hi, once this problem is sorted out, can we r/s customers exchance our new still
in the packet hatch 1/4 rubbers for the new replacment ones.
Unused ones yes.
Edited by les, 23 April 2010 - 05:12 PM.
Posted 23 April 2010 - 05:12 PM
Posted 24 April 2010 - 07:54 AM
Unused ones yes.
Posted 04 May 2010 - 05:31 PM
Posted 07 May 2010 - 08:16 PM
Posted 07 May 2010 - 09:08 PM
Posted 07 May 2010 - 10:15 PM
Posted 08 May 2010 - 04:30 PM
Posted 08 May 2010 - 05:39 PM
ok here we go. first with the 3rd lot of rares door rubbers. its been a few weeks since i fitted them and i have to say they did get a little better. the 3rd lot are very very soft and they did squash flat and out of shape in the problem front lower corner. all the way round the door frame the rubber was out of shape but did shut a little better.
now the new rubbers from aussie muscle car parts in qld. now these do look like the genuine rubbers with different locating lugs to the rares rubbers. i did have a little problem fitting them, the black plastic things in the door frame are a little to small, i had the make the hole rounder by using a small plillips head screwdriver. cause the genuine ones are not round enough for them. once that was done with a fair bit of pushing they went in. now looking at them fitted and checking the genuine ones fitted to the slr they do look the same. shutting the door at about 30 cms it closes perfect and you dont have to slame the bloody thing hard.
Posted 08 May 2010 - 05:49 PM
Posted 08 May 2010 - 08:59 PM
Posted 08 May 2010 - 09:21 PM
Posted 09 May 2010 - 11:13 AM
Edited by The Baron, 09 May 2010 - 11:19 AM.
Posted 09 May 2010 - 01:45 PM
Rares has changed the hatch seal, but it is still not as per original..the section that sits in the square channel is not square as per the original for example.
But it is a massive improvment over what they (and others) have been selling for the last 20 plus years.
Just check you are getting the latest, as I'm sure a retailer would prefer to move old stock first!?
If someone has the latest RS seal, could they post a photo of the side (cut end) profile? Just to help other check?
Posted 09 May 2010 - 05:35 PM
Edited by lx5008, 09 May 2010 - 05:42 PM.
Posted 09 May 2010 - 06:35 PM
When i fitted my Rare Spare Rear Quarter Window Seals & had to close the windows i was shitting myself.
Close the window with 2 hands,one outside pushing the glass & the other locking it.
i am not opening them again in fear of cracking thr glass.
Posted 09 May 2010 - 09:41 PM
Posted 10 May 2010 - 08:18 PM
Edited by sstorana, 10 May 2010 - 08:24 PM.
Posted 10 May 2010 - 10:31 PM
Posted 11 May 2010 - 07:58 AM
As advised at the time, I have used a little quickgrip to keep the seal in place.
I do not intend to rip it out and have to clean/sand it out before fitting another seal unless the seal is 100% right.
So, thank you guys for following this through and trialing the different seals on the market.
It is saving me one very big headache.
PS..any one know a good none destructive way of removing old (3yrs) set quickgrip short of acetone !
Posted 12 May 2010 - 12:39 PM
Posted 12 May 2010 - 01:06 PM
Posted 12 May 2010 - 02:17 PM
Just a bit of history, the original door rubbers were made by SA rubber which later became Bridgestone. They were made from a rubber skin filled with foam on a metal carrier that doubled as a clip. It should also be noted that they were porous on the back to some extent and allowed water into the rubber.
This was an antiquated and inefficient way of making weather seals and when Bridgestone dropped the process GMH designed a new style of seal which included the current style plastic clip. RSP (Rare Spares) supplied GMH these door seals for many years to the GM specifications until GMH dropped the product. Rare Spares carried on making these however over the years we have changed the compound to try and improve the product to satisfy our customers. We have adopted new technology to enable us to do this with our current range of products. Presently we are at a point that if we make the seal any softer then it will not work as a door seal because the �memory� and durability will be compromised.
We could have opted for the simple solution that other companies have used by making a hollow tube. Primarily that style of seal is designed as a weather seal to be used on a cabinet that is not opened as much as a car door. We in fact already have the same seal that is on the market at the moment, and have had for many years but declined to use it because of its lack of durability and memory retention (the characteristic that ensures it will return to its original shape when the door is open)
http://rsp-secure.co...mage=39-620.jpg
In the long run the customer will decide which is best to suit their car but I feel confident that if a Rare Spares seal does not fit your car door then it is being fitted incorrectly or there is a problem other than the rubber
Posted 12 May 2010 - 02:31 PM
Posted 12 May 2010 - 07:26 PM
Posted 12 May 2010 - 09:52 PM
