Had to do a dummy fit first.
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/02072010367.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/02072010368.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/02072010369.jpg)
This is the 80A pump i had to give the drive gear to a mate to machine it to fit inside my gilmore pully on the crank.
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/02072010370.jpg)
I unbolted the manifold and measure and marked where i was gonna drill the holes for the jets.
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/02072010373.jpg)
Then drilled the 6 holes and tapped them with an 1/8 npt tap.
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/02072010375.jpg)
Then i fitted all the nozzles and hoses. This kit is for a small block chev so it has 8 lines luckly 6 had 90 degree fittings and 2 had straight jic fittings so all i did was remove 2 of the longer hoses from the block and plug the holes and got 2 joiners and joined them to the 2 straight hoses so they would reach number 1 and 2 cylinders.
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/02072010376.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/02072010377.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/02072010378.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/02072010379.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/02072010382.jpg)
![Posted Image](https://cache.gmh-torana.com.au/i930.photobucket.com/albums/ad143/blownuc202/02072010385.jpg)
Looks pretty sexual if i dont say so myself.
