hatch project
#51
_Barman_
Posted 29 June 2010 - 07:06 AM
#52
Posted 08 July 2010 - 07:25 AM
#53
Posted 12 July 2010 - 02:59 PM
#54
_Barman_
Posted 15 July 2010 - 05:04 AM
#55
_dirtbag_
Posted 15 July 2010 - 05:49 AM
#56
Posted 15 July 2010 - 11:21 AM
#57
Posted 09 August 2010 - 03:47 PM
Fitted a charcoal canister i got off the old man, hid it under the left front guard, it's off a mini so it's pretty small, still have to hose it up though.
Machined up a spacer for my balancer pulley, a word of warning if you buy a gilmer belt kit off procomp motorsport you need to make up a spacer, the instructions say to just space it out with washers! The bolts they supply aren't even long enough.
Fitted and wired up my demster system, 2 x 12v hairdryers plumbed into the windscreen ducts so i can remove the factory heater system, used a relay to switch them as they use a fair bit of power. The cable ties are to hold it all together until i make up some type of system to secure the hairdryers.
Have been muckng around with wheels trying to work out what i want. I used a spare commodore rim and spaced it out to simulate the right backspace, took out the springs front and rear and simulated full wheel movement to check clearances. I have ordered new rims and hopefully they should be here sometime this week.
#58
Posted 09 August 2010 - 04:37 PM
Some people with drop tanks have been required by engineers to fit two Torana charcoal canisters to match the increased capacity of the fuel tank.
#59
_Barman_
Posted 09 August 2010 - 07:24 PM
and you still havent come around for that beer.... im on "D" crew roster, text me 0429820237
cheers Baz
#60
Posted 09 August 2010 - 08:42 PM
#61
_Lamo_
Posted 09 August 2010 - 09:50 PM
#62
Posted 10 August 2010 - 05:06 PM
And no they aren't marks or scratches on the rims it's water, it's been raining all day here.
#63
_Kush_
Posted 10 August 2010 - 05:59 PM
#64
_keg006_
Posted 10 August 2010 - 06:59 PM
#65
Posted 10 August 2010 - 07:29 PM
The rears are 18 x 8 which originally had 4 1/2" backspace, these would suit a standard diff length, i got 10mm machined off the back of mine before they drilled the stud holes because i am using a BW 78 out of a skyline which is a bit wider than a torana diff. i suppose you could say they have about 4 7/8" backspace.
I may have to do a little surgery to the front of the guards arches and the firewall seam in the front arches which is par for the course for toranas with big wheels. The wheel arch mods shouldn't be noticeable. As i said before i tried my 18" Commodore rims spaced out for size and everything should be right.
Once i get to take it for a little drive i will know what the clearances are like. Then i can strip the car put it back into the rotissary and do all of the body mods, panel and paint.
It was a tossup between these and showwheels streeters in grey.
I wanted this style of rim as i like the pro touring look which seems all the rage at the moment.
#66
_Barman_
Posted 11 August 2010 - 07:27 PM
#67
Posted 16 August 2010 - 05:29 PM
The rears fit really well, might just need a bit of guard lip surgery.
The fronts should look a bit better with a wheel alignment, (it has camber like a V8 Supercar at the moment!)
The front guard needs a little surgery both at the front but also the seam on the firewall but this is normal with big tyres on torana's.
Nothing too hard.
Might take it for a little drive up and down my driveway tomorrow.
#68
_Kush_
Posted 16 August 2010 - 06:00 PM
I like them very much, however I find it hard to tell if I like them on a torana. They need some rubber and a shot of the car from further back.
yes, I like them. I think the car will certainly sit lower when it's put back together.
#69
_Barman_
Posted 16 August 2010 - 06:02 PM
#70
Posted 17 August 2010 - 05:22 PM
Also my Dakota Digital Dash turned up today, only ordered it last Monday, 8 days to come from the states , excellent service if you ask me.
#71
_Barman_
Posted 17 August 2010 - 09:27 PM
Have you got a body colour in mind?
what happened to comming over? come over tommorrow
Baz
Edited by Barman, 17 August 2010 - 09:31 PM.
#72
Posted 18 August 2010 - 06:13 AM
#73
_Barman_
Posted 18 August 2010 - 07:45 AM
#74
Posted 18 August 2010 - 03:15 PM
#75
Posted 05 September 2010 - 05:10 PM
Here is the computer which i have put under the dash. Please excuse the wiring everywhere i need to tidy it up when i am finished.
