Repairing Fuel Tanks
_APL_
Posted 13 April 2010 - 01:29 PM
I plan to buy the Por 15 repair kit, which is a three part procedure.
Has anyone used it and what are your thoughts??
Also any ideas blocking the holes...IE:- Bungs for filler and sender unit points.
APL
_shep jnr_
Posted 13 April 2010 - 02:56 PM
The LJ Torana developed a tiny leak in the top RH corner near the breather outlet.
APL
Hi . my grandfather is a plumber and he is gunna silver solder my tank. its in the same spot..
Posted 13 April 2010 - 03:37 PM
LOL
Just kidding, no idea! Silver solder as above maybe?
_oldjohnno_
Posted 13 April 2010 - 08:16 PM
If there is any doubt whatsoever that you can thoroughly purge all the vapour then DON"T DO IT!
Take it to your local radiator bloke instead of risking a big bang.
_APL_
Posted 14 April 2010 - 05:43 PM
Thanks for that oldjonno....Silver solder makes a permanent repair but you have to know what you are doing to do it safely. I recently ss'd a patch on my young blokes HZ tank. Basically you have to wash the tank out thoroughly with water and detergent and then purge any remaining vapour with an inert gas like co2. Once this is done you loosely cap any openings to trap the co2 (or whatever you used) while you make the repair. If you find you need to make a 2nd attempt (if there is still a pinhole for example) then you need to repeat the whole procedure.
People that I have spoken with are reluctant to carry out the repairs.
A small hole on the outside of the tank does not vouch for the integrity on the inside.
As I understand the Por 15 Repair kit is a 3 parts procedure:
Cleaner
Etcher
Coating
This in my opinion may be the better course of action, but was wondering if anyone else has used it.
APL
Posted 14 April 2010 - 06:08 PM
i would personall be going for a more permanent fix than that if you are going to weld it tip i got from my trade school teacher its get a big of vacuum cleaner hose and pipe it to the filler neck that way it wont go bang obviously clean it out as said in one of the above posts
_oldjohnno_
Posted 14 April 2010 - 07:20 PM
PLEASE don't do this! Your trade school teacher is an idiot. Usually the airflow thru a vacuum cleaner passes through the motor to cool it once it's been through the filter/bag. Fumes from the tank + sparks from the brushes might be exciting. Testing a carburetor that hasn't been completely emptied on a flowbench can result in similarly spectacular results.
You can flush as much air thru it as you like but it will never really be safe until you replace all that oxygen with something inert like co2.
Please don't frOck with this stuff fellas, too many people have been hurt over the years because they didn't know what they were doing..
Posted 14 April 2010 - 08:20 PM
_oldjohnno_
Posted 15 April 2010 - 05:44 AM
my tank has a pin hole and the tank hasnt been in the car or had petrol in it for over 14 years its bone dry do these rules still apply
As unlikely as it is that there would be any trace of fuel left after 14 years I'd still use the same procedure.
Posted 15 April 2010 - 07:47 AM
Posted 15 April 2010 - 08:27 AM
woops sorry forgot to say atach othe end of pipe to a running cars exhuast NOt the vaccum cleaner
Posted 15 April 2010 - 08:51 AM
They de gas by washing them out then running a car exhaust thru them.
They then soldier the holes up.
If you plan to keep the tank forever this may be the go followed up with the por 15 to seal the inside.
Posted 15 April 2010 - 09:18 AM
Interesting.Radiator repair shops repair fuel tanks.
After consulting ALL of the radiator places in my town, none of them are allowed to repair fuel tanks anymore.
Posted 15 April 2010 - 09:23 AM
Easy enough job to do yourself tho.
_sshatch355_
Posted 15 April 2010 - 12:10 PM
Posted 15 April 2010 - 12:13 PM
Cheers Dave
Posted 15 April 2010 - 08:04 PM
cheers Blake
_robrenjus_
Posted 15 April 2010 - 09:54 PM
Posted 15 April 2010 - 10:44 PM
Posted 15 April 2010 - 11:02 PM
can anyone verify whether or not it is legal or illegal for radiator mobs (or anyone else for that matter)to repair or modify fuel tanks ?? sounds like crap to me and i just had my radiator guy clean and neutralize the vapours in a caustic soda bath and solder a vp swirl pot /fuel pump into my lx tank charged me 100 bucks check it out
looks like youve cut through your breather.
#21
_robrenjus_
Posted 16 April 2010 - 07:18 AM
#22
Posted 16 April 2010 - 10:59 AM
The breather that has been cut is there so when the car is parked nose down the two front breathers will be submersed but the third breather will be clear.
If all breathers connected to the liquid vapour separator are submerged and the tank is full then when the fuel expands it will be pushed into the charcoal cannister. Many drop tanks do not have the rear breather and push fuel out the charcoal cannister on a hot day.
Edited by ls2lxhatch, 16 April 2010 - 11:04 AM.
#23
_1uzbt1_
Posted 16 April 2010 - 03:57 PM
[/quote]
Interesting.
[/quote]
We used to solder them up but decided in the end the risk outweight the profit, whether it was legal for us to do it im not sure.
For what its worth, we used the old soldering irons you had to heat with a blow torch and then proceeded to solder them up that way.There is no direct flame with this method btu was alittle time consuming.
#24
_Torana308_
Posted 16 April 2010 - 09:09 PM
Since using the KBS kit there are no leaks at all from it finally. Wouldn't use it to fix a big leak though.
