9 Inch Diff oil change
29 replies to this topic
#26 ls2lxhatch
  • 5,335 posts
Posted 15 February 2013 - 08:35 PM
Has anyone tried removing the bottom stud and replacing it with a bolt to act as a drain, or is the stud screwed into a blind hole?
The studs are a splined stud that is pressed in from the inside of the housing. They are a similar style to axle studs.
It would be easier to weld in a drain plug than it would be to replace the stud with a bolt.
#27 Marks LXTorana
Marks LXTorana
  • 158 posts
  • Name:Mark Grovenor
  • Car:LX Torana
Posted 16 February 2013 - 07:19 AM
Ah! that explains it :Headbang2:
Nothing is ever easy....
#28 Marks LXTorana
Marks LXTorana
  • 158 posts
  • Car:LX Torana
Posted 25 February 2013 - 01:01 PM
I put a another diff centre in the car and I noticed it has a grub screw in the bottom ofthe cast diff centre, to use as a drain!
#29 Marks LXTorana
Marks LXTorana
  • 158 posts
  • Car:LX Torana
Posted 01 March 2013 - 05:16 PM
What have I done??
I put the open diff centre in without a problem, then inserted the right axle without a problem, but when I tried to insert the left (short end) axle, it stopped with about 30 mm to go. I looked down the shaft and noticed a pin is protruding very slightly where the splines are. I compared this to the original diff centre that I removed but I cannot see where a pin might come through, making me think the spider gear assembly is modified to convert it to a locker (although the spider gears are still there).
So my question is, can I possibly knock the pin back enough to get the axle in (using a tapered steel bar or similar) or do I need to take the centre out again?
I think I know how I will be spending the wet weekend (doh)!
Edited by Marks LXTorana, 01 March 2013 - 05:17 PM.
#30 _rob350hatch_
_rob350hatch_
Posted 01 March 2013 - 07:08 PM
i just use a drill pump to suck it dry peice of piss but that is if you have the drain plug and then filling is the reverse process.the required amount is placed in a container and sucked up back into the diff .easy as.
with my race car i just fill it back up thru the breather tubes.
