Exhaust manifolds LX 308 SS
25 replies to this topic
#1 _kangur_
_kangur_
Posted 15 April 2006 - 11:59 PM
Hi there are some exhaust manifolds on ebay which I might put a bid on if they are original LX SS 308.Can anyone help and identify them?
http://cgi.ebay.com....1QQcmdZViewItem
#2 _lx5008_
_lx5008_
Posted 16 April 2006 - 01:01 AM
they are v8 torana
#3 rodomo
  • 18,031 posts
Posted 16 April 2006 - 01:06 AM
Listing says "no leaks" but looks obvious that the rear of the right manifold had been leaking and may need machining.
#4 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 16 April 2006 - 10:19 AM
they are pre ADR27A Torana V8.
#5 _Mondie_
_Mondie_
Posted 16 April 2006 - 12:51 PM
Thanks for that Red, l guess l better withdraw my bid then :huh: How can you tell they are pre ADR 27A? l was advised they came off a July 77 SS.
#6 _kangur_
_kangur_
Posted 16 April 2006 - 01:08 PM
Is it a big issue if they have to be machined?.And is it expensive?.
#7 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 16 April 2006 - 01:13 PM
They will still suit your car ok. The RHS manifold to exhause studs are short on PRE ADR27A and there is a heating pipe that runs though, you can see the hole in one pic
#8 _Mondie_
_Mondie_
Posted 16 April 2006 - 01:14 PM
These have the hot air riser bracket, what else do they need to be 27a, l thought that was it?
Kangur, not sure what headers you are looking for but if you need a pair of pre pollution headers l will have a set once l get the correct ones for my car.
#9 _Mondie_
_Mondie_
Posted 16 April 2006 - 01:16 PM
Thanks Red, you must have posted just after l did. So these would be day one correct for my car?
#10 _kangur_
_kangur_
Posted 16 April 2006 - 01:51 PM
Hi Mondie,yes I'm after the pre pollution ones so these on ebay are obviously no good for me and even if they were i would not bid against a forum member.If you do end up getting these than I would be interested in your pre pollution ones.Let us know how you went and how much you would want for your manifolds.
Kangur
#11 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 16 April 2006 - 02:31 PM
The ones on EBAY are PRE ADR27A, they will still fit on a POST ADR27A Car. The left one is the same, the right one for a PRE ADR27A car has
1. Short studs for mounting of the exhaust
2. A hole running from front to rear for the auto choke
These ones on EBAY will fit on any Torana V8, but if you want to be 100% original, the right one is incorrect for a post ADR27A car.
#12 _kangur_
_kangur_
Posted 16 April 2006 - 02:49 PM
Thanks RED,there was a bit o mis understanding,so these will be right for my pre pollution SS.Mondie if they are no good to you than I will place a bet on these.If you let me know if I'm still bidding against you that would be great so we don't jack up the price for each other.
#13 _Mondie_
_Mondie_
Posted 16 April 2006 - 03:37 PM
Was that you who just won them Kangur? l tried retracting my bid 20 mins before close after reading Reds post but it wouldn't let me - that was after l found where to which is not made easy :furious: At least l got outbid, must say l am suprised at how much they went for though.
Thanks for the info REDA9X, now l remember the choke pipe you are talking about. Keep searching l guess.
#14 _kangur_
_kangur_
Posted 16 April 2006 - 06:16 PM
That wasn't me unfortunately,yes I was suprised as you with the price they sold for,oh well just have to be patient and keep looking.If I find some pollution ones I will be more than happy in swapping them with you for your pre pollution ones that you have.If you find some before I do than please let me know as I would take them of your hands.
Kangur
#15 _Mondie_
_Mondie_
Posted 17 April 2006 - 01:57 AM
Thanks Kangur, will do :spoton:
#16 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 17 April 2006 - 08:55 AM
I don't think you guys quite got what I was trying to say, they will still fit either model you have, pollution or non pollution. You could have bougth them and used them no dramas at all, that pipe does not leak, and the longer studs make bugger all difference. Oh well, they went for a decent amount
#17 _Mondie_
_Mondie_
Posted 17 April 2006 - 09:00 AM
No worries Red, l am fussy and want the 100% correct ones for my car with the auto choke pipe you speak of.
#18 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 17 April 2006 - 09:21 AM
OK Now I know you missed what I said. If you wanted the one with the auto choke pipe, you should have bought those ones
#19 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 17 April 2006 - 09:38 AM
PRE ADR 27A
POST ADR 27A
#20 _Mondie_
_Mondie_
Posted 17 April 2006 - 10:41 PM
l think l am getting there :D
Post ADR 27a has the auto choke pipe in the inlet maifold, pre has it in the drivers side header. Got it :spoton:
#21 _kangur_
_kangur_
Posted 18 April 2006 - 12:18 AM
Yeah,thanks RED that certainly helped.At least i know what to really look for.
#22 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 18 April 2006 - 06:12 AM
I would have bought these personally, the left one is the hard one to get the right one is the same as any HQ-HZ
#23 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 20 April 2006 - 11:05 AM
Back in the mid 80's my exhaust manifold cracked and I went to the wreckers, they all wanted at least $125 for just one side, one was more expensive than that of the other for some reason. Even back then they were hard to find.
Mine happened to be the expensive side so I ended up replacing them with extractors - much cheaper and performance enhancing at the same time.
I also remember seeing some with a butterfly type choke.
s
Edited by StephenSLR, 20 April 2006 - 11:08 AM.
#24 _kangur_
_kangur_
Posted 20 April 2006 - 04:08 PM
Extractors are a option but if you're restoring it to factory original it just has to have the right exhaust manifolds.There is plenty of extractors and cheap too(I have 2 sets now) but hardly any manifolds.About 15 years ago I chucked out 2 sets as they were not worth anything as at that time everyone wanted extractors,now these days is the opposite and everyone wants manifolds.
#25 _torana_
_torana_
Posted 20 April 2006 - 04:25 PM
reda9x I take my hat of to you, it appears as though what you dont know about toranas, just isnt worth knowing. :clap:
I see you answer so many questions put up here by people, and often wonder ' how on earth does he know this?'
I hope one day you can help me.
Its great to see you and other members helping each other in keeping the torana legend alive.
cheers julian
Edited by torana, 20 April 2006 - 04:27 PM.
