![](https://secure.gravatar.com/avatar/d41d8cd98f00b204e9800998ecf8427e?s=100&d=https%3A%2F%2Fwww.gmh-torana.com.au%2Fforums%2Fpublic%2Fstyle_images%2Fblackstream%2Fprofile%2Fdefault_large.png)
The blown uc 202
_BlownUC202_
Posted 08 April 2010 - 12:19 AM
Posted 08 April 2010 - 08:13 AM
_TJ253_
Posted 08 April 2010 - 11:56 AM
_BlownUC202_
Posted 01 June 2010 - 01:13 AM
this is what i started with.
![Attached File](https://www.gmh-torana.com.au/forums/public/style_extra/mime_types/gif.gif)
this my new interior
_BlownUC202_
Posted 25 June 2010 - 10:02 PM
well heres my engine with the end caps milled flat
IMG]https://cache.gmh-to...02/Image202.jpg[/IMG]
this is the template i made for the crank girdle
IMG]https://cache.gmh-to...c202/Image5.jpg[/IMG]
this is the girdle i got arp head studs and had a machine shop shorten them by half an inch.
IMG]https://cache.gmh-to...c202/Imageo.jpg[/IMG]
I will post pics of the oil system tomorrow and the rest of the engine then the body work
_BlownUC202_
Posted 26 June 2010 - 09:25 PM
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/25092009014.jpg)
Then i drilled and tapped npt threads into the two far ends of the main oil gallery.
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/29092009018.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/29092009019.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/29092009020.jpg)
I made a t peice for where the oil pressure sender goes and joined it to the two outer fittings with hose.
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/29092009021.jpg)
I made a fitting that comes out of of where the standard oil filter goes and tapped a thread and plugged the small hole in the pump. So what happens is the oil is picked up in the sump sucked into the side of the oil pump, pumped out of the end of the oil pump to a remote mount filter then back to the t peice then gives even oil presser to the center and ends of the engine.
After i was happy with it all i had all the parts chromed
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/13102009038.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/13102009039.jpg)
_BlownUC202_
Posted 26 June 2010 - 09:47 PM
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/31032010220.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/31032010221.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/31032010223.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/31032010226.jpg)
New black carpet
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/31032010222.jpg)
I bought a pait of autotechnica race seats for the front.
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/31032010224.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/31032010225.jpg)
_TJ308_
Posted 26 June 2010 - 11:30 PM
Posted 27 June 2010 - 02:53 AM
_BlownUC202_
Posted 27 June 2010 - 08:07 PM
_BlownUC202_
Posted 27 June 2010 - 10:16 PM
The main hoop
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/02052010283.jpg)
I made the two rear bars bolt onto the main hoop.
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/03052010284.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/03052010285.jpg)
Made some brackets to use the 2 origanal seat belt bolt threads to mount the cage and fitted a bar with tags to mount the new seat belts.
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/21052010315.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/21052010316.jpg)
In the car
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/22052010317.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/22052010318.jpg)
With one of my new front seats and harness
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/22052010322.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/22052010323.jpg)
Posted 28 June 2010 - 08:10 AM
_why-psi_
Posted 28 June 2010 - 08:55 AM
Just an observation about the "taxi bar" that you have fitted to your roll cage. I think you'll find that it is mounted to low to be legal with ANDRA or CAMS sanctioned events as the belts are to vertical. The bar would be better at the same height as the holes through the seats.
was about to say the same thing. with the belts vertical like that, in an accident they will compress your spine. ANDRA regs are shoulder straps mounted behind the driver must be above a line drawn downward from the shoulder at an angle of 40 degrees to the horizontal. Id move the bar up to about the top of the doors
_BlownUC202_
Posted 28 June 2010 - 08:40 PM
_BlownUC202_
Posted 28 June 2010 - 08:57 PM
I pulled the 2 fenders and stone gaurd off my spare uc and marked where to cut.
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/23052010325.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/23052010326.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/23052010327.jpg)
chopped it off
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/23052010328.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/23052010329.jpg)
Then added 100mm to it
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/23052010330.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/24052010331.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/24052010332.jpg)
it looks rough but it sanded up ok.
_BlownUC202_
Posted 28 June 2010 - 09:04 PM
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/01062010337.jpg)
I did the same as dirtbag here used an lx front spoiler as a template to make steel brake cooling ducts.
Once made i tacked them in place.
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/04062010340.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/04062010341.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/04062010342.jpg)
All the metal i used was recycled from the roof of one of my xf demo derby cars (the only straight bit of metal left on the car).
I stared to fill the gaps this took alot of tacking then bending to shape.
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/04062010344.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/04062010345.jpg)
All welding finished just smoothing it out with filler i will post pics when its finished.
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/22062010351.jpg)
Posted 28 June 2010 - 10:45 PM
I was gonna say exactly the same thing about the cage but yeah looks like you didn't too a bad job other than the location of the taxi bar. I want to do that even more now! haha
_BlownUC202_
Posted 29 June 2010 - 08:51 PM
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/20052010304.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/20052010305.jpg)
Thought i would jack it up and see what it looked like with some 29x12.5 drag slicks.
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/20052010312.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/20052010313.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/20052010314.jpg)
I havent finished the front flares yet they needed a lot of work.
_BlownUC202_
Posted 29 June 2010 - 08:59 PM
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/Image202.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/Image5.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/Imageo.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/04062010339.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/04062010338.jpg)
_dirtbag_
Posted 29 June 2010 - 09:07 PM
I hear that Dirtbag guy is a real loser, best not say you did anything that he did : ) hahaha.
Look forward to following this thread.
#21
_BlownUC202_
Posted 29 June 2010 - 09:38 PM
Im going to be running a manualised trimatic (thats a big horsepower stealing oil pump dirtbag) =) so i bought a B and M quick shifter. I didnt wanna just use the B and M shifter surround and it wouldnt fit into the standard shifter sorround so solution was make a custom one.
I got a standard shifter console.
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/09062010347.jpg)
measured shifter height and cut a chunck out.
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/09062010346.jpg)
Fibreglassed it flat with a space for the shifter smothed it with filler and bolted down the chrome shifter display.
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/23062010352.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/23062010353.jpg)
All painted im gonna use the flat bit thats upright for all my switches
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/23062010355.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/23062010356.jpg)
Next to a standard one.
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/23062010354.jpg)
#22
_dirtbag_
Posted 29 June 2010 - 09:48 PM
Seriously though, console looks great!!!
#23
_BlownUC202_
Posted 29 June 2010 - 09:52 PM
#24
_Barman_
Posted 02 July 2010 - 07:02 AM
great work i like the gurdle and oil lines very professional
cheers Baz
#25
_BlownUC202_
Posted 03 July 2010 - 08:17 PM
Nice and easy with an engine crane and leveling block.
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/01072010364.jpg)
The bare deengined bay.
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/01072010365.jpg)
Thats as far as i got for now because i got destracted with something else.
