Modifying an open Banjo centre?
#26
Posted 20 April 2006 - 06:53 AM
#27
Posted 20 April 2006 - 02:08 PM
how about Volvo diffs? they already have the right stud pattern.
#28 _CHOPPER_
Posted 20 April 2006 - 07:24 PM
Thanks for that. LH - UC rear track is 54", so it's a matter of using different offset rims to get it close enough. I shall keep this in mind. Just need to keep money in the pocket.Chopper,the diff that I used was from a 1978 RN25 which has shorter axles the same length as the LC/LJ 670mm(rough measurement). Toyota changed the length somewhere around 1980/82 to 695mm(accurate measurement)this may be suitable for LH/LX/UC? Comparing a B/W & Hilux very similar in size inside Hilux has thicker crown wheel plus the Hilux can change ratios quicker due to it being a removable centre. I have seen plenty of these diffs used in dragsters over the years appear to be quiet strong without the weight of a 9" & about 3kgs heavier than a banjo.
#29
Posted 04 May 2007 - 05:23 PM
Was said somewhere that a LSD for a VOlvo diff was expensive? What would you be looking at price wise, also read else were to that they are a Dana 30 ????? and that LSD are easy to find for these. Did i remember all this correct????
Obviously a 9' in better but just looking at other opions
If you went't the hilux for more avaliably ratio's and centres, what brakes did they run, or what brakes could you run with these????
#30
Posted 10 May 2007 - 03:21 PM
#31
Posted 19 June 2007 - 07:55 PM
THanks Mate
#32
Posted 11 August 2013 - 02:08 PM
Hi Guys.
Dave720gtr said
"vL turbo 4pinion LSD is one of the strongest and prob the best choice"
The VL turbo 4-pinion is no stronger than the VL V8 LSD, the ratio is the only difference.
Also all VN to VS LSD 'live axle' rear ends (V6 or V8) are the same strength again, only around 2" longer. They're all 28 spline 4-pinion. If you shorten the axles to the required length the VN to VS are way cheaper & more plentiful than the VL turbo & V8 diffs.
Dr Terry.
I was looking around and found this Dr Terry,
http://www.gumtree.c...u-ef/1024793674
VL TURBO.jpg 31.19K 1 downloads
A very good idea to keep all things Holden and is this wider than a Banjo Centre Carrier. Dave I
Edited by TORYPOWER, 11 August 2013 - 02:20 PM.
#33 _Bomber Watson_
Posted 11 August 2013 - 02:51 PM
Wow, 7 year old thread?
