anyone?
#50 _Barman_
_Barman_
Posted 25 June 2010 - 07:00 PM
17x8 are too big for front, 17x7 are good for 225 45 and ive got 17x8 with 245 45 on the rear,
